Question about DentistRx Intelisonic Toothbrush & UV Sanitizer, Model DRX-1000
Unit won't charge - DentistRx Intelisonic Toothbrush & UV Sanitizer, Model DRX-1000
  • colette
    colette Oct 20, 2013
    No more details involved. I opened the box, put the unit on my shelf, put the toothbrush on the charging unit, plugged it in, the green lights indicating the brush is charging do not light. Left the brush on the unit for 24 hours, the base of the brush gets warm, but is not charged and the lights are still not on.
Won't turn on
try holding the power button down for 8- 10 seconds... then release. Still not on? Is the unit charged?
Jan 20, 2013 | Sharper Image Literati Reader 16375680042...
Battery light is on a 1998 cavalier. alternator won't charge. has new battery and alternator
CHECK WIRING THIS UNIT WILL CONTORT THE FIELD IN THE COMPUTER. THE FIELD CONTROL IS WHAT MAKES IT CHARGE.
Jan 19, 2013 | 1998 Chevrolet Cavalier
My rino won't charge
Two things occur to me: possible damage to socket where charger connects to unit------or no voltage from charge source to the battery
A lot of the connectors where the unit connects to power are easily damaged.
Nov 03, 2012 | Garmin Rino 530 GPS Receiver
Battery won't charge
Sounds like you have a broken AC plug. You can buy them cheap and disassemble the laptop and soldier the new one in but unless your electronically capable I wouldn't try it yourself. You can Google your laptop model number and watch videos to help if you insist on doing it yourself.
Aug 11, 2012 | Toshiba Satellite A215-S4807 Notebook
Have New battery and Alternator, battery still won't stay charged.
Since you are having a new battery and alternator the charging circuit of the electronic charging unit is a possible suspect.
All what is required is to check the charging voltage when the engine is started, if there is no increment of voltage when the engine runs the alternator then the connection from the alternator must be checked. Check the output from alternator, check the relay box which contains the charging unit. It can be a failure of the rectification or the stabilising circuit, the unit must be replaced.
Sep 21, 2011 | 1993 Buick Park Avenue
How long should i charge my jump box
I'm not familiar with this model, but other boxes I've used have all had some kind of power level indicator to show their charge level. I'm sure yours does too. Charge it at least until the indicator shows it's full. You can leave the unit charging for as long as you want, actually. The charging circuitry drops to a low trickle when the unit is fully charged, and won't damage anything by overcharging. (We have one where I work. As soon as we're done jumping something it goes back on charge, and it's over three years old now.)
Aug 11, 2011 | Xantrex Technology XPower Powerpack 200...
My samsung s3600 won't turn on. I charge it but it won't open.
maybe the problem that sir, is the flex bcoz the connection of the power on, came from flex,if the flex damage it result you can't power ur unit..better change it, flex for s360. gudluck
Jul 27, 2011 | Cell Phones
My a/c won't hold a charge because the valve
change copper pipe and any valves.
Jul 24, 2011 | Heating & Cooling
Window unit comfort aire rad 121 e wont get cool. fan works, everything works, just wont blow cold air. can system be recharged like a car?
actually it can be charged like a car "if" it has charging ports which it won't have unless someone has installed them - which would only of happened if the unit had a leak previously. So, to answer your question a window unit can be charged like a car but it's a little more complicated than charging a car and I would think you'd need a serviceperson to do this.
Also, if you don't have charging ports already installed on the unit - the chances that you have a leak is not very strong. These are 'sealed' units and really do not spring leaks very often.
I would be more inclined to think you had an electrical problem, i.e. wire burnt off compressor terminal or something like that instead of leak.
Sometimes you can save a lot of money and time - by getting a qualified serviceperson involved.
Jun 04, 2011 | Heating & Cooling
My unit won't turn off.
I have a Remington electric razor fully charged and it won;t shut off unless I plug it iin. When I remove the plug in cord it runs all the time?
Dec 14, 2009 | Remington MS5500 Electric Shaver
DentistRx Intelisonic Toothbrush & UV Sanitizer, Model DRX-1000 Logo
278 people viewed this question
Top DentistRx Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a DentistRx Health and Beauty Expert? Answer questions, earn points and help others
