Question about Machspeed Trio DROID-7C Tablet
My trio tablet wont connect to wifi. It says Authentication Problem.
    New Friend:
  • 57 Answers
1.this happens if the SSID or Network name is the same in two places that you go to, but the password is not the same
2. it could be your router that needs resetting, or just unplug and plug it back up and see what happens
3. you can Delete - or tell your tablet "forget" the network in question and reconnect all new
4. if non of the above works - turn your device off and wait a little bit and turn it back on
let us know if this help
thanks
Posted on Oct 18, 2013
Have a Trio Stealth -10 wont connect to the WiFi
Is wifi turned on on the tablet? If not, go to Settings>Wifi and turn it on. The device should then automatically scan for networks.
If you are able to connect to your network but then cannot actually get to the Internet you may just need to restart your router. You might get something like "Obtaining IP address" for a long time and then get "Limited" connection. Correcting this may be just a matter of unplugging it for about a minute then plug it back in. Wait 4-5 minutes for the router to boot up completely then try connecting again. Some routers are sensitive to new devices. When I had AT&T Uverse router I would have to restart it every time I tried to add a new wifi device.
Hope this helps.
Jan 03, 2016 | Trio 1 - MACHSPEED -STEALTHG210.1 10.1"...
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
Authentication problem. Reset wifi and tablet. Nothing is working.
An "authentication problem" means that that the wifi does not accept the wifi password that the device is providing, or that its MAC address may be on the exception list, not allowing it to connect. Verify that the tablet is using the proper wifi password for the system you are trying to connect to, and that you are using the same wifi security (WEP/WPA/WPA2) on the tablet that the wifi is using.
Oct 04, 2015 | Dragon Touch Touch R10 10.1 Google Android...
What does authentication error mean when I try to connect to my wifi?
You need to input the authentification code which was supplied with your router.
Aug 09, 2015 | Tablets & eReaders
My WiFi is up and running and my other devices can connect but my trio tablet says authentication problem, why can't I connect?
I'd make sure that you have configured the correct wireless security type. If your tablet allows both WPA and WPA2, make sure whatever you selected matches the configuration on your WiFi router. Also, the encryption algorithm has to match - AES is the most common but some older routers only support TKIP.
Feb 13, 2015 | I-INC UniK Trio AXS 3G with Wifi 7.85"...
How do I get wi-fi connection. I have inputted information for the wi-fi it says saved, then when you go to connect it says authentication problem and cannot complete registration.
Hi
To connect to a WiFi system, you may need 3 pieces of information:
A username
A password
An encryption key
Once you have successfully linked to a WiFi access point then your tablet will remember the settings until told to forget them.
A lot of the time you may only need the encryption key, and if the tablet detects a WiFi access point then if you tap on that in wireless settings then it will either connect automatically or ask you for some sort of code - the encryption key. If this is not entered correctly then it will return an authentication problem/error. In order to connect you have to have this code. Also bear n mind that the code may or may not be case sensitive, and that the authentication type for both router and tablet needs to be the same. It is possible that you will only be able to change the authentication type on the Aceess Point / router and not on the tablet.
Cheers
Dec 25, 2014 | Tablets & eReaders
trying dumbing down the authentication on your wifi router. Try these:
turn off 40mhz wide channels
try wpa instead of wpa2
try tkip instead of aes
if all else fails, try wep.
Feb 11, 2014 | Craig CMP741d Tablet
Authentication Problems
wrong settings entered on tablet, try again.If possible connect tablet first via usb cable to computer or router to try connecting it , to determine the actual fault on connections.
Dec 28, 2013 | ZEEPAD New 7 Inch Android 2.2 Tablet Pc...
Wifi connection/ IP address unavailable
I would guess your wifi broke.. but you can always ... try wifi elsewhere to verify... if it works then you need to manually connect to your wifi... I would attempt to get your Ip off the working one and copy the same IP and DNS for your wifi... since it's a tablet I would just reset it to factory settings if it just is stuck... you can back up your files VIA google or BUMP app
Nov 28, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Authentication problem connecting to wifi
Can't get unit to connect to my home wifi , keeps giving message Authentication Problem
May 12, 2012 | Polaroid Tablet Computer PMID701
Machspeed Trio DROID-7C Tablet Logo
202 people viewed this question
Top Machspeed Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
john smith
Sean  Piquet
Sean Piquet
Are you a Machspeed Tablet and eReader Expert? Answer questions, earn points and help others
