Cleopatra cooker parts
Sut at the bottom of the cooker beside plates(burners)iol does not seem to vapourise
2 Suggested Answers
  • 213 Answers
SOURCE: Where can you get oil burners for cleopatra cooker
Hi Emer O Grady,
Here is a sight that does reconditioning. May suit your interest. Also international inquiries accepted. Reconditioned Cleopatra oil fired central heating cooker . This would be a solution since they have contact resources. Best Wishes. Fare. Well.
Posted on Jul 03, 2014
Oven igniter comes on gas burner lights but goes out after 15 seconds cutting power to the stove power comes back on after a couple of minutes model mgs5770
Hello Susan,
it is not quite clear to me what you mean.
But I think, the ingition in the gas oven works and lights the burner.
and then after 15 seconds the burner goes out.
Any modern oven has a Flame Failure Device.
That prevents the oven getting gas when the burner went out for some reason.
I would suspect that FFD, it is mounted besides the burner.
You can not repair that part for safety reasons, You have to replace it when it is gone.
Kind regards, Dik
Flavel Leisure Cooker Spare Flame Failure Device FFD CO1464
Feb 10, 2018 | Kitchen Ranges
Hello Susan,
Kind regards, Dik Flavel Leisure Cooker Spare Flame Failure Device FFD CO1464
Where can you get oil burners for cleopatra cooker i live in sligo Ireland and finding it hard to find any??
Hi Emer O Grady,
Jul 03, 2014 | Kitchen Ranges
Burning smell from underneath the bottom oven plate
Something spilled into the area where the flame is Those big gaps in the bottom plate is how the heat gets into the oven from the burner . Try letting the oven burn off whatever spilled in it
Jan 04, 2014 | Samsung FX510BGS Gas Ranges
Pressure cooker is not heated on induction cooker
Likely the pressure cooker base is not induction-compatible. This is the case with all aluminum pressure cookers and some older stainless steel models. Your cookware store will have a small metal plate that you can put on your induction burner to heat non-induction compatible cookware.
Nov 10, 2013 | Home
Stove top gas burners are making my pots black with sut
the flames seem to be to high
try adjusting the air shutters underneath the cook top
May 27, 2009 | Magic Chef 9122 Gas Single Oven
Rice cooker keep feature turns rice crispy
This sounds like the thermostat inside the unit has went out and is overheating whitch in turn is cooking your rice too fast and too hot! if the thermostat is replaced it will cook the rice even again!
Please rate my response to your question
Thank You!
Jan 07, 2009 | Sanyo ECJ-PX50S 5-Cup Rice Cooker
How to fit a flame failure device to rangemaster 55
the part that you need is the oven ignitor, located nest to the oven burner. that part gets hot to open the gas to the burner, that will make the oven work again.
Dec 08, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Cannon Rhapsody LPG Gas open Fire sooting up of burners
well its my experience that ranges don't come lpg they are all made natural gas but you convert them to lpg after purchase now if the lpg conversion isn't done properly then they soot like crazy proper lpg converson is to change the spuds on the burners and to turn the orifice over in the pressure regulator do you still have your owners manuel if so consult it on converting gas range to lp then check to see if every thing was done right on the pressure regulater there is a square cap you take it off and there is a round part that on one side says lp on the other says ng this changes the pressure that the regulator as ng and lp operates at different pressures and the regulator has to be set for what you using like i said im not familiar with your brand or model but i do know the problem if the range did come ng then you need to make sure the conversion most ranges aren't lp because there is not that big a market for it read the plate on the back will tell you if it was made ng or lp serial plate on front may say also most of the time it is beside the bottom drawer on the range
Jan 18, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
