Question about Dehumidifiers
Instuction manual for amcor D265LA - Dehumidifiers
Amcor pldm18e dehumidifier
That is simple to resolve, go to: http://www.edocr.com/doc/8/amcor-dc800-dehumidifier-operating-manual and download it.
Jan 23, 2014 | Dehumidifiers
Manual for PLDM18E
go to: http://www.edocr.com/doc/8/amcor-dc800-dehumidifier-operating-manual You can download the manual and read how to set the controls.
Jan 16, 2014 | Amcor Dehumidifiers
Fan not operating, believe the mother board needs replacement, where could I purchase one for Amcor Dehumidifier Model # AHD-65E
Unfortunately, you will be hard pressed to find parts for your Amcor Dehumidifier. This British Manufacturing Company of electrical household goods went out of business 03/11/2009. Although, there are some of their appliances are still on the market, you can rest assured their warranty is useless.
I wish I had better news for you, but it is what it is. Thanks for choosing FixYa.
Sep 19, 2011 | Amcor Dehumidifiers
Unit does not start, shows E2 error, can you help on what that code means and resolution
I have searched and searched and have not been able to find an Owner's Manual for your model Amcor Dehumidifier. I did discover that Haier and Fredrich both have similar models, So similar, I suspect Haier manufactured them. But, neither the Haier nor the Fredich's unit have any information concerning Error Code 2. Plus, the ratings for your Amcor model were not very good. Seems that Amcor is riddled with problems.
In any event, lets try to solve your problem. First, turn the Master ON/OFF Switch to OFF. Unplug the unit from the wall outlet and remove the water collection bucket and the air intake filter. Check the filter closely for significant dust and dirt buildup and clean it if necessary. Make sure the filter is thoroughly dry, before placing it in the unit. Leave the unit unplugged for at least 15 minutes or until the filter is dry. Then replace the filter, insert the bucket - making sure that it fits swaourely from top to bottom into the bucket holder. Plug the unit back in and turn the Master ON/OFF Switch to ON. Hopefully, the 15 minute timeout has allowed the unit's electronics to reset themselves and they reverted back to the original factory settings. If so, set the controls to your liking and the unit should start and run like it should.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 17, 2011 | Amcor AHD45 Dehumidifier
I have a Amcor DC830H and have lost the operating instructions . Could you please inform me as to what lights should be showing when using the dehumidifier part. Thank you
Nov 16, 2010 | Amcor DC930 Dehumidifier
Where can I get the correct water plug (what size) for this dehumidifier. The original got lost. I emailed Amcor but have not had a response.
I am unfamiliar with product but look on repairclinic.com under dehumidifier parts (try Item #1334409). JR
Oct 12, 2010 | Amcor DC930 Dehumidifier
LOOKING FOR amcor dc800 manual. Any advice? thanks
problem solved. found instructions.
thanks
Oct 24, 2009 | Amcor Dehumidifiers
Where, in the UK, can I obtain Amcor replacement parts?
the thermal break is there for a reason, the motor has overheated, if this was due to a towel or other item covering the unit great remove the the obstruction and replace the thermal break. however the major cause is that the bearings have dried up on the motor and it has started to seize, which means replacement.
Mar 31, 2009 | Amcor MD250 Dehumidifier
Dehumidifiers Logo
142 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
