Question about Microwave Ovens
Error code flashed across screen either E13 or E12 then it quit heating.
    Scholar:
  • 178 Answers
What make and model??
Posted on Oct 28, 2013
My microwave oven quit heating . No error message or any other problem. all buttons work fine just no heat
If it has a turntable that does move it usually means one of three things bad:
1. A diode many use for power purposes for the heating.
2. A circuit board called an inverter that powers the heating and controls the Magnetron.
3. A Magnetron which does the actual heating.
12_11_2012_3_08_28_pm.jpgTypical diode which cannot read shorted or open across.
12_11_2012_3_10_09_pm.jpgTypical Magnetron which usually cannot be tested by normal means but has to be replaced to know if good or bad.
Dec 11, 2012 | Kenmore Microwave Ovens
F1 trouble code is flashing and BEEPING how do i get it to Quit
You can pull the AC plug and leave it overnight; the error may be only a momentary glitch.
If the problem persists, you may find it less costly to replace it instead of sending it for repair.
BTW, that F1 could mean different things on different units. You gave us neither the brand nor the model number.
Oct 24, 2010 | Microwave Ovens
F9 error on screen and microwave won't heat
Hello :
The F-9 error code indicates a defective control board, inverter or line voltage too high.
good luck .
please rate !
Mar 31, 2010 | Kenmore 60654 Microwave Oven
Panasonic Microwave SD697S quit cooking and has
HI, this will require the skilled hands of a qualified Panasonic tech. The damaged part here is the Magnetron assembly. this is a very sensitive part that creates radiation and the heating process as well. you will need to replace this device asap if possible...
thank u
rate me!!!
Jul 28, 2009 | Panasonic Microwave Ovens
Samsung SMH 8165 ST E13 Error message. Oven
I own the same Microwave and it just gave me the same error code E-13. I was heating a large plastic coffee mug of cold water using the "beverage" control. The only thing out of the ordinary was I used very cold water from the Fridge. Maybe this had something to do with the Max time error. Hopefully this was a one off error.
Jun 24, 2009 | Samsung Microwave Ovens
Code F6, E0, "Communication Error"
Hi. this code represents a key pad or control board malfunction. you will have to make sure the key pad or control panel connectors are connected tightly and securely. If the wires and connectors are secure, the actual control board may be faulty and you will need to replace it at this point.
Mar 01, 2009 | KitchenAid Microwave Convection Oven
Panasonic Microwave
the error code H98 refers to the heating filament on the magnetron, unless you are confident I would not progress further
Feb 18, 2009 | Microwave Ovens
Microwave Oven Model MMV5207BA/BC
E13 is usually a bad door switch or door switch mount.
The first step is to unplug it from the power outlet for one minute, then plug it back in and try it again.
If it still fails to heat, I would check the door switches and door switch mounts.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Maytag Microwave Ovens
On a Jenn-Air Microwave Oven Model JMV8166BA what is an error code E12 indicate?
E12 normally indicates a door switch problem. It can be a bad switch or switch mount.
Sometimes it's bogus and you can clear the code by unplugging the oven for a few minutes then resetting the clock.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please write back with more details if you need further help.
Jun 04, 2008 | Maytag Microwave Ovens
Microwave Ovens Logo
138 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
