Question about Canon P1-DHV Calculator
How do i set it to tally the total amount of lines i am adding?
Is there any problem putting a second trans cooler "in-line"? Would adding enough fluid to fill the cooler affect the fluid recommended fluid level?
You can probably fill the new cooler with liquid and measure the amount it takes, then include that amount in total volume. For instance, when you measure motor oil to a crankcase, some include the 1/2 quart or so in the oil filter to the total volume needed.
I would not see any problem with adding a second cooler. There are some trans pans that have cooling fins or cooling tubes in them. It might accomplish what you want.
Mar 03, 2014 | 2008 Ford Expedition El
How to create post dated voucher in tally
When we issue post dated cheques then we have to maintain the dates on which it is likely to be presented in bank. Regular post dated cheques can be easily trackedpost+dated.jpg e.g. cheques issued for some regular installments etc. But if the quantity of post dated cheques is large and the payment schedule is not regular then keeping track of all PDC becomes more important.
Tally can handle both PDC payments made by cheques and PDC cheques received by you. Tally has a facility to convert any voucher in post dated form. A post dated voucher is one which is going to be realized in future date. It would be reflected in books only on due date and not before this.
While entering the PDC cheque you have received just press 'Ctrl+T' in reciept voucher type and enter the voucher on that specific date.
In same way what ever post dated cheques issued by you can be entered in payment voucher by putting the voucher in post dated mode by pressing 'Ctrl+T'.
Now comes the real problem, How to see the status of these cheques? How to see which cheques is going to be cleared and which cheque is coming for payment? To do this a particular period can be specified in
Display -> Exception Reports-> Post Dated Vouchers
Here you would see all the post dated vouchers. Select voucher type as receipt or payment by pressing 'F4' to see the status on a specified period. You can change the period by 'Alt+F2'.
You can also see the total bills out standing amount with our without post dated vouchers.
If we see
Display-> Exception Reports->Overdue Receivables
then normal screen would be like this
post+dated+transactions.jpgBut by pressing F12 and putting Include post dated transactions to Yes you can see the net pending amount also.
See the figure below how PDC amount can be seen. A new extra column would be added to show the net PD Amount.
The same thing can be achieved for Bills payable in
Display-Exception Report->Overdue Payables
Jun 17, 2011 | Computers & Internet
How to get all balance sheet entries tally to excel
This is a very handy process when you're totaling or subtotaling columns. On the cell that you want the 'total' in type '=sum(column letter row number),(column letter row number). The first 'column letter row number' is where you want the first cell to be started in the total factor and the second 'column letter row number) is the last cell you want added in the total factor. The help (?) section is good at explaining formulas. Hope this helps, keep this process handy if you use Excel much because it'll be helpfull each time you subtotal or total columns.
Bob
Sep 23, 2009 | Computers & Internet
Export tally data to excel
tally data to excel converting . i have some data export to excel but no excel formating you have some tally data to excel spred sheet software
Aug 27, 2009 | Tally T2245 Matrix Printer
Tally 5.4 error
try to configure your configuration setting. change the data source where you data saved.
Exp (from program files, configuration setting) :
;; Tally eis 5.4 workstation specific parameters file
[Tally]
; Specify location of Data files
Data = D:\data tally\Tally 2\DATA
;; Specify list of companies to preload
; ** TO STOP DEFAULT LOADING set the following line to NO
Default Companies = Yes
Load = 0001
;Load = 0002
; Specify list of TDL files for user defined reports and changes
; ** TO STOP LOADING TDL FILES, set the following line to NO
User TDL = Yes
;TDL = <TDL file 1>
; Specify location of TALLY.SAV (saved configuration of Tally)
Config = c:\TALLY
; Specify Color details of local monitor
Color = Yes
a bold letter is the source of data that you must change.
Jun 22, 2009 | Computers & Internet
I set up a google adwords account and my ads are not running,i need some help
u should pay some money to them because it a small charge and they only cut the money form it when any vistor come to it i think per click is 0.16 cent for 1 click ok rate me ok
Jun 18, 2009 | Google AdWords
Page Totals in Reports
Reports: Page Totals Each section of a report has a Format event, where you can alter properties such as Visible, Color, Size, etc in a manner similar to the Current in a form. (See Runtime Properties: Forms for details.) For example to force a page break when certain conditions are met, include a PageBreak control in the Detail Section and toggle its Visible property. In addition, the Print event can be used to perform tasks like adding the current record to a running total.
You have an Amount field, and want to display the Amount total for that page in the Page Footer. Totals are not normally available in the Page Footer, but the task requires just four lines of code!
  1. In the PageHeader's Format event procedure, add:
    curTotal = 0 'Reset the sum to zero each new Page.
  2. In the DetailSection's Print event, add:
    If PrintCount = 1 Then curTotal = curTotal + Me.Amount
  3. Place an unbound control called PageTotal in the Page Footer. In the PageFooter's Format, add:
    Me.PageTotal = curTotal
  4. In the Code Window under Declarations enter:
    Option Explicit 'Optional, but recommended for every module.
    Dim curTotal As Currency 'Variable to sum [Amount] over a Page.
That's it! Don't forget to rate 4 stars for this solution.
Jan 17, 2009 | Office Equipment & Supplies
How to change column in tally
change the portrait form of paper setting to landscape
Dec 17, 2008 | Tally T2250 Matrix Printer
How can i export tally data to excel format?
Export to Excel With new release now you would get one more options while exporting data. One added format option is Excel format. excelexport.jpgIf you export in this format then file would be saved in xls format. More over if you put Excel formating option to Yes then tally would automatically format the data in presentable format. Tally would automatically bold the headlines and main fields for you and format data in a good way. Take a look at excel snapshot of balance sheet exported from Tally.
excelexport2.jpgThe special thing here is that you can do the calculation on any amount figure or any row or column, which was earlier not possible. The only drawback which i could find was that amount figures are not right aligned which is must for numbers for easy calculation, although you can do it by selecting the amount figures and putting them right aligned.
Feb 27, 2008 | Computers & Internet
About tally
Learn Tally 7.2, Tally 8.1, Tally 9 @ your home.
Fee Rs.2000 PrePaid (Rs. 500 extra for study material) (weekly 3 days class, 1 hour duration / total 9 class)
Ph : 9341-202004
E-mail : shekhar202004@rediffmail.com
Sep 03, 2007 | Tally Line Matrix T6050 Printer
Canon P1-DHV Calculator Logo
16 people viewed this question
old marine
old marine
