Question about Toshiba DVD/VCR Combination
Dvd ok but the video keeps cutting out - Toshiba DVD/VCR Combination
Sound keeps cutting out
take to the repairers they will handle it parfectly
Sep 05, 2017 | Toshiba Satellite L755s5246 Laptop...
A VHS tape is in the recorder but will not eject. The flap opens when eject key is pressed, the cassette comes up, does not come forward, and then goes back down. The recorder then switches itself off.
Hi, the problem is the tape has got chewed up inside the video the only way your going to get it out is by taking the case of but dont do this whilst its plugged in.
you need to take the tape off and you may have to cut the tape so you can put the case back on and switch it on so the tape will eject, you need to get what ever is keeping it stuck free, the chances are the tape has got chewed up around the drive and this will need cutting free to allow the tape to come out.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks.
you could try fast forwarding a bit or rewinding a bit then try ejecting but failing that your going to need to take the case off to free the tape
Sep 01, 2010 | Panasonic DMR-E95HS DVD Recorder
Avic-n3 to play dvd while in motion
There are a few ways to do this. Most of them involve grounding the e-brake wire and uploading special software. www.avic411.com should have multiple posts that give you step by step directions.
Feb 02, 2010 | Pioneer AVIC-N3 Car DVD Player
Picture sides cut off when watching avi files
My new LG LCD is not syncing the video and audio when playing avi movies on either USB stick or HDD.
Dec 28, 2009 | LG 37LC5DC 37 in. LCD Television
JVC DR-MH30 keeps flashing ''loading'' after recent power cut
Measure the 5V line on the DVD drive,if to low replace the bad caps in power supply.There is an 22 microfarad elco you can upgarde to 47 microfarad to last longer.
If the 5V line is ok the problem could be the harddisk,this is not traceable without the proper software.
Aug 13, 2009 | JVC SR-DVM700 DVD Recorder/HDD Recorder
Unit shows 'loading' continuously
This player is equipped to do a self power on test to all pain parts of the player to assertain everything is ok. The blue light will keep flasing until it completes its task and then the blue light will stop flashing and you you can start reusing it.....................sodeep
Jul 30, 2009 | JVC DR-MH30 DVD Recorder
How do i edit a dvd? i copied a movie from tv but it ran over and dvd copied part of another movie.how do i remove it
if u have recorded using dvd recorder then u need to use Pinnacle video maker or sony vegas to cut and edit ur movie
Jul 09, 2009 | Ahead Software Nero 7 Essentials Suite...
How to solve disc region error?
Here's how to make it region free..
1.Keep Tray in eject position
2.Press Setup from remot
3.Go to preference page
4.Press"138931"
5.Using Navigation Key change region code to "0"
6.Press "OK"
7.Regionfree!!
Jay
May 25, 2009 | Televison & Video
Cuts out for a second when watching dvd's and then resumes
wow its weird the ps3 dvd drive is not messed up my the laser that reads data every mili second is actiong up skipping over movies with a lot of dialoge
May 19, 2009 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
21 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
