How to upgrade fujitsu U820 memory to 2GB? Where
How to upgrade fujitsu U820 memory to 2GB? Where is located in the laptop? Is soldered or just memory stick? Thanks Bob
  • 556 Answers
SOURCE: compaq presario c714nr upgrade memory too 2gb laptop
http://h10032.www1.hp.com/ctg/Manual/c01301275.pdf
Page 43 of this manual seems to have the best documentation on memory for this machine. I saw a 2GB max in another document and this shows the biggest module as 1GB. I would believe that infers a pair.
Posted on Dec 18, 2007
mumma_1
  • 903 Answers
SOURCE: Acer Aspire 3690-2970 Memory Upgrade
Don't try to load both sticks, your computer will not recognise anything more than the maximum allowed. And could cause problems on your laptop. Take out your 512mb stick and install the 2gb stick on its own.
I hopet his helps
Posted on Nov 16, 2008
JSGRepair
  • 130 Answers
SOURCE: Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to Newegg.com
Have a nice day!
Posted on Dec 22, 2008
jonniewalker
  • 1029 Answers
SOURCE: Memory upgrade for Acer Aspire 3680
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot so you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance How much memory your Windows OS will recognize depends on which version of Windows you are running. 32-bit versions of Windows will see (and utilize) only 3GB or 3.5GB. To utilize more memory, install a 64-bit version of your OS hope this helps pls appreciate by rating as fixyaa.thanks and Godbless.
Posted on Jan 07, 2009
sentsignal7
  • 186 Answers
SOURCE: Memory uprgrade
You have to remove the keyboard, under the keyboard to the left is a heat shield (silver metal cover), remove it. Your ram is located there. Just take your time and remember where the screws go.
Posted on Jan 22, 2009
Fujitsu v700 4 gb memory will not boot
You don't say if the Notebook is 32 or 64 bit.
If its 32 you may have a problem uprating the RAM more than be handled.
Aug 03, 2017 | Fujitsu LifeBook V700 Notebook 15.4...
My laptop is too slow even if i am just surfing internet like FB. can the memory be upgradable? up to how many gb?
you can upgrade up to 2GB (DDR2)
Your computer has 1 memory slot you remove the memory and install a new one.
you can use either
2GB 800MHz DDR2 Non-ECC CL6 SO DIMM
or
2GB 667MHz DDR2 Non-ECC CL6 SO DIMM
Jun 22, 2011 | ASUS Eee PC 1000H Laptop
I want to upgrade the memory in a lifebook Q notebook. It is NOT under any access panels!
i was trying to find it for you and came across stuff saying you cant upgrade the ram. it is soldered on to the motherboard. this is what it said
"The memory for Q2010 is soldered on board and is of non-standard form factor. What ZaZ suggested is that there "may" be another empty slot on the mainboard which you may utilize, but there is indeed none. So in short, you can not upgauge your memory.
Apr 14, 2010 | Fujitsu Siemens LIFEBOOK Q2010 PC Notebook
Audio driver fujitsu u 820 free download
http://support.fujitsupc.com/CS/Portal/driverdownload.do
Jan 31, 2010 | Fujitsu LifeBook U820 PC Notebook
1. Has anyone installed 2Gb RAM memory in a Sony PCG-TR3A? please give details of memory specification. 2. Has anyone installed a HDD bigger than 40GB? please give me details of HDD specification.
You can only upgrade the memory to 1GB in that model Vaio laptop.
The memory supported is DDR SDRAM which runs at 333MHz. There are 2 memory slots which support 1x512 module in each slot.
I recommend Kingston RAM as the manufacturer.
As for the HDD the laptop supports EIDE (IDE/ATA) hard drive. you can have anything up to 320GB. Seagate are excellent drives as well as Fujitsu.
Regards.
Sep 29, 2009 | Sony PCG-TR3A Notebook
Trying to put 2g mamory into computor only 1 slot
According to specs that laptop came with 2gb installed. Right clik my computer and see if you dont already have 2gb. In the event you dont, memory slots in a laptop are stacked one behind the other. If there is a stick in the slot remove it and I believe youll see another slot behind.
Sep 25, 2009 | Fujitsu Siemens Computers & Internet
Can't find on button Fujitsu Lifebook U820
Try holding the down the power button for 4 seconds or longer. This should work. If the button is on the side and it slides back and forth then keeping holding it opposite of its normal position until it turns off.
Aug 01, 2009 | Fujitsu LifeBook U820 PC Notebook
S6120 didn't take 250GB memory
hi Barch
every processor has three types of buses.
  1. address bus
  2. data bus
  3. control bus
The size of address bus is responsible for the number of memory locations a processor can access.
The size of address bus is fixed for each processor.
Your processor can address that many memory locations only through its address bus.
That is why anything more than the limit of memory location is waste.
Thank You
Jul 15, 2009 | Fujitsu LifeBookS6120 Notebook
Memory uprgrade
Jan 22, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
59 people viewed this question
David Payne
David Payne
