Question about Weedeater Featherlite Blower 18 Cc 150 Mph 300 Cfm Model No Fl1500 Reconditioned
Carburetor how to take carburetor off
Carburater replacement
  • Why do you need a new one?
  • Details in the main link for cleaning and replacing.
  • Carburetor replacement parts for 2006 Kawasaki KFX50 ... www.2wheelpros.com/oem-parts/2006-kawasaki-kfx50-ksf50-a6f... Original 2006 Kawasaki KFX50 (KSF50-A6F) Parts. Search Carburetor parts using manufacturer microfiche assembly diagrams.
  • 2006 Kawasaki KFX50 KSF50A CARBURETOR Parts, 2006 Kawasaki ... www.bikebandit.com/oem-parts/2006-kawasaki-kfx50-ksf50a-carburetor/... 2006 Kawasaki KFX50 KSF50A CARBURETOR Parts at BikeBandit.com. The Web's most trusted source for 2006 Kawasaki KFX50 KSF50A CARBURETOR OEM Parts.
  • 2008 Kawasaki KFX50 (KSF50-B8F) - CARBURETOR ... - ... www.2wheelpros.com/oem-parts/2008-kawasaki-kfx50-ksf50-b8f... 2008 kawasaki kfx50 (ksf50-b8f) - carburetor ... 2008 ksf50b8f (932) schnee white; air cleaner; battery; belt converter; carburetor(b8f/b9f) chassis electrical equipment;
  • Kawasaki ATV Parts 2006 KSF50A6F KFX50 CARBURETOR Diagram www.partzilla.com > Kawasaki Parts > Kawasaki ATV Parts Search for Kawasaki ATV Parts 2006 ... Parts / Kawasaki ATV Parts / 2006 / KSF50A6F KFX50 Kawasaki ATV Parts 2006 KSF50A6F KFX50 CARBURETOR Diagram ...
  • 2008 Kawasaki KFX50 (KSF50B8F) Carburetor(B8F/B9F ... www.kawasakipartshouse.com/oemparts/a/kaw/500b50d3f8700223e47963d1/... Shop our large selection of 2008 Kawasaki KFX50 (KSF50B8F) Carburetor ... Kawasaki; ATV; 2008; ... or any Replacement Parts! Kawasaki Parts House is ...
  • Kawasaki KFX50 KFX 50 Carburetor Carb 15003-S004 Fuel Gas ... www.amazon.com > ... > Parts > Fuel System > Carburetors Kawasaki KFX50 KFX 50 Carburetor Carb 15003-S004 Fuel Gas 2003-2006 New OEM
  • Kawasaki ATV Mini KSF KXF 50 Carb Carburetor Used Parts ' ... www.ebay.com/sch/sis.html?_nkw=Kawasaki+ATV+Mini+KSF+KXF+50+Carb... Find best value and selection for your Kawasaki ATV Mini KSF KXF 50 Carb Carburetor ... Kit Carb Repair KFS 50 KFX ... 2006 Kawasaki KFX KSF 80 Carburetor ...
  • 2006 kawasaki carburetor ' eBay www.ebay.com > Search > 2006 kawasaki carburetor Refine your search for 2006 kawasaki carburetor. Refine. more Format ... Kawasaki KFX 400, 2003-2006, Carb / Carburetor Repair Kit - KFX400 ... $34.50. List price: ...
  • Go to Bing homepage
    Jul 09, 2016 | kawasaki 2006 KFX 50
    Runs but will not carry a heavy load eng boggs down with load and voltage drops
    The engine isn't getting enough fuel. Your carburetor needs cleaning. Generators are notorious for gummed carburetors because of the ethanol alcohol in today's gasoline and the generator sitting idle for weeks, months & even years without use wicks moisture into the fuel. Drain your carburetor of gasoline, & remove the carburetor. Clean your carburetor with Carburetor Cleaner spray & make sure the float needle valve & seat are clear of gum & varnish. To help prevent this from happening again, shut off the fuel petcock at the fuel tank and run the generator carburetor out of fuel before you put it away. It'll help keep the carburetor free of gunk. Also, replace the old fuel in the tank with fresh fuel every 3-6 months.
    Mar 06, 2016 | Electrical Supplies
    Could some help me with factory carb settings on this saw
    Adjustment and Tuning of a Chainsaw Carburetor ' Chainsawr
    store.chainsawr.com/.../tuning.../1126042-adjustment-and-tuning-of-a-c...
    Carburetor Adjustment for Chainsaws Carburetor adjustment is critical on chain saws ... These saws have what is called a "fixed jet" which is set from the factory.
    Stihl Chainsaw Carburetor Adjustment - Tune-up Settings
    tekindoor.com > MISC
    Stihl chainsaw's have three carburetor adjustment screws (LA) Idle Speed screw - This ... When the engine is tested at the factory the carburetor is set to obtain a ...
    How to Adjust the Air and Fuel on a Stihl Chainsaw ' Home ...
    homeguides.sfgate.com > ... > Adjustable Mortgage Rates
    The fuel/air mixture in any gasoline-powered engine is regulated by the carburetor, and the carburetor in a Stihl chainsaw is factory-adjusted to provide the best performance.... You'll find three adjustment screws for the carburetor, usually located under the air filter cover.
    Factory carb setting on Craftsman 2.0 or Poulan Micro ' Firewood
    Dec 04, 2015 | Garden
    Fuel leaking out of 2 hoses connected to the carb cant stop the fuel leak
    Inspect the fuel inlet hose closely. If you notice a wet spot around the hose where it joins the carburetor fitting, or the hose has become swollen, soft, brittle or hard, replace the fuel hose and the small fuel filter inside the carburetor fitting. Install a new worm clamp to tighten the new fuel hose to the fitting. Use a Phillips screwdriver.
    Check for a fuel leak around the accelerator-pump cover assembly. Some carburetor models come equipped with a diaphragm-accelerator pump on the side of the unit. If the cover screws have come loose, fuel will leak through the diaphragm and external cover. Look for a square cover on the side of the carburetor and tighten the cover mounting screws at each corner with a Phillips screwdriver.
    Look around the gasket located between the carburetor upper body and the main, or lower body. This gasket may have worn out or the carburetor upper body mounting screws may have become loose, allowing fuel to leak outside the carburetor.
    Ensure the upper body mounting screws are tight, if you found a leak. If they are tight, remove the clip holding the throttle linkage to the carburetor with a pair of needle-nose pliers and reposition the linkage to the side. The linkage allows the driver to operate the throttle plates in the carburetor through a cable when depressing the accelerator pedal. Unfasten the screws holding the carburetor upper body from the main body with a ratchet, short ratchet extension and socket. Remove the old gasket and install a new one.
    Inspect around the bottom of the carburetor where it joins the intake manifold if no leaks were found around the gasket located between the carburetor upper body and the main, or lower body. If you find a wet spots or marks around the bottom of the carburetor, the base plate gasket is leaking. Remove the upper and main carburetor body using a ratchet, short ratchet extension and socket. Install a new base gasket and replace the carburetor assembly.
    Jan 21, 2012 | 2009 CCM RL 125
    Oil runs out air filter
    If you have a fuel/oil mixture running out of the air filter, it is most likely you will need to service the carburetor. Today's modern fuels will, over time, gum up the carburetors and small passage-ways within the carburetor making the carburetor ineffective. A carburetor rebuild kit can be a DIY project. Mantis has a very good customer service department that can locate your correct parts and send them inexpensively. The needle within the carburetor (behind the 4-screw plate on the carburetor) is likely not seating properly and the fuel is flowing through the carburetor and out the filter. Thanks!
    Sep 25, 2010 | Mantis 2-Cycle Tiller
    The car periodically stalls out
    1 Inspect Carburetor Dirty and Improperly Functioning Carburetor. 2 Inspect Carburetor Incorrect Carburetor Adjustment. 3 Inspect Carburetor Worn, Faulty or Damaged Carburetor.
    May 22, 2010 | 1993 Buick Regal
    When i accelerate there is hesitation and jerking? Once at a certain speed there is no jerking but if you slow down and then accelerate again it jerks/hesitates again.
    It means there is a problem in the carburetor of your car . But if then so you still have to check the accelerator springs and pedal. For there are worn out or destroyed parts then replace them for good .About the carburetor.Prepare the equipment or tools to be used in servicing the carburetor .So that when carburetor will be repaired or serviced no parts will be damage or lost. Locate the carburetor. Disconnect the fuel lines , the accelerator cable and the magnetic jet from the carburetor.Dis -assemble the carburetor.Clean carburetor with carburetor cleaner.Don't forget to observe safety rules. If there are worn out parts or destroyed parts then replace them .But you the owner don't have time to do the job then go to a car shop mechanic and let them do the job.
    Oct 19, 2009 | 1994 Dodge Intrepid
    Toyota 3c low acceleration and lack power
    the owner of the car should check on the carburetor of the car .The owner of the car should be able to service carburetor.Prepare the equipment or tools in servicing the carburetor .So that when the carburetor will be repaired or service no parts will be damage or lost. Locate the carburetor ,disconnect fuel lines accelerator cable and magnetic jet from the carburetor, Dis-assemble the carburetor ,clean the carburetor with carburetor cleaner, observe safety measures. but if the owner of the car don't have time in servicing the carburetor. then owner of the car is advice to go to a car shop mechanic and let the car mechanic to do the job.
    Sep 30, 2009 | 1994 Toyota Previa
    I have a John Deere Riding lawn mower which starts
    Hello roobar2009:
    >>From your Description it Sounds like a Carburetor Problem, a Bad Fuel Filter or Bad Gas.
    >>If you have Changed the Filter and the Gas and the Problem is Still happening, then
    >>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
    >>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
    >>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
    >>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
    >>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
    >>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
    >>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve.
    Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
    >>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace is the Needle Valve.
    >>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
    >>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
    >>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
    >>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
    >>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
    >>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
    >>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
    >>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
    >>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
    >>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
    >>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
    >>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
    >>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
    >>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
    >>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
    >>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
    >>2- http://www.cpdonline.com/692509.pdf .
    Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
    Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
    Good Luck
    Respectfully
    jbridger (John)
    May 17, 2009 | Garden
    Weedeater Featherlite Blower 18 Cc 150 Mph 300 Cfm Model No Fl1500 Reconditioned Logo
    Top Weedeater Garden Experts
    Jim Parker
    Jim Parker
    Matt Olenzek
    Matt Olenzek
    ray gallant
    Are you a Weedeater Garden Expert? Answer questions, earn points and help others
