Question about Dyson DC31 Bagless Handheld Vacuum
How do I gain access to the trigger switch contacts? I have removed the one visual screw but still cannot get the cover off.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 47 Answers
If your sure that it's the ONLY screw, then try to gently apply pressure to between the two sides (that were held together by the screw) with a flat-edged screwdriver. be very careful trying to separate the two side, as you can break the plastic.
Posted on Oct 19, 2013
If my sprayer is plugged lint? cat hair?then how do I unplug it? I still haven't figured out how the squeeze trigger works. Can't see how it can contact the sprayer.
There is a clear cover over the suction head that is held on with 2 screws. Remove the screws with a philips screw driver and the cover will remove providing access for cleaning. Refer to your owners manual which provides this info with a photo I think. Reinstall in the reverse manner. Be careful not to over tighten the screws as you could strip the threads. So to reassemble do not use an electric screw driver or drill type screw drive.
Jun 10, 2016 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to remove CLOG Riccar RAD.7 vacuum?
There is a clean out port on the back on the lower portion. Remove two screws to remove the cover to gain access to the air path from the floor to the bag. If this doesn't solve it you may have to remove the screws on the bottom which allow you to remove the cover of the nozzle assembly. There is a cover that goes from the floor to the direct air motor. Remove the screws to remove this cover which gains access to the air path and fan of the direct air motor. It's possible you may need to remove the direct air motor to clean out the fan if it has something stuck in there. This is not a job for the average person but if you are very mechanical you should be able to do it. If in doubt take it to your dealer. It is not very expensive to have done.
Apr 22, 2016 | Riccar Radiance Upright Vacuum Cleaner...
Remove hoover vacuum fan
I don't know what model you have but on most vacuums you need to remove the nozzle housing from the vacuum, remove the cover over the motor to gain access to the motor. Remove any screws holding the motor in. Remove the motor and take the screws out to allow access to the fan. Remove the fan, replace and put back together exactly as it was before.
Nov 09, 2015 | Hoover Vacuums
How do u fix the on off button on dyson vacuum it will not stay on
Remove the wand to gain access to the screws you will need to remove and the tabs to release the cover holding the switch. Pull the cover off to remove and replace the switch.
Feb 21, 2015 | Dyson DC25 All Floors Bagless Upright...
How do you remove dyson dc04 absolute start switch
The switch is in a cover held on by screws and tabs. Remove the hose and wand to gain access to the screws and tabs. After removing the screws, push on the tabs to release them and the cover will come off the front of the machine. Be very careful removing parts so you will know how to put them back together.
Jul 10, 2014 | Dyson DCO7 Animal Bagless Upright Cyclonic...
The switch will not turn the vaccum off or on
The switch is activated by the lever you push in the handle. Start by tightening the screw holding the handle in. If that doesn't solve it remove the bag door and the screws holding the cover above the bag to gain access to the switch compartment. If you can't figure it out in there take it to your Riccar dealer
Feb 17, 2014 | Riccar 8955 Upright Vacuum
Riccar 8955 power cord replacement
Remove the dust compartment door to gain access to the cover over the wiring and switch compartment. Remove three screws to gain access to be able to remove the old power cord and slide it through the hole in the back of the vacuum. Put new cord through the hole and wire back up as it was before.
Feb 14, 2014 | Riccar 8955 Upright Vacuum
Hoover empower belt need replace
To gain access to the belt: remove 2 screws at the top rear cover, next remove 2 screws at the bottom front cover. This will allow the cover to be removed. Then remove 3 or 4 screws that hold the roller in place (from the top). you will be able to see the belt and replace it.
Apr 18, 2010 | Vacuums
Panasonic Vacuum MC-E450UK
Panasonic MC-E 450UK upright vacuum cleaner.
Just had this problem myself...........easy to get at it when you know how.
Panasonic UK wouldn't help me so I spent some time working it out..........here it is.
Remove the hose from its mounting storage at the rear (called hose clip) where the main body of the vacuum cleaner meets the base of the handle assembly. Remove the screw at the rear of the handle assembly which is behind where the hose 'was' situated and is located inside the deep recess.
Using the soft part of your clenched hand as a hammer, knock the base of the handle assembly at the front and it will slide backwards off the main body of the vacuum cleaner. Don't be scared, give it a thump and keep moving it backwards with a few more knocks.
Next remove the two screws at the front which hold the mains cable and on/off switch cover in place.
Finally looking from the rear once more, lift the plastic 'lug' at the top of the cover and which is part of the cover. This will now allow you to release the cover and pull it forward.
There you go! Told you it was easy!
Watch out for the funny little spring at the front behind the cover in the tiny plastic tube where it connects to the small rubber tubing as it could possibly try to escape.
You now have complete access in order to cut the intermittent part of the cable out and remove it from the 'choc' block.
Happy fixing!!
Jack.
Apr 07, 2008 | Vacuums
Dyson DC31 Bagless Handheld Vacuum Logo
158 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
