Question about HP OfficeJet 6210 All-In-One InkJet Printer
Print spool I used the printer this morning, and it worked just fine, went to use it this afternoon and it won't work. Its telling me that the print spool doesn't work. I don't know how to fix that. Hoping you can help. Thanks, Sharon
    Scholar:
  • 84 Answers
Click on start Click on run Type services.msc Look down the list and set the following to Automatic Click apply after all are set. Shut down and restart the computer Then try printing again Print Spooler LexBce Server Remote Procedure Call RPC
Posted on Sep 27, 2007
Printer is just printing a whole page of black ink and no words
Yqes that is your toner. It needs to be replaced or checked if needs to be replaced mmaybe needs cleaning asking but for the most part. If only black ink and no colors do a self diagnostic on the printer , if this is not available make sure there are no paper jams also.
Feb 21, 2012 | Ricoh Office Equipment & Supplies
How to fix lexmark s400 error messages
Please make sure that the Print Spooler service on your computer is running and enabled. Go to Start menu > Control Panel > Administrative Tools > Services. Select Print Spooler in the items. Right-click on Print Spooler > click Properties. In the General tab, select Automatic for Startup Type. Click Start for Service Status. Hit Apply, and then hit OK to save the settings.
Try to print a document again to verify that the problem is fixed.
Should the problem continue, maybe it would be best to contact Lexmark Technical Support Center to further diagnose the problem.
Jan 22, 2012 | Lexmark X2600 InkJet Printer
Pulled in driveway this morning transmission was working fine. Went to pull out this afternoon, and transmission will not engage in any gear.
check fluid levels in transmission it needs to be tested to determine if its a sensor or something more most transmission shops will tell you what it is at a fair price find one that is trust worthy and has experience in transmissions
Feb 23, 2011 | Honda Accord Cars & Trucks
OUR tALLY 8008 IS A NETWORKED PRINTER. FOR SOME REASON IT IS NOT PRINTING FROM MY COMPUTER. IT WAS PRINTING FINE THIS MORNING AND IS STILL INSTALLED ON MY PC. THE MESSAGE "THE DOCUMENT FAILED TO...
You may need to clear out your print que and restart the print services. Open a command window by typing CMD in a run box. Type the following in the command window after it opens:
net stop spooler
del %systemroot%\system32\spool\printers\*.shd
del %systemroot%\system32\spool\printers\*.spl
net start spooler
There will be a delay after you hit enter when you type the net stop and net start commands.
Aug 26, 2010 | TallyGenicom Office Equipment & Supplies
Dell 942 all in one printet wont communicate to dell dimension pc
You've tried to uninstall and reinstall the printer driver of your printer. But still no luck. The printer still won't print. Or it would say printing but it won't finish printing.
You can try these steps:
1.Check if the firewall is blocking any printer services
2.Check what port the printer is using (reenable the bi-directional support) and if it's on online mode
3.Disable all the firewalls
4.Uninstall the printer driver and software
5.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet\Control\Print\Environments\Windows NT x86\Drivers\Version-3
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-2
HKLM\System\CurrentControlSet001\Control\Print\Environments\Windows NT x86\Drivers\Version-3
Optional***
6.Delete any non default items under the ff keys:
Note: ONLY THE NON DEFAULT ITEMS SHOULD BE DELETED
HKLM\System\CurrentControlSet\Control\Print\Monitors
HKLM\System\CurrentControlSet001\Control\Print\Monitors
Default items are as follows:
AppleTalk Printing Devices
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
Windows NT FAx Monitor
7.Delete any items under the ff keys:
HKLM\System\CurrentControlSet\Control\Print\Printers
HKLM\System\CurrentControlSet001\Control\Print\Printers
8.Completely remove drivers by doing the ff: (Option for comm failure because of the upgrade from xp to vista)
Ensure there are no documents in queue.
Disconnect printer’s USB cable.
Click the Start pearl, then click All programs, Printers, Dell xxx (where “xxx” is the printer model number) and then Uninstall. Complete the uninstall utility.
From the start search box type spool and press .
The spool folder located at c:\windows\system32\spool opens.
Rename c:\windows\system32\spool\drivers\w32X86 to c:\windows\system32\spool\drivers\backup.
Rename c:\windows\system32\spool\prtprocs\W32X86 to c:\windows\system32\spool\prtprocs\backup.
9.Restart the computer.
10.Check th services status
Start-Run- Type Services.msc and Click on Open
You will see long list of services
You need to make sure following 4 Services are set to Automatically start
Remote Procedure Call RPC Locater
LexBce Server
Print Spooler
11.Reinstall the latest printer driver
good luck. :)
Aug 30, 2009 | Dell 942 All-In-One InkJet Printer
Will not print! was working fine and stopped?
go to start>>control panel>>adminsitrative tools>> services
right click on printer spool and select stop.
restart the printer. restart the printer spool.
May 14, 2009 | HP Officejet 6200 All-In-One InkJet...
Printer Spool
Windows XP: Click on Start click on Run Type in CMD and hit Ok....... Now type in " sc config spooler depend= rpcss " just copy and Paste the same thing.......... Now after typing that hit enter......... It should say ChangeconfigSuccess.......... Now click on Start click on Run Type in Services.msc click ok..... On the new window Find Print Spooler....... Just right click on it and start it will work fine...... Good Luck............
Windows Vista:  Click on Start click Type in CMD it will show you result for it just right click on the CMD and click Run as an Administrator..... Now type in " sc config spooler depend= rpcss " just copy and Paste the same thing.......... Now after typing that hit enter......... It should say ChangeconfigSuccess.......... Now click on Start Type in Services.msc Hit Ok..... On the new window Find Print Spooler....... Just right click on it and start it will work fine...... Good Luck
Jan 28, 2009 | Lexmark Z645 InkJet Photo Printer
Won't print. Red light blinking
Reboot your computer and power down your printer. Leave them off for about 30 minutes or even overnight. (In other words, leave the computer and printer off more than a few minutes--some of the printers take more than 5 minutes before they'll clear their memories--a quick reboot won't do it.)
When deleting print copies it is safer to use the delete button on the printer than to delete from your computer, as then the copies don't get hung up in spooling.
I've had to do this a few times with Vista and printers, as things get held up in spooling on a regular basis.
Jan 05, 2009 | Brother HL 1440 Laser Printer
Printer Error
check all drivers first........
if it dont work............try to print any matter........
if it work then main matter u r trying to print may be in not a printer supported format
dont forget to tell me u r problem solved or not
best regards & best of luck..
Oct 25, 2007 | Computers & Internet
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
