Question about LG LP123CD3A Air Conditioner
Lg ch 02 - LG LP123CD3A Air Conditioner
    Genius:
  • LG Master
  • 2,492 Answers
-What's problem...? Too cold...? Not cold...? Not working...?
-You need to tell us more specific problem. So we can help you.
mai
Posted on Oct 18, 2013
CH 02 error code
Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5 kOhm at 25C. If not replace sensor.
Jan 16, 2016 | LG LP1200DXR Portable Air Conditioner
Its giving an error code CH 02
You have to try resetting the system. First turn the breaker off for the condenser and wait about 20 seconds. After you turn it back on the system should reset Air Conditioning Tamarac
Error code CH 02. Since this LG model has been discontinued I am looking to repair if possible. Thermistor error but which one and can I just order a new one and simply unplug the old and plug in the new?...
Very easy to replace, just make sure power is off and wait 10 mins for capacitors to discharge then swap over thermistor and power up.
Mar 15, 2015 | LG LMN125HVT Air Conditioner
https://www.youtube.com/watch?v=jkZWwXUVh7A
Could not trace your model number or the error code quoted.
On an old machine it would be better to replace all thermistors while you are at it.
The video link will give you an idea of how to go about it.
Mar 15, 2015 | LG Washing Machines
LG Inverter Air Conditioner showing CH 02 what can I do?
CH-02 Indoor Pipe Sensor or Outdoor Sensor Assy fault, Open or Short. Disconnect from PCB and measure resistance. Air sensor = 10 kOhm at 25C, Pipe sensor = 5
Dec 27, 2010 | Heating & Cooling
Please indentify trouble code CH-02
Hello, this is a fault with a thermistor (sensor) that either the sensor is bad or the wiring to it. The code lists it as either "open" or "short" see here - http://www.abacusairconditioning.co.uk/lg%20split%20codes.pdf
May 13, 2010 | LG LA245HV Split System Air Conditioner
The model number would be on the right hand side of the outdoor unit and same on the indoor unit if it is a midwall split. If it is a flat cassette cieling type you may need to open the grill, which is simply two little levers either side of the grill, and the grill will swing open. Without the model number it is difficult to give accurate info. However, I can offer the following. One, check the condensate drain. You can just blow into the drain pipe from the outside and this sometimes clears clogged mud in the drainpan. Or two, error reading can also come from phase failure (in the case of a three phase unit) or power related problem. This can be solved by switching off the mains and then switching on again to reset. If you have a phase failure you would need an electrician to confirm that the power supply is good. Unless you have a volt meter.
Mar 02, 2009 | Heating & Cooling
LG LP123CD3A Air Conditioner Logo
167 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
