I have a RCA audio video stereo reciever and it
I have a RCA audio video stereo reciever and it worked fine until one day on the screen says power off and it Shuts off and I've unplugged everything and tried it again and nothing but power off is there a reset I can do please help
SOURCE: "weak signal" on my RCA scenium
Hey! I have the same problem as you. But! this would happen only when I got a power outage. Unplug the TV for a couple of minutesand all was fine. For the last 5 day I have no TV. I have tried everything. All the out on the TV and I still get unusable signal. My rep told me to unplug for 24 Hours. Still didn't work. My menu option work as well and every time I put the TV on, off or if I change the input sound will come on for 2 seconde and stop. If I find the salution I will let you know. Gilles Ottawa
Posted on Apr 12, 2007
  • 11 Answers
SOURCE: htr-5730 yamaha reciever
try another outlet sounds like you may have a short in either your power cord/supply or your outlet is acting up with the wiring
Posted on Apr 30, 2008
SOURCE: Rca Big screen shut down and now no power
NO audio and no picture .... no power to on - off button. Checked outlet and it is good .... cable connection good - checked with another tv....
Posted on May 15, 2008
SOURCE: No S-Video nor RCA Video output to monitor
First, you've checked and the monitor will display other sources plugged into the same monitor input?  And you've tried plugging the receiver into another TV?  Otherwise all I can tell you is that the receiver does not convert.  So if you want to see S-Video on your monitor, you have to input S-video.  If you want to see RCA output, you have to input RCA.  Best of luck.
Posted on Sep 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA HD52W69D projection tv powers up for second green light
try replacing CP150 on the deflection board
Posted on Mar 15, 2009
Just recieved a rca maven tablet. touch screen option worked fora day. now touchscreen option inop
It may be just locked up. Hold the power button until it shuts down, restart it and see if it works. If this doesn't work, return to place of purchase, you have only had it for 1 day.
Jan 28, 2017 | Tablets & eReaders
I have an RCA STA 3900 stereo reciever that wont turn on. Standby light is on. Tried resetting it from the back but didnt work. Please advise
A standby condition can mean a fault in the receiver. voltages in the system are off. This can either be a bad diode or power transistor.
Aug 24, 2014 | RCA Sta-3900 Stereo Receiver
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
When I sit down to watch a movie my system sound shuts off after 3 min. I get up and wiggle the svideo cable and the sub powers back on and is ok for another 3 min or so. it repeats the same chacteristics...
The cord you are wiggling is not an S-video cable, it is a Mini DIN 8 connector. Both S-Video and Mini DIN 8 are the same type of connector, (DIN) except the S-video is a Mini DIN 4.
I'm not sure exactly what the problem is, perhaps you could enlighten me with some more info? Have you changed any audio settings in the menu lately?
First, try unplugging your sub from the power for 30 secs. Then plug back in.
Then unplug one speaker (doesn't matter which one but keep track of what you've unplugged) from the sub, wait the 3 mins and see if it shuts of again. If it shuts off again then plug your speaker back in and repeat this step with another speaker, until you've found the culprit, or run out of speakers.
Let me know what you find.
Nov 11, 2012 | JVC TH-M606 System
Just bought the LG ht305su dvd reciever system i set it all up but cannot get sound from the tv only when i play a dvd or cd it works can anybody help?
you need to run a pair of rca cables from the tv's stereo audio out (if it has one) to the auxilliary stereo inputs of the LG reciever.
Nov 30, 2010 | Audio Players & Recorders
Power
Audio amplifier IC damaged need to be replaced
Apr 23, 2010 | Yamaha HTR-5730 Receiver
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
Amp protection mode
Disconnect everything from the amp except the power cord, then power on the amp. If the receiver still shuts down, your problem is inside the case and unless you can perform electronic repair yourself you will probably need to take it in for service. If it does not shut down with nothing connected, power it off, connect one speaker or component and power on again. Repeat the process until the amp shuts down and you may have found the bad speaker or other component.
Jan 01, 2009 | Onkyo TX-SR503 Receiver
Sony a/v reciever not sending video to tv.....
I don´t know if I´ve understood, but the best way to "pass" video signals to TV through receivers is using a stereo VCR, where you plug in any antenna. Then you connect VCR´s audio and video channels to the receiver. Turning on all equipment, select video1 source. You will hear sound through the system and watch video signal on TV. Hope this may help.
May 22, 2008 | Sony A/V Receiver
Immediately shuts off when turn on.
get another speaher wire two wires are touching making ti go into protect mode..
Jan 15, 2007 | Onkyo HT510 Receiver
120 people viewed this question
 Grubhead
Grubhead
