Question about Hunter Ceiling Fan Light Switch Control
I have a Hunter fan and now the pull chain that turns the lights on and off has stopped working. What do I need to do to fix this?
    Genius:
  • Hunter Master
  • 1,617 Answers
You need to buy & install a new light switch. Should be a two wire switch that you should be able to find at Home Depot, Lowes or a real fan store.
Posted on Oct 18, 2013
  • 51 Answers
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
SOURCE: we have a hunter type 2 ceiling fan installed on a bedroom ceilin
Okay. Turn off circuit breaker. Take the bottom off the fan. Mark how the wires are connected. Remove switch by unscrewing the sleeve you mentioned. Take the switch to Home Depot (or the like) -- buy a replacement.
If you have to turn the breaker back on during this process, make sure you have a wire nut over the end of each of the loose wires you disconnected from the switch.
After you take the switch out, you'll know how to reinstall it, so I won't go thru that.
Charlie
Posted on May 12, 2009
  • 57 Answers
SOURCE: wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Posted on May 16, 2010
SOURCE: Hunter Fan problem
Thge black boxes are capacitors. One is a single and the other is a dual. Evidently the dual runs the two lower speeds and the single run the high speed.
You can test capacitors for basic operation with an analog voltmeter set to Ohms (Rx1 setting is best) by charging up the capacitor with the leadshooked up in one direction, and then reversing them to watch for the slight jump as the capacitor discharges back into the meter... note that this test only works with an analog meter and it must be set to ohms.
This is only a basic test for capacitors and will not indicate if it's withing specs, only that it basically works.
IMO, Hunter is known for having bad capacitors. I've just purchased two fans and already had to swap out the light kits, which contains the capacitors and switches, in one becuse of poor operation and excessive humming noise. since the other fans has the same componenets, other than being a different color, I also thought to try the light kit/capacitor assembly in the fan I've already installed before also installing the second fan.
Guess what, the other set of electircal components with the capacitors runs the fan slower and hums louder.
According to Hunter's web site, humming is a sign of poor engineering in ceiling fans (meaning a power hum rather than a hum from loose components) I agree and Lowes is about to get two Hunter fans back as my three cheapo fans that came with my house do not hum and also the one in my old house did not hum and moved more air.
Even the better capacitor set that I switched out still hums to some degree, so I'm climing Hunter's using **** components, probably becuse their chinese suppliers are screwing them and they're not bothering to keep up the quality control.
Posted on Jun 08, 2010
SOURCE: my hunter fan is not working. the remote has a
It sounds that fan use to work and lights and you did correct thing by changing battery. I've had this problem and it just needs the reciever replaced. Reciever is located at electrical connection in ceiling. Just buy a new universal wireless remote and reciever at any home depot. if dont fill safe doing this task should call an electician to do job or someone with electrical skills.
Posted on Aug 16, 2010
Hunter ceiling fan will not work
Maybe you have dimmer for light also dimming fan motor?
Aug 01, 2014 | Harbor Breeze 44-in Tilghman Aged Bronze...
The light flahes whe the hunter fan light chain is pulle. Why.
If you're putting in the correct bulb then you probably have a short in the light.
Jul 14, 2014 | Dryers
Hunter Light transponder fail?
Only way to know if it's the light is to take the remote receiver out and try the pull chain on light after rewiring to house wires.
Jan 03, 2014 | Hunter (25417) Ceiling Fan
Hunter fan works light broken
Check to make sure light wires are connected at light kit & remote. Otherwise it's probably a bad receiver. If there is a pull chain for the light pull it once & try the remote light button again.
Mar 10, 2013 | Hunter Ceiling Fan Light Switch Control
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Hunter 52, fan works but light no longer works with remote or chain pull
mcdevito75 here, Don"t the fan lights work off the wall switch, The chain pull should be for fan speed. Check make sure electricity is going to the fan.
Jul 19, 2010 | Hunter 52" Ceiling Fan With Light And...
Fan stopped working and light now only works on pull chain
there should be a remote inside of the fan that probably went bad
Sep 05, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Ceiling fan pull chain connected but does not click on
There is a pull chain switch inside the fan termination housing. you will have to take the little cover off and remove the switch. it has 2 small screws with wire landed under them. Turn off the power at the breaker before working on the switch. take this little ****** out and put in a new one. you can get them at the Home Depot or equivelant. it don't matter if the new switch is a little bigger but it still has to fit. use some judgement here. wire it in the place of the old one, turn the power back on at the breaker and it should be ready to go. Presto.
Aug 16, 2009 | Hunter 20531 Vista Brushed Nickel Ceiling...
Ceiling fan stopped working after power spike blew the breaker. I reset the breaker and all else in the room came on but not fan. Does it have an internal reset?
If you own a Hunter Original, there is no reset button, but MANY people that have a remote control added (includng me) have , once power has been restored, found that the chain was pulled by someone and it got into the off position, rather than the slow, medium or high setting. With the circuit hot, pull the chain one more time and try to turn on your fan with the remote again.
Hope this helps.
Jun 20, 2008 | Hunter 23852 Classic Original Ceiling Fan
Dryers Logo
85 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
