Question about DentistRx Intelisonic Toothbrush & UV Sanitizer, Model DRX-1000
Unit won't charge: brand new, just opened, never been used.
My brand new Wolvol Android won't even turn on
I recommend you contacting the seller. They seem to have prompt service.
Dec 24, 2012 | Coco Android 2.1 Tablet (837121001186)
I can't get my charge chord back into the reader. I used it once and charged it to get it going. However,I tried to charge it this morning and the cord won't go in
Maybe the connection pins are broken.
If you brought it brand new as you say, just take it back to the company you brought it from for an exchange.
Good Luck!
Nov 23, 2012 | PANDIGITAL Novel 7
Cool pix s4100 won't charge
If this is a brand new camera, take it back to the place of purchase and have it checked, if battery is used then it will need to be replaced.
Mar 14, 2012 | Nikon Coolpix S3000 Digital Camera
Hi my wife has a philips layshaver that won't hold a charge? Does it need a new battery? Are they easy to replace? Thanks
Yes , if the shaver is not holding the charge then it is possible that the battery has leaked or worn out. You can open the shaver unit and see if there is clogging or crusting on the battery terminals , Sometimes it is possible that moisture has crept into the unit . If so open to confirm . Other wise you can replace the battery , choose from regular types to replace , you can also use ordinary types which can be stacked to suit the voltage and current rating.
Sep 06, 2011 | Philips Televison & Video
My camera won't turn on...it is brand new
Brand new as in you just opened it out of the box? If thats the case you have to charge the re-chargeable battery first, then put it in the camera and it should work fine. Try giving the battery a charge first if you haven't already.
May 21, 2011 | Polaroid i1237 Digital Camera
Psp doesn't charge or open at all, nor any indicative signs
I would think that would be battery problem. Did you buy the PSP new or used?
If used I would buy a new battery and try that. If new reurn it or send it back to sony.
Jul 16, 2009 | Sony PlayStation Portable (PSP) Slim...
Display not open [I X U S 70]
There is small switch under the battery lid near by the battery. Use a tooth stick to press the switch down and turn on the unit. If the unit won’t turn on you need a new main board.
Apr 05, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
DentistRx Intelisonic Toothbrush & UV Sanitizer, Model DRX-1000 Logo
273 people viewed this question
Top DentistRx Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a DentistRx Health and Beauty Expert? Answer questions, earn points and help others
