Question about Emerson Televison & Video
Tv sleep mode
Sleep mode is set at 90 minutes. How do I change?
    Top Expert:
  • Emerson Master
  • 74,383 Answers
Download the user manual to your set by internet. It has all details. Try this link to download it. www.retrevo.com
Posted on Oct 19, 2013
How do you get a Westinghouse 50 inch TV out of sleep mode
Go to sleep timer in menu and hit button until it goes from max sleep (i.e. 90 minutes) down to 0 minutes or off.
Jul 07, 2016 | Westinghouse Televison & Video
How do i change sleep mode
Sleep Timer Mode
The Sleep Timer mode is an energy-saving feature that enables you to set a time for the monitor to
power on and off at the same time every day. This also extends the life of the backlight bulbs in the
monitor. The Sleep Timer has five settings:
? Set Current Time
? Set Sleep Time
? Set On Time
? Timer: On/Off
? Sleep Now
To set the timer:
1. Press the Menu button on the monitor front panel to display the OSD Menu.
2. Scroll down and highlight Management.
3. Press the OK button to select Management.
4. Scroll down and highlight and select Sleep Timer > Set Current Time.
NOTE: You must set the current local time before you reset the time for Sleep Time or On Time. Note that the time is displayed in a 24-hour clock format. For example, 1:15 p.m. is displayed as 13 hours 15 minutes. A power failure or loss of power to the monitor will cause the timer to reset to 00:00. If this occurs, you will need to reset the sleep timer mode.
5. Press the OK button once to enter the adjustment mode for hours.
6. Press the - (Minus) or + (Plus) button to adjust the hour.
7. Press the OK button again to enter the time for minutes.
8. Press the - (Minus) or + (Plus) button to adjust the minutes.
9. Press the OK button to lock in the time chosen.
10. After setting the current time, the highlight automatically skips to Set Sleep Time. Repeat steps 6 through 9 to set Sleep Time.
11. If you do not want to set Sleep Time, press the OK button twice, then select Save and Return to exit the menu.
12. After setting Sleep Time, the highlight automatically skips to Set On Time. Repeat steps 6 through 9 to set On Time.
13. Set the Timer mode to On to activate the Sleep Timer settings.
14. When you are finished, select Save and Return to exit the menu.
The fifth selection, Sleep Now, turns the monitor backlights off immediately and stays in sleep mode
until the next On Time activates or a monitor button is pressed.
May 27, 2014 | HP Pavilion 22bw Black 21.5" LED Monitor...
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
Phillips lcd 32 inch(PFL-3403) tv picture is going off after 10- to 15 minutes of working since 26.01.2011.
Check whether timer is ON mode or OFF. If it is ON set it to OFF mode.
Check whether sleep after 15 mins is after
set it to NEVER or OFF mode(sleep means if you won't change any channel or iuf you din't did any thing for 10 it will goes to sleep mode..... and again you have to turn it ON)
Thank you
Jan 27, 2011 | Philips Televison & Video
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
Dec 22, 2010 | JVC AV-36F702 36" TV
We have a Sony Trinitron Color TV that seem to be in a sleep mode and we can't turn it on. Would you know what the problem is?
Hello
Press the "Sleep" button on your Sony's remote control hanset until the TV displays the time in minutes [ 15,30,45,60 or 90] that you want the the TV to remain "on" before shutting "Off" automatically. Cancel by pressing until "Sleep Off" appears. The logo also will go out from the screen.
You just do this after unpluging the TV from AC wall socker for about 10 minutes or so, and then plug it.
Nov 13, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Can you change the energy saver adjustment
yep!
you can change it. actually it is on user's settings
it is located under general settings key operator mode.
just scroll down for energy saving
mostly the default value is sleep mode. after you press the sleep mode, the it will ask you for the sleep time you want. just press a number ( each number corresponds to number of minute)
that's it
Apr 02, 2010 | Panasonic Office Equipment & Supplies
Why does my philips turn off when i use it as a monitor?
Probably you're using your tv as a computer monitor via vga input. just click on start,control panel, power option and select NEVER
Jun 20, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
This TV has a sleep mode
There are two ways to solve this, but both will require using the original remote for the Magnavox. The original remote has a SLEEP button - press it until the screen says Sleep DISABLED or Sleep OFF.
Or make sure the TV is in TV mode, and Press Menu --> TV Steup --> Sleep Timer --> change to DISABLED
-Tha Mp3 Doctor
Feb 20, 2009 | Philips Magnavox 15MF400T 15 in. LCD...
Televison & Video Logo
20 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
