Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
Frigidaire 30" Self-Cleaning Freestanding Gas Range, electricity randomly turns off and on.
  • Official Brand Answer
  • 4,342 Answers
Good Morning Jason, thank you for your post!
First, I suggest plugging another appliance in the same circuit/plug to confirm that the issue does not lie with your household circuit. If your circuit breaker is working properly and the issue continues, then it sounds like your range may possibly have a faulty power supply within the unit, a communication issue with the EOC (electronic oven control), or a potential wiring failure. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Best regards!
Posted on Oct 22, 2013
Krazytech
  • 725 Answers
SOURCE: frigidaire self cleaning convection range
Error code F1
1. Shorted keypad.
2. Control's internal checksum may have become corrupted.
3. Control has sensed a potential runaway oven condition. Control
may have shorted relay, RTD sensor probe may have gone bad.
1. Disconnect power, wait 30 seconds and reapply power. If fault returns
upon power-up, replace EOC.
2. Check RTD sensor probe and replace if necessary. If oven is
overheating, disconnect power. If oven continues to overheat when
the power is reapplied, replace EOC. Severe overheating may require
the entire oven to be replaced, should damage be extensive.
3. Replace EOC.
Check resistance at room temperature, if less than 500 ohms, replace
Temperature (°F) Resistance (ohms)
32 ± 1.9 1000 ± 4.0
75 ± 2.5 1091 ± 5.3
250 ± 4.4 1453 ± 8.9
350 ± 5.4 1654 ± 10.8
450 ± 6.9 1852 ± 13.5
550 ± 8.2 2047 ± 15.8
650 ± 9.6 2237 ± 18.5
900 ± 13.6 2697 ± 24.4
Hope it helps please let me know
Posted on Jun 12, 2008
SOURCE: Frigidaire self clean electric stove 'f9' message
looking for lower element for Frigidaire ElectriClean Wall over
Posted on Nov 21, 2009
  • 401 Answers
SOURCE: I have a Frigidaire Electric Range with
its probebly a bad latch motor. not easy to get at. you may call for service.its located behind the back pannel but depeding on the model its hard to fish it twards the front to replace it.
Posted on Jan 23, 2010
SOURCE: Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Posted on Jul 26, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite made by Frigidaire
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 26, 2010
How do i use the self cleaning feature
Hello Veronica Candeleria - I located the manual on the Frigidaire website. Here is the manufacturer link and hope you find all the information that you need. If for any reason you have difficulties pulling up the requested information, I recommend taking off the last letter of the model number so you can pull up the data
Feb 14, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
What is the input - 120v or 240v?
Hello Seth Kwao - If you are referring to a gas range it is recommended to use a receptacle of 120v and a receptacle of 220v for an electric range.
Sep 25, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
I have a frigidare brand self cleaning gas range and the oven will not light
If the rest of the unit work properly, then you are having an electronic ignition issue. Contact your manufacturer and then a professional they suggest to have it repaired.
Sep 02, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
How do you turn on the self cleaning oven
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Dec 26, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
30 " self cleaning oven,
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
No instructions on how to use self cleaning Frigidaire range/oven
stove stuck in self cleaning mode door was open when cleaning mode was turned on will not shut now what do i need to bdo?
Feb 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven wont heat
This may be a control panel issue. i would also check the glow ignition as well , assuming it is a gas range.
Feb 11, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Cant get the self cleanin to work
I have no manual and wish instructions to use the self cleaning of this Frigidaire electric range.
Jun 12, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
66 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
