Question about GE CVM2072SMSS Microwave Oven
I want to replace the control panel on my GE CVM2072sm3ss otr microwave. It has a motorized vent above the door and control area and I can't get to the screws as shown in your helpful video. How do I proceed?
fridgetech
  • 473 Answers
SOURCE: GE Microwave JVM3660SD001 Control Panel Removal Procedure
Remove the grill, should be screws on the top of the unit. There should be one screw behind the grill at the top of the control panel. Remove it and pop the control panel up to remove it. Make sure the mw is unplugged first. Then you can remove the board.
Posted on Oct 05, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacemaker Microwave Handle Replacement
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Aug 10, 2008
SOURCE: Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Posted on Oct 07, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: GE microwave (jvm1740dm1bb) - Control panel inop
That model number is not quite right. I'm going to assume it's JVM1740DMBB01.
(If that's not right, please check the tag inside the oven & reply back)
The membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
The part number you need is WB07X11040 and you can find helpful exploded view diagrams and order this part here for $107.00 (compared to $164.75 from GE!)
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 02, 2009
jsrock516
  • 5911 Answers
SOURCE: Handle broke off my GE Advantium 120 microwave
You are correct. The handle screws can be accessed by simply removing the interior facing of the door, and can easily be replaced without the assistance of a repairman. This is a common problem with some microwave oven doors.
To access the door handle mounting screws on MOST microwave ovens, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to carefully pry the plastic up and work your way slowly around the perimiter of the glass. Most microwave ovens also have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, simply open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
If you have any questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: You can view some excellent exploded view diagrams of your oven at pcappliancerepair.com as reference to see how the parts are assembled.
Posted on Sep 16, 2009
Where is the fuse on kenmore microwave
Is this an over-the-range (OTR) microwave oven or a counter-top model? Assuming it is an OTR model, your can get to the fuse by first unplugging the microwave, then removing 2 to 4 screws over the grille vent. Remove the grille vent. Depending on the model, you either slide it to the left a little bit (1/4 inch) then pull it out, OR tilt out the top of it followed by the bottom. Now you should see 1 screw that hold the top of the control console in place. Remove it, then lift up on the control console to get past the tabs, and tilt out the top. Now, depending on the model, you may see the fuse behind the control console, or if it's not there, then remove the 1 or 2 screws that hold the metal grill vent that's located above the control console. Remove that metal grill, and your should see the fuse behind it. Sometimes that fuse blows for no good reason, other times it blows because you have a shorted high-voltage capacitor, or you may have a sticking "monitor" door switch.
Jun 25, 2014 | Kenmore 63252 Microwave Oven
Samsung microwave not working
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 02, 2013 | Samsung Microwave Ovens
No power
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.Remember use the VOM.
God bless you
Apr 02, 2013 | Electrolux E30MO65GSS Convection Microwave...
My emerson microwave will not power on
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open. Use the VOM
God bless you
Apr 02, 2013 | Emerson Fans Emerson MW8115SS Microwave...
Won't run
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Test the switchs door see diagram
Oct 10, 2012 | Frigidaire FMV156DC Microwave Oven
GE microwave oven not working
Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 10, 2012 | GE SpaceMaker Microwave Ovens
My microwave shows nothing on display and will not turn on
Sep 27, 2012 | Maytag Appliances Over-the-Range Microwave...
Mh3184xpq-4 is dead, i have replaced the fuse...what else could it be?
see the next steps: use the common sense God bless you
Aug 01, 2012 | Whirlpool MH3184XP Microwave Oven
Replaced the touchpad and put it all back together. It now heats, but the oven light doesn't come on and the turntable doesn't rotate. Do you think there's a loose wire?
First check is the main fuse of the unit. On countertopunits, you will need to take the shell off. The fuse will be close to where thecord comes through into the unit. OTR units, this main fuse is usually behindthe control panel or possibly behind the vent. Usually the fuse is obvious ifblown, otherwise test with an OHM meter, if open, replace fuse. Some brands will also have a thermal cut-off fuse in theincoming voltage line to the control board. This thermostat looking fuse isusually above the oven cavity somewhere under the outside shell. Sometimes youcan get to it through the vent of OTR models. Test with an OHM meter, replaceif open. Forturntable: First, make sure the turntable coupler under the glass dish is notbroken. Second, on the control board, find the turntable relay and test forvoltage. Some turntable motors are 24 volts DC, so make sure you're testing thecorrect voltage. If no voltage from the control board, then replace the controlboard. Otherwise head towards the turntable motor. On OTR models, you can get to the motor by un-screwing thebottom panel on the microwave. On countertop models, there will either be aknockout or screw on access panel. Check for voltage at the motor. If novoltage, check the wiring back towards the control. If voltage, then replacethe turntable motor. Hope this will help you. Good Luck.
Sep 03, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
Mounting OTR microwave oven under a penisula cabinet
We put false doors on the back of the peninsula, mounted the wall mounts on the inside of these doors and then connected it to the top.
Mar 24, 2017 | GE Profile Spacemaker Over-the-Range...
GE CVM2072SMSS Microwave Oven Logo
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
