I have a 2005 Pontiac Grand Prix .. I took a long trip and used my air circulator at the end of my trip it wouldn't shut off so a friend had a mechanic look at it he detached the blower fan so my battery wouldn't die so now I have no heat, AC or defroster ..Can anyone tell me what my problems is ???
    Genius:
  • Heating & Co... Master
  • 2,415 Answers
-Try to plug it back on. If the problem is gone, you should be okay.
If not and the blower still keep running like before.
-What you need to do:
-Unplug the "Blower Relay" If the blower is OFF then replace the relay.
Sound like the blower's relay stuck at (ON POSITION)
Mai
Posted on Oct 18, 2013
bobicehouse
  • 1524 Answers
SOURCE: Intertherm model MGHA-090-AAPQ -- combustion air keeps running
Sounds like a problem with the circuit board.
Posted on Apr 23, 2009
  • 10 Answers
SOURCE: blower fan wont shut off
Try cycling the switch at the furnace to reset the blower board. If this doesn't work remove the green wire from the blower board(computer board) to eliminate a shorted t-stat or shorted wire between the furance and t-stat. If blower remains on, then blower board is shorted. I've seen all these problems.
Posted on May 04, 2009
co7196
  • 3433 Answers
SOURCE: Dometic AC that the fan shuts off but the compressor keeps running
call dometic dealer. I hear they have a bad circuit board that is replaced.
Posted on Jun 02, 2009
  • 208 Answers
SOURCE: Does this unit draw inside outside air in fan mode?
that's usually controled by a baffle inside or outside air
Posted on Jun 22, 2009
  • 340 Answers
SOURCE: blower fan is not coming on
I recommend you getting service its a safety thing. the humming is the transformer and is normal.. good luck Tom
Posted on Jun 23, 2009
2005 pontiac grand prix gtp flashing engine code slugish
I actually have the same car, and when mine did that it ended up being a cracked spark plug. So I changed the plug and it cracked again. Ended up needing new spark plug wires.
Apr 03, 2014 | 2005 Pontiac Grand Prix
Where is the fuse box located in a 2005 Pontiac grand prix
On this website (link below) you find fuse box diagram and description for Pontiac Grand Prix 2005
Pontiac Grand Prix mk7 Seventh Generation 2005 fuse box diagram Auto Genius
Jan 14, 2013 | 2005 Pontiac Grand Prix
I need a 2005 pontiac grand prix wiper diagram
look under hood or fuse box , best guess is under hood threr will be in cluster with others in main box,switch it out with a knowen good one
in cluster.good luck for great diagrams go to AA1CARS.COM all are free
Oct 29, 2012 | 2005 Pontiac Grand Prix
1994 pontiac grand prix, starts up and runs fine until it warms up, about 4-5 min, then dies and will not start until cool, has new plugs and new fuel filter
the mass air flow sensor will cause this. you can remove it and spray it with electrical cleaner or maf sensor spray. you can buy at any auto parts store. follow directions on can for maf sensor spray. this sensor is very sensitive to dirt and debris. and also make sure air filter is clean and hose from filter is free from dirt.
Oct 18, 2010 | 1994 Pontiac Grand Prix
I have a 2005 pontiac grand prix and i have errer code p0411. Engine light is on what do i do?
P0411 is The Secondary Air Injection system. It is used on cold starts to run fresh air into the exhaust to help fire the cat up.
Look around for a broke hose that goes from the intake system to the exhaust that is controlled by a solenoid.
Their are three phases that will trigger codes your code is phase 1 of the systems operation.
I would take the vehicle to a shop to have this serviced. Or you can ignore the code. Their wont be any detrimental affect other than if you have smog or e-check your car will fail.
Jul 02, 2010 | 2005 Pontiac Grand Prix
Where is the fuel filter on a 2005 pontiac grand prix
On the driver's side under the car in the area of the rear passenger seat is a small silver can with two quick connect barbs and on the other end a threaded connection. This is the fuel filter.
May 21, 2010 | 2005 Pontiac Grand Prix
No heat in car ,new coolant ,new thermostat
Had the same problem and turned out to be that the Heater Core was clogged. Took it to a Radiator shop and they blew the system out to unclog it. Cost was $25.00. 2005 Grand Prix.
Feb 27, 2010 | 2005 Pontiac Grand Prix
2005 Grand Prix heater works fine when blower is off-air coming thru vent gets hot; once blower is turned on air turns cold. Why?
Sounds like a clogged heater core- insufficient coolant circulating through heater core, and as soon as you blow air past the core, it get cooled off.
Jan 09, 2010 | 2005 Pontiac Grand Prix
Car
Transmission, Most likely need to flush it a few times and that should do the trick. My friend had the same problem with his grand prix, 3800 engines are tough but the transmission the grand prix come with blow.
May 03, 2009 | 1999 Pontiac Grand Prix
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
