Question about A.C.T ATV Tire - 26x8R12
Crack along lug of tire - A.C.T ATV Tire - 26x8R12
    Problem Solver:
  • 8 Answers
If it's an old tire, the crack is probably caused by the rubber drying out and becoming brittle. If it's a new tire, it sounds like a manufacturing defect or road damage.
Posted on Oct 18, 2013
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Instructions on changing front brakes on a 1993 delta88 oldsmobile 1993
Instructions
    • 1Loosen the lugs nuts using the tire iron. Place the wood blocks in front of the tires you will not be removing.
    • 2 Raise the vehicle using the floor jack. Set the jack beneath the support strut that runs along the outer edge of the undercarriage. Raise it enough to allow the tires to clear the ground. Place the jack stands underneath the same strut as the jack.
    • 3 Remove the lugs nuts completely and take the tire off. Set these all aside.
    • 4 Remove the mounting bracket bolts with a socket wrench. The mounting bracket is the metal half-circle that is revealed when you remove the tire. Tie the mounting bracket to the undercarriage with rope to prevent stress damage to the brake line.
    • 5 Remove the brake pads from the bracket by hand.
    • 6 Compress the caliper cylinder with the C-clamp. The caliper cylinder is the 3- to 6-inch wide cylinder in the center of the bracket. Make sure that it is flush with the bracket.
    • 7 Install the new brake pads where the old ones were.
    • 8 Reattach the mounting bracket to the rotor. Reattach the tire and finger-tighten the lug nuts. Lower the vehicle and the tighten all of the nuts with the tire iron.
Apr 08, 2014 | 1989 Oldsmobile Delta 88
How to get tire off when missing tire key
on most lock lugs, a socket can be knocked onto the lug, in other cases use a hammer and a chisel. hit the lug dead center and the lug will crack. if you dont want to ruin the lug, find a tire shop or a place that sells rims and rim accesories
May 24, 2012 | 2000 Lexus RX 300
Just purchased a H1, learning things as i go need to know if there is any tricks to changing tires concerning the CTIS
make sure your ctis selector knob is in the neutral position, and your manual switch if applicable is not engaged for all wheels. crack the center nut at the wheel hub for the ctis with a 3/4 wrench then crack the lug nuts before lifting the truck to disconnect the ctis line completely from the base then take your lug nuts the remainder of the way off. flip the procedure for install. goodluck
Mar 10, 2011 | Wheels, Tires & Parts for Hummer H1
I got a flat tire of my 1999 cherokee limited and it cracked the rim can i use the rim off of a chevy blazer fit on it. the tire number of the cherokee is p245/70
The lug pattern for a blazer is not the same even if tire is the same size. Afew wheel spaecialist can repair you wheel though
Jan 10, 2011 | 1999 Jeep Grand Cherokee
When changing the front tire does the center nut need to be removed along with the lug nuts? if so, how?
Only the four wheel lug nuts need to be removed to get the rim and tire off the car. That large center nut holds in the front axle shaft.
Oct 31, 2010 | 1991 Honda Accord
How do u chage tire on a 2007 bmw 650i
block wheel on opposing side to avoid rolling.loosen lug bolts on wheel using lug wrench. donot completely remove nuts. place jack at designated position on side of car. diagram should be on spare cover in trunk under carpet along with the appropriate tools.raise vehicle with jack just high enough to clear ground. remove nuts and flat tire and replace with spare. tightened lug nuts and lower jack. check nuts again for tightness.
Apr 26, 2010 | 2007 BMW 650i Convertible
Tire will not come off when lug nuts r removed on front right whe
this is a very common problem rim rusts in place just hit it hard with hammer it should come lose
Apr 12, 2010 | 2004 Hyundai Elantra
Need to replace brakepads but have lost the original wheel removal tools
go to a tire store, have them break the "LOCKING" lug nuts.
you would not be able to use that nut w/o a key, but at least you will be able to get the tire off.
Apr 17, 2009 | Buick Park Avenue Cars & Trucks
A.C.T ATV Tire - 26x8R12 Logo
55 people viewed this question
Top Carlisle Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Carlisle Vehicle Part and Accessory Expert? Answer questions, earn points and help others
