Question about RCA F35673MB 35" TV
No sound Our TV was hooked up to a receiver with speakers. We recently moved it to another room and had to disconnect the receiver. I now get no sound at all. I haven't reconnected the receiver, but I believe I should get sound from the TV itself. Before we moved it, we would get sound, but only after the TV had been on about 5 minutes. Once the sound kicked on, it would stay on. Now, nothing. Is this worth getting fixed? (The picture is still good.) Thanks so much!
    Prodigy:
    An expert who has answered 500 questions.
  • 556 Answers
It seems you must have done some thing wrong at the time of connection after moving. please check once again & put on the set.
Posted on Sep 27, 2007
I can't get sound from my speakers. I have a Sharp Aquos 60 inch tv. Hooked up to my Onkyo TXSR608 Receiver. I can't get any sound from the speakers.
Some Onkyo receivers have support for speakers in different rooms, or zones. Make sure your speaker is not set to send the audio signal to Zone B.
Mar 02, 2011 | Onkyo TX-SR608 Receiver
I have a Vizio Flat Screen TV. I have speakers in all the rooms in my home. Can the TV be hooked up to the speakers with any success?
yes, the TV can be hooked to the speakers, but you will be needing a receiver (amplifier).
Check your TV, if you will have any earphone input space. If you find it on the TV, then it means job is half done.
Get a 3.5mm to RCA cord, connect the 3.5mm part to your TV's earphone space (if any), then connect the RCA part (Red and White) to input (Aux/Video/CD in etc) at the back of your receiver (amplifier) or deck, select the input (Aux/Video/CD in etc) on your sound system (receiver/amplifier) and sound should come out of the speakers.
Also, you can use this same method, but this time with a different wire which is RCA to RCA.
Connect the RCA (Red and white, to "Output" or 'Out' at the back of the TV, then connect the other part to the "Input" of your sound system (receiver/amplifier).
Good luck.
Dec 02, 2010 | Televison & Video
Yamaha RX-V463 Receiver Speaker Setup
That receiver has A and B channels. Look for the Speaker button and press it until B appears on the diplay. The other room speakers will play the same thing as in the main room.
Jul 05, 2009 | Yamaha RX-V463 Receiver
No surround sound like the movies
HOOK IT UP FROM A DVD PLAYER OR BLU RAY,,, WITH EITHER COMPONENT OR A OPTICAL CABLE ,,MAKE SURE YOU HAVE ALL OF IT TURNED ON ON THE RECIER SETUP
May 14, 2009 | Pioneer SX-315
We want to hook up eight speakers in eight differnet rooms (one speaker per room with individual volume control) and hook them up with yamaha RX-V1800 receiver so that we can play all the speakers in...
Hi...
Without a huge mess, I would suggest one of the multi-speaker selectors that partsexpress.com sells or a similar item.
Just put "speaker slector" in their search engine.
If youre going to 8 other rooms..you might try a couple of wireless speaker systems too. They work in stereo and ....no wires
Jan 03, 2009 | Yamaha RX-V1800
Onkyo receiver question
One of the speaker maybe are in bad conditions and that burn out the audio amplifier IC you need to change it or send the device to a repair center.Good luck
Apr 28, 2008 | Onkyo TX-SR502 Receiver
No speaker sound
check the 2 buttons under the source selector knob they are labeled A and B check to make sure both are not pressed in just the one you have your front speakers hooked up to
Sep 10, 2007 | JVC RX-770V Receiver
Distorted sound on all right channel inputs
yep but if your not a tech you should take this easy repair to a pro. Your problem is an open emitter resitor and happens when the units over driven or a speaker is bad for a while while it was working. if your a tech then check all of the emmitter resistors. also it could be a bad output device. Good Luck
May 27, 2006 | Yamaha RX-V496 Receiver
Televison & Video Logo
60 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
