Question about Camp Chef Smoke Vault Patio Cover 24'' PC 24
Cant get the burner to put out enough flame - Camp Chef Smoke Vault Patio Cover 24'' PC 24
Why my cooking range big burner giving yellow flame whereas other burners running.
A yellow flame indicates not enough air is reaching the burner. That particular burner may have a clog which is preventing sufficient air.
May 18, 2014 | Ovens
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Dynasty gas range - orange flames
It is normal, it will disappear after a little while, when you bang on the burners, particle fell off form inside of the burners and it caused the orange flame. Yellow flame means not enough air or burner is internal clogged.
Feb 15, 2010 | Dynasty DGRSC 36-6 Gas Kitchen Range
Furnace was not coming on red light was blinking once now its working wondering what the one blink means cant find my manual
One blink does not tell you much, it tried 3 times to start and did not.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Jan 10, 2010 | Goodman GMS90703BXA Heater
Goodman furnace seems to be cycling too often. Burner not staying on long enough to put warm air into system. Burner quits after a few seconds then repeats.
dIf the burners are only staying on for about 5 seconds, you proably hav e a dirty flame sensor. Watch the burners light, the glow plug will light one end of the burners, in front of the last burner to light the will be a small thin rod, this rod must sense the flame or the gas will be shut down. Take a piece of steel wool and gently cleqan the rod.
Oct 11, 2009 | Goodman GDS80904BNA Open Flame Heater
Flames under all burners are very small
It is possible to rejet the burners but I cant recommend doing this as there can be safety issues. First thing I would do is relace the gas regulator and then go from there. It sounds like low pressure to me. In this country it would be set to around 12-15 psi.
Sep 29, 2009 | Maytag CWG3100A Gas Single Oven
Yellow flame on the rear of my burner
Yellow is a "reducing" flame meaning low oxygen, whereas blue is an oxidizing flame. There is not enough air mixing with the gas. Clean out the pipes and free the air intake holes on the first stage of the burner assembly.
Jun 02, 2009 | Char-Broil CharBroil Master Flame Gas...
Had no gas coming into the oven of my Viking 305. bought a new dual thermal valve and replaced it. now i have small flame on left burner and none on right. right after installation, flame was strong for...
Are the burners on top getting enough gas? Is there enough gas coming out of the wall? Did you purchase the correct dual valve? Is the orifice sizing correct? Make sure the holes are not plugged on the burners. And u should also check to see if your line has debris in it. Either unplug the holes or check the pressure out of the line in the wall. What makes you think the right one isn't getting enough gas? Could it be an ignitor? Anyways, the burners have a 5 yr warranty. Try replacing those. Good luck.
Apr 28, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
The furnace burners won't stay lit
Could be a couple things. First and easiest is to check your intake combustion air supply. If it is blocked by anything or just not enough flow, it will put out the flame. Next would be the flame sensor, usually a temperature probe near the flame front. If it's not reading an increase in temp within a pre-programmed time, it will kill the flame. It can be checked with a multimeter.
Jan 16, 2008 | Heating & Cooling
Heater puts out dirty residue ( bad )
Check with the manufacturer but in most cases, yes blue. A dirty flame is caused by either too much gas, not enough gas, too much air or not enough air. By cleaning the burners you may have inadvertently misadjusted the unit. Contact your gas company to get a technician in to inspect it.
Oct 23, 2007 | Heating & Cooling
Camp Chef Smoke Vault Patio Cover 24'' PC 24 Logo
64 people viewed this question
Top Camp Chef Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Camp Chef Grilling Expert? Answer questions, earn points and help others
