Question about Retail Supplies
Ncr register I have an NCR 2113 cash register that is beeping and reading an error code A99. I have found no info on how to clear this error. Any suggestions?
SOURCE: NEED ACTIVATE READ OF CODE 128 IN NCR 7872 SCANNER
Reset
Defaults
Prog.mode
Hex 1
Hex 7
Hex 1
Hex 1
Hex 0
Save & Reset
Posted on Dec 12, 2007
ansari03
SOURCE: NCR 7875 SCANNER/SCALE
Hello
Well regarding this error sending you this display of the scanner in most cases is needed because if the scanner calibration, you have to do is:
Remove the dish from scanner (where you put the products to weigh), there you will see that has a plastic part on the right side, and take away that the bottom is a black button color you need to start to put pressure gauge.
Once you press this button, and is ready to start calibrating, then put him back to the plate and the scanner with a voice that sends you will be asking some weight, so this should have on hand your weights to calibrate the scale.
First the scanner asks 0 kg. in this step not going to put anything in weight, ahi press the button Scale Zero appearing in the panel's scanner,
After asks you to 2.5 kg, is there when you need to put the 2.5 kg asks you, when you have them placed on the plate press Scale Zero, the scanner then will ask now that you put 5kg, then you take away those who had 2.5kg and you put the 5kg, and when you have 5kg in the dish press the button Scale Zero, now the scanner will ask that you put 10k, then take away the 5kg and that he had put the 10k that asks you to press the button and Scale Zero, and finally asks you to the scanner in this 0Kg, then you take away the 10k and leave it with nothing, and press Scale Zero
If the calibration did well Scanner you send a voice message that says Calibration Complet or calbración completed, it is very important that when you calibrating the scanner is not moving or having obstacles that may make the calibration is not made well, good clean plate and that this part of the bottom, which revises the 4 Gomito that has to sustain the plate are complete, that are not broken up or are some more than others and that when you put the dish did not move. fijate also not hit the plate or the chassis of the scanner with something else, so there's no obstacles in the calibration,
If you salio calibration is not well in the display will show a 9Error, this means that there was interference during calibration, it is required to check well before the scanner or do a cleanup.
Posted on Jun 30, 2008
  • 3 Answers
SOURCE: NCR 7875 Scanner/Scale Communication problem with PC
You need another cable (the metrologic cable doesnt work with the same configuration) and set the button in the interface card to rs-232 and program the scanner-scale with the programing tags.
Posted on Dec 05, 2008
  • 3 Answers
SOURCE: error in my cash register
I PUSH THE BOTTOM CLK# COVEN AND DOES NOT WORK
Posted on Jan 17, 2009
SOURCE: Enabling NCR 7875 flatbed scanner to read Code 128 barcodes
On a 7876, you need to scan the sequence “17130” is to add 128 tag readability. Not too sure if the 7875 is the same.
Posted on Feb 20, 2009
How do you clear the error # 3 on the national cash register 2114-1306-7100
I used to work for NCR. An error 3 on a 2114 (any model) means the printer failed to initialize or is jammed or failed. There is a sensor in the printer that sees the printer drum move. If the drum fails to move or is not "seen" to move then an error 3 is indicated. This printer has a high failure rate after about 5 to 10 years of use. No real repair for the printer as the usual cause is the rubber type on the drum starts to fall off. (I read through the other replies and got a good laugh at the "supposed" experts that hang out here.)
Jun 25, 2014 | Retail Supplies
Ncr atm error codes
Contact NCR Support. They should have the answer to this problem. That is a proprietary piece of equipment.
Jul 19, 2013 | Computers & Internet
How to repair ncr 1900 cash register
It is not a 2 day course. Enroll for an electronic course after completing join a cash register fixing company and get exposed to basic technics
Jan 13, 2012 | Retail Supplies
Ncr cash register model 2114 3Err code
error 3 code on model NCR 2114 is a printer error meaning the printer cannot complete a print cycle caused by various issues concerning the condition of the printer
Nov 16, 2011 | Computers & Internet
I have a 7870--2000 NCR scaner and it keeps freezing with the cash rigester?
First determine if the problem is the scanner or the register. Switch scanners with another one, does the problem follow the scanner?
Could be the cable, interface card on teh scanner.
If the problem stays at the register and you tried a new cable, the register is the problem.
Apr 10, 2010 | NCR 7872
Going dim, POS NCR 7452 cash register 9" vga mono.
bcollier696, You did not state how many hours of use this small screen monitor has on it!! You may need to replace the CRT if it has been in use for a long time. Can you approximate the total "ON" time of said unit? Is it >10k hrs. Multiply hrs/day x 300 days x yrs of use. If u come up with 15k hrs or more replace the unit with an LCD if possible.
lmistyrel @ aol.com or louie12fix on fixya
Sep 16, 2009 | NCR Refurbished 9 MONOCHROME VGA MONITOR
I can hear sound of scan but didnot scan
Capital Computer Group
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
Wethernb@capcom-ncr.com
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
Jan 14, 2009 | NCR 7875
NCR 2113 Cash register
i have one if you to get a copy just email me.
birdsky69@yahoo.com
Nov 22, 2007 | Office Equipment & Supplies
Retail Supplies Logo
Top Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Retail Supply Expert? Answer questions, earn points and help others
