Question about Air Purifiers
Rainforest air purifier RF2 - professional model RF-2pro/3500 How do I clean dust from inside purifer
SOURCE: Can't clean Ionic Pro CA-500 inside?
This unit is a pain in the @$$ to disassemble but it CAN be done. The way I always look at it: Someone ASSEMBLED it.
Remove the four screws on the bottom stand followed by two screws on the bottom side of the unit. Then remove the tiny little screws up each side that hold the grill together (you will need a precision screwdriver).
Carefully pull apart- don't force it.
One half comes off (clean that half) in bathtub. The other half does not come off-vacuum that half out and use q-tips.
When re-assembling, watch for two things: First the wire cleaner (that slides) runs on a track on each half- pull it out a little to best allow for fitting. Second, there are little tabs at the top that fit under the control panel-watch for those.
email me at originalpairadice@yahoo.com if any problems.
Posted on Dec 23, 2007
  • 19 Answers
SOURCE: Oreck XL® Professional
clean your cell. Allso check for broken or loose tungsten wires in cell.
Posted on Feb 22, 2008
  • 10865 Answers
SOURCE: need to reset Holmes Air Purifier HAP726
click on this link and get the service manual or info u need
http://www.holmesproducts.com/CustomerService.aspx
Posted on Apr 18, 2009
  • 3 Answers
SOURCE: Cleaning the top of the oreck air purifier
what i normally do, is i take off the top of the and remove the filter, the metal dust catcher, and the back filter... i was the 2 filters and rub them down. then with the metal dust catcher i take a butter knife. wrap it in a clorox wipe (making sure that no metal is exposed to scratch) then i feed it through the metal dust catcher one at a time to clean it. It took me 5 wipes to clean the whole thing. when the wipe comes out black then i rotate it. As for the top of the machine. there are 2 screws that i removed to get to the fan. when they were out i used a can of air (like you would clean a computer with) and blew out the fan... it took care of all noise and it runs just like the day i got it.
Posted on Oct 13, 2009
  • 102366 Answers
SOURCE: how to open and clean oreck xl air purifier
You can download teh manual at
http://www.oreck.com/PUG/3323-8889-Rev-K-AIR8.pdf
Posted on May 03, 2011
Why is my Oreck XL is my air purifier arcing?
If it was just clean recently, it's probably picking up dust particles and that's what you hear or see arching, like a bug zapper.And conversely, if it has been cleaned recently, dust particles on the filter are breaking off and getting zapped. In which case, you need to clean the filter.
Thanks for choosing FixYa.
Aug 25, 2011 | Oreck XL Professional Air Purifier
Oreck XL air purifier (Tower Model)
Is this purifier wet at all, or been in any heavy areas of moisture. This purifier is very undependable with moisture. It may just have to dry out. Let me know if this solves your problem or we can explore further options.
Please keep me updated, thanks
Apr 13, 2008 | Oreck XL Professional Air Purifier
Can purifer work without the ozone card working
It will operate without a purification plate, as long as you are running in RCI mode or normal mode. If you normally run the purifier with some ozone output, then you will need a purification plate. Hope this helps you.
Feb 21, 2011 | Ecoquest Fresh Air Air Purifier
Do I soak the rci target plate in ammonia with the purification plate?
No, just rinse the RCI target with warm water. Allow it as well as the purification plate to dry completely before reinstalling into the purifier. You can speed up the drying process using a hair dryer at a low heat setting. Hope this helps you.
Feb 11, 2011 | Ecoquest Fresh Air Air Purifier
MyFresh Air Air Purifer is not working. About 1 year ago I accidentaly put a staple through the power cord to the purifer and it stopped working. I have had it in storage but would like to start using it...
You can use any standard computer power cord for this purifier. If the damage is closer to the plug side of the cord, you could cut the plug end off and put on a new replacement plug. You should be able to find a replacement cord or plug at a hardware store. Hope this helps you.
Jan 20, 2011 | Ecoquest Fresh Air Air Purifier
How often shoule you clean/change the plate? how do you clean it?
You should clean the purification plate once a month. Using a 1 part water and 1 part amonia solution, dip an old toothbrush into the solution and scrub the metal grids on the plate to remove any dirt or deposits on the grids. Remember to do both sides of the plate. After the grids have been scrubbed, rinse with warm tap water and allow it to dry completely or use a hair dryer to speed up the drying time.
It would be a good idea to scrub the metal contacts that touch the plates inside the purifier as well. The plates should be changed if they develop a crack or there is noticeable arcing when the purifier is running. Hope this helps you.
Dec 09, 2010 | Alpine Air XL-15 Air Purifier
Will the Breeze AT help with the house hold dust kicked up by 2 St. Bernards etc. Also, can I clean the filter myself?
It should help to reduce the amount of air borne dust in your home. The filter can be cleaned either by vacuuming the lint screen or removing it and washing it with hot water and using a toothbrush to remove any dust buildup. Clean the purification plate with a 50/50 solution of water and amonia and a toothbrust to clean the grids. Allow both to dry completely before reinstalling. Make sure that the lint filter has the clip depressing the safety switch when reinstalling it. Hope this helps you.
Oct 27, 2010 | Ecoquest Breeze AT Living Air Purifier
I want to take my ecoquest fresh air apart to clean it, but do not know how, i have misplaced the manual
Unplug the machine and unscrew the phillips head screw on the back grill of the machine, that is just above the plug. There are depressions on the sides of the back grill that has a plastic tang that hold the back grill to the machine. Press the back grill inwards to allow the tangs to clear the sidee and the back grill should now be easily removed. Remove the two thumb screws on the top corners to remove the filter. Once the filter is removed, then you can remove the purification plate and remove the two screws that hold the RCI cell. The RCI cell and filter can be cleaned by vacumming out the dust and dirt.
The purification plate can be cleaned with a old toothbrush and a water and amonia solution. Scrub the metal grid with the toothbrush. Do both sides and then rinse with water, allow it to dry completely before reinstalling the plate. After every part is cleaned reassemble the purifier, and plug it in. Then press the reset reminder button on the front of the keypad to clear the "perform cleaning" message. This message will appear again after the purifier runs for 30 days to remind you to clean the purifier. Hope this helps you.
Oct 09, 2010 | Ecoquest Fresh Air Air Purifier
What is the problem when it needs cleaning pretty often?
If you are referring to the "Perform Cleaning" message on the machine. There is nothing wrong with your machine. It is a feature of the machine to display this message after 30 days of continous use. After you have cleaned the grille, purification plate and vacummed the RCI cell, press the reminder reset button to clear the "Perform Cleaning" message.
Oct 05, 2010 | Ecoquest Fresh Air Air Purifier
I own an Ionic Air purifer. A wire (like a
Yes, must be replaced with same gauge wire(same thickness), good luck.
Mar 02, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Air Purifiers Logo
115 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
