Question about Health & Beauty
Left motor disconnected - Health & Beauty
Wire off
Posted on Oct 19, 2013
How to replace brushes on a classic 6 1200
Disconnect the power
disconnect hoses
lay machine on it's left side
remove back cover screw and cover
slip belt off pully
unplug motor wires
undo bolts holding motor
pull motor to rear of machine
revome motor to bench
locate brush housings
undo retaining clip and slide out old brush
fit new brush
replete with other brush
reasonable in reverse of removal
Oct 04, 2014 | Bosch Washing Machines
I am getting 4 flashing leds on the controller.Manual states this indicates right hand drive motor is disconnected. The lever for right side is engaged. Anyone know how to fix this?
hi, it could be a bad connection to the motor, the controller cannot see the motor resistance, okay trace the cable back to the controller box, checking connections...please update me..
Regards
Rob
www.gewizrepairs.co.uk
Mar 16, 2014 | Shoprider 6 Runner Power Chair With 14"...
Invacare MKIV R11 Flashing lights
One of the most common controllers, codes to help you and others.
VSI & VR2 Joystick error flash codes:
1 RED BAR:
Low Battery Voltage The battery is flat (more likely).
Or the battery has a bad connection (which is unlikely)
2 RED BARS: Left Motor Disconnected The left motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
3 RED BARS: Left Motor Wiring Trip The left motors wiring has a short circuit. Check all connections and leads for wear and chafing between the left motor and the battery cables or chassis
4 BARS: Right Motor Disconnected The right motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
5 BARS: Right Motor Wiring Trip The right motors wiring has a short circuit. Check all connections and leads for wear and chafing between the right motor and the battery cables or chassis
6 BARS: Activated if you turn on your wheelchair with an external device like the Charger still connected.
7 BARS: Possible Joystick Trip, Make sure that the joystick is in the centre position before switching on. If you still get this when switching on then joystick is probably faulty.
8 BARS: A control system trip. Make sure that all connections are secure and if so the power module or control pod is probably faulty. Test by substitution of known good one.
9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
10 BARS: Over voltage detected. This can happen with a bad battery connection although unlikely. More likely your battery charger is faulty and is overcharging your batteries quite severely.
1 BAR to 10 BARS and back in a "ripple" every few seconds. Joystick not cantered when turned on. Switch off and try again.
1 BAR to 6 FLASH every few seconds. System Asleep. Switch off and back on. Time before sleep can be adjusted or disabled in programming
Hope this helps, If so please click the "Yes" button
Regards, Mark.
Jul 12, 2012 | Invacare Pronto M51 Power Wheelchair
Our Jazzy Select G.T. power wheel chair won't run. The lights keep blinking when the power is turned on but won't run..? Why? Battery is charged.
Hi
delobner,
Sometime we lock our vsi joystick by mistake. Here are the instructions on how to lock and unlock your joystick.
If the problem is still there after write me back and I'll help you.
LOCKING/UNLOCKING THE VSI
The VSI has a feature that enables you to lock your power chair to prevent
unauthorized use.
To lock the VSI:
1. With the VSI powered on, press and hold the on/off key. After one (1)
second, the VSI should beep.
2. Release the on/off key.
3. Push the joystick to the full forward position until the VSI beeps.
4. Pull the joystick to the full rearward position until the VSI beeps.
5. Release the joystick. There should be a long beep.
6. The VSI is now locked.
To unlock the VSI:
1. Press the on/off key and power on the VSI. The maximum speed/profile
indicator should ripple side to side.
Good Luck
mi mobility
Feb 18, 2011 | Pride Jazzy Select 6 Indoor Power...
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
2 LIGHTS FLASHING ON POWER GAUGE
Left-hand motor disconnected. flip yellow lever on left-hand motor up.
Jan 29, 2011 | Shoprider Smartie
Blower motor need a page from the book to fix it and it location
Component
Blower Motor Below right side oft?
Blower Motor Relay . In engine compartment fuse relay box
Blower Motor Resistors Below right side oft?
Blower Switch Below center oft?
Engine Compartment Fuse Relay Box Left side of engine compartment
ignition Switch Below left side oft?
Cl90 (68-LT gry) Left side of engine compartment (fuse relay box)
C20l (20-W HT) Below left side oft'?
C225 (13-Will) Below right side oft'?
Q216(8-WHT) Below right side ofi?
0203 Below left side oft'?
Blower Removal
1. Discharge the refrigerant from AC system. (Refer to the operating instructions of
your refrigerant recovery recycling charging station for proper procedures.)
2. Disconnect the inlet and outlet pipe from the evaporator.
NOTICE
- When connecting and disconnecting, refer to Quick Coupling below
- Immediately plug all open fittings to keep moisture out of system.
3. Remove the cover and drain hose.
4. Remove the glove box and disconnect the wiring harness connector.
5. Remove the blower unit.
6. Install in the reverse order of removal.
7. Evacuate the refrigerant system. (Refer to the operating instructions of your
refrigerant recovered cycling charging station for proper procedures.)
S. Charge the AC system. (Refer to the operating instructions of your refrigerant
Recovery recycling charging station for proper procedures.)
Dec 16, 2010 | 1998 Kia Sephia
How do I replace the heating fan on my 2000 Kia sportage
Blower Motor
Removal & Installation
To Remove:
  1. Evacuate and recover air conditioning refrigerant.
  2. Remove battery.
  3. Disconnect and cap A/C lines at evaporator tubes.
  4. Remove blower motor assembly drain.
  5. Remove glove box.
  6. Remove 5 screws and right hand instrument panel lower trim panel.
  7. Remove screw that attaches upper center console to gain access to left
    instrument panel lower support.
  8. Remove left and right bolt and remove instrument panel lower support.
  9. Detach control cable from inlet duct.
  10. Disconnect blower motor electrical connector.
  11. Pull carpet back and remove hole cover plate.
  12. Remove 2 bolts at top of blower motor assembly.
  13. Remove 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  14. Remove blower motor assembly.
To Install:
  1. Install blower motor assembly.
  2. Install 2 bolts at top of blower motor assembly.
  3. Install 2 nuts that attach bottom of blower motor assembly to mounting studs
    on bulkhead.
  4. Install hole cover plate and replace carpet.
  5. Connect blower motor electrical connector.
  6. Install instrument panel lower support and install left and right bolts.
  7. Install right hand instrument panel lower trim panel and 5 screws.
  8. Install glove box.
  9. Install blower motor assembly drain hose.
  10. Connect evaporator lines at bulkhead.
  11. Evacuate and charge air conditioning refrigerant.
  12. Install battery.
Oct 29, 2010 | 2000 Kia Sportage
Replace the blower motor.
Under the glove box:
Disconnect the blower motor power transistor electric connector (the transistor is far over to the left, with a curly wire coming down to it.)
Remove the blower motor power transistor mounting screws the remove the transistor.
Disconnect the electrical connector from the blower motor (slightly to the right of the motor).
Remove the blower motor mounting screws and then remove the blower motor assembly.
(there are, I believe, 3 screws; 1 just below the connector; 1 above the connector, higher up, and slightly to the left; and 1 over to the left of the blower motor)
Remove the circlip from the blower motor shaft to release the fan from the motor.
Installation is reverse.
Hope this helps you deal with it.
Dec 16, 2009 | 2003 Honda Accord
Were is the heater blower on a 98olds silhouette in back of van on the left or right
  1. Disconnect the negative battery cable.
  2. Remove the left hand side rear quarter access panel.
  3. Remove the blower motor electrical connector.
  4. Lift the tabs on blower motor and turn counter clockwise.
  5. Remove the blower motor.
To install:
  1. Install the blower motor and turn it clockwise until the tabs lock into position.
  2. Connect the electrical connector.
  3. Install the left-hand side access panel rear quarter.
  4. Connect the negative battery cable.
Nov 19, 2009 | 1998 Oldsmobile Silhouette
Health & Beauty Logo
13 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
