Question about Rossi Single Shot 308 Winchester Rifle in Blue Finish
Rossi single shot rifle in 243 accuracy - Rossi Single Shot 308 Winchester Rifle in Blue Finish
Harrington richardson 243 modle sb2 ultra would like to know the value of this gun
H&R SB2 Ultra .223...whats it worth? ' The Firearms Forum
www.thefirearmsforum.com > ... > The Ask the Pros & What's It Worth? Forum
  1. Cached
  2. Similar
Apr 9, 2011 - 9 posts - ‎4 authors ... i can get for it. Its an H&R SB2 Ultra .223 with a Bushnell 6x-18x,50 Banner... ... NIB - this model in that caliber sells in the $279 - $290 range.
Harrington For Sale - GunBroker.com
www.gunbroker.com/Harrington-Firearms/Browse.aspx?Keywords=Harrington...
  1. Cached
  2. Similar
H&R Harrington & Richardson SB2 Ultra 243 win ... Harrington and Richardson Handi Rifle 243 Win ... H&R Model 158 30-30WIn -LIKE NEW-single shot.
Harrington Richardson Rifles For Sale on GunsAmerica
https://www.gunsamerica.com/Search.htm?C=325
  1. Cached
24 Listings - Beautiful H&R (marked Wesson & Richardson) Model 1871 Buffalo Classic ... Harrington & Richardson Handi Rifle; SB2; in .243; 22-inch barrel; adult ... Harrington richardson 243 modle sb2 ultra Google Search
Dec 02, 2016 | Harrington & Richardson H&R Superlight...
Need Rossi 243 single shot rifle sights
gunsmith is the only place I KNOW
Feb 18, 2015 | Optics
I recently bought a Rossi 243 riffle and it has jammed after firing the 8th bullet, how do I fix this?
Remove the firing pin. The entire gun might have to be disassembled to get to it.
Nov 25, 2014 | Optics
Rossi arms
Yes you can but you didn't include any model info, just that it's a Rossi brand.
So, start here:
http://www.gunpartscorp.com/Manufacturers/Rossi-33467.htm
Shotguns are at the bottom of the list.
Aug 23, 2014 | Optics
Can't remove stock from Rossi single shot
Remove the butt plate (should be 2 screws), shine a light down the stock bolt hole to determine if you need a socket and extension or a long screwdriver. Use the appropriate tool to remove the stock bolt. Righty tighty, lefty loosey.
Oct 02, 2013 | Rossi 308 Winchester Single Shot w/23 Blue...
I have a 243 cal single shot that snaped when fired. Tried different ammo. still misfires
Firing pin is worn. It may make a slight dent in the primer, but not quite enough to press against the anvil inside of the primer, hence the misfiring
Talk to a gunsmith to see if he has any spares, or has the ability to repair the firing pin.
Oct 03, 2012 | Harrington & Richardson H&R Sportster in...
What is the best lubricant for keeping the rifled barrel clean and how often should it be lubricated?
Oil in the barrel an air gun can lead to bad things, If you are worried about corrosion, lube with light oil then remove as much as possible with a dry swab. It doesn't take much to provide corrosion protection. I rarely clean or lube my air rifles, maybe 2 times/year or every 1,000 shots. It really is not necessary unless your accuracy deteriorates.
Here is an excellent article dealing with this issue:
http://www.air-rifle.net/cleaning/cleaning.html
Apr 26, 2010 | Crosman Optics
Rossi Single Shot 308 Winchester Rifle in Blue Finish Logo
50 people viewed this question
Top Rossi Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you a Rossi Optic Expert? Answer questions, earn points and help others
