Question about HP DesignJet 4000 InkJet Printer
It does not recognize hp designjet printhead cleaners 4000
  • 628 Answers
SOURCE: The HP Designjet 1055cm has
I doubt it. When the printer powers up, it checks to make sure that all modules are in place and functional. If one is missing, you'll get an error message.
Posted on Dec 10, 2008
  • 67 Answers
SOURCE: HP Designjet 500ps 24" Plotter- screen says to replace printheads
Printheads are available everywhere, you replace them your self. Machine will usually indicate just one bad print head at a time.
Posted on Jan 10, 2009
ingenito
  • 11 Answers
SOURCE: How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Posted on Jun 20, 2009
  • 75 Answers
SOURCE: How do you clear printhead path Type (1)
the carriage slide bar has no oil on it.using your finger apply some sewing machine oil to the bar
Posted on Mar 09, 2010
SOURCE: I replace the black ink
This message comes when print head is not fitted or locked properly in the socket, please remove printhead, also check for polythene conver on nozzle that should be also removed.
Posted on Feb 08, 2011
New print head ( genuine HP) flashing, not recognized! help
You will need to remove , clean and reinstall the print head.
HP may have some advice specific to your particular model on their support website. Go there and check.
However there have been similar problems with some others and this is the procedure recommended in those cases. It should be similar on your machine.
HP OfficeJet 6500 Printers Resolving Printhead Problem or Printhead...
Jan 11, 2016 | HP DesignJet 110 Plus InkJet Printer
HP designjet 1055cm plus: Installed new toner, printheads and printhead cleaner packs and the black one is failing? Said, alignment so reinstalled. Still failing. Help!
hello,
Try to reconfigure your printer setting and then run diagnostic on your printer to know the status of your printer if it still supports the new toner , printer heads you install.
Thanks
Jul 31, 2009 | HP DesignJet 1050c InkJet Printer
HP DesignJet 4000 replace printhead
Hello.
Replacing the print head on your 4000 is a pretty easy matter. Step-by-step illustrated instructions are in the user manual starting on page 42 and can downloaded from: 4000_User_Manual
Jan 17, 2014 | HP DesignJet 4000 InkJet Printer
My problem is after claibration i receive a message POWER OFF AND CHECK PRINTHEAD CLEANER PATH
Something is blocking the printhead cleaner assembly from moving forward and backward.
Turn the plotter off, open the printhead cleaner access cover (RH side) and see if you can move the cleaners to the front of the machine.
If you can move them fairly easily, then try (with the plotter still off) to move the carriage assembly (holds the printheads) to the left of the machine.
Check the condition of the carriage belt for frayed areas or missing belt teeth.
(I suspect a worn out carriage belt is causing the problem)
With the cleaner assembly to the front, and the carriage to the left, turn the plotter back on and see if the error continues.
May 03, 2011 | HP DesignJet 5500PS InkJet Printer
I replace the black ink printhead and cleaner for hp designjet 1050c and it keeps telling to reseat the printhead.
Dec 29, 2010 | HP DesignJet 1050c InkJet Printer
HP Designjet 4000ps printhead error
Plz Sir
Stape :: 1
Your Printer Cover Open Few Minitus
Stape :: 2
Plz Chek Your Printer Property .... And Delete Your Own Page
Stape :: 3 Plz Check Printer Property And Port Tab Chenge Selected Port
Enjoy
Aug 17, 2009 | HP DesignJet 1055cm InkJet Printer
Open Rh Cover , Remove All the Ph Cleaners
Pull The Tray in Which We Seat the Ph CLeaner , Clean the thin Steel Shaft With a Lint Free cloth ,Insert Ph Cleaners
Check it now if still no go
then Replace service Station
Jul 07, 2009 | HP DesignJet 1050c plus InkJet Printer
Dec 22, 2008 | HP DesignJet 500ps InkJet Printer
The HP Designjet 1055cm has 4 ink cartridges, 4 printheads and 4 printhead cleaners. My question is: Will the plotter still work properly if I just install the black ink cartridge along with the printhead...
Dec 10, 2008 | HP DesignJet 1055cm InkJet Printer
Printhead replacement
I don't just change the printheads, go to utilities and recover printheads.
If all printheads are playing up, che3ck the magenta cleaner, if it's over full it can cause all printheads to fail, this info was taken from a page on the HP web page, but ?I can't remeber where.
May 13, 2008 | HP DesignJet 1050c InkJet Printer
HP DesignJet 4000 InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
