Question about Dishwashers
Indesit dif 04A dishwasher
My dishwasher has stopped working, the control panel seems fine it allows me to turn it on/off or change programs as i desire but the washing process does not begin this has happened in the past and been solved with a firm closing of the door but that is not working and i dont want to damage it further please help
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Either: broken wiring at the hinge point o the door
or: water solenoid full of crud.
get a service tech to check it out.
Posted on Oct 18, 2013
  • 641 Answers
SOURCE: rcd tripping
Well done ! Thanks for the information.
Posted on Jul 21, 2007
Krazytech
  • 725 Answers
SOURCE: Indesit di67 dishwasher
Did you check the float switch? it is bottom of the dishwasher ( may be under the dish washer Bosch / Danby .. it should move freely up and down.. make sure that there is not something under it .. Also to much soap can stick the the float in the up position. if it moves freely test it. unplug the dishwasher or shut off the power at the breaker. Check for continuity with the terminals removed...if you don't have it you have a bad switch...let me know if it helps
Posted on Aug 15, 2007
SOURCE: Tecnik DW2677
check your water intake- i had the same issue - a leaky fitting wasn't supplying enough water to the dishwasher. had exactly the same symptoms you describe. fixed the leak, reset the dishwasher & it's working fine.
Posted on Mar 03, 2008
aborcass
  • 2651 Answers
SOURCE: Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Posted on Mar 24, 2008
  • 58 Answers
SOURCE: kenmore quietguard standard wont start.
is there any function at all? if not, check thermal fuse located inside near control panel, check www.searspartsdirect.com and enter your model # to show how to take it apart. If it has functional display lights, replace main control board after ohm test on wash motor and fill valve.
Posted on Jun 25, 2009
My indesit idl40 cleans everything, but leaves a film? does not seem to rinse?
Hi, what you are currently experiencing is as a result of dishwasher detergent, combined with mineral deposits from hard water, which in yurn can leave a white film on the inside of the dishwasher.
You have to clean the dishwasher by sprinkling baking soda onto a damp cloth. Scrub the inside of the dishwasher to remove soap scum, grime and mineral deposits.
Pour 2 cups white vinegar into the bottom of your dishwasher. Turn the dishwasher on and run it on a full cycle. Stop the dishwasher halfway through the wash cycle and allow the vinegar and steam to work on the remaining mineral deposits for 20 minutes before resuming the cycle.
Open the dishwasher and dry the interior with clean, dry cloths. Keep the door propped open for 20 to 30 minutes to allow the dishwasher to dry completely.
Jun 26, 2011 | Indesit Dishwashers
Indesit DIF 04 error lights halted cycle
i have a indesit dif 04 that starts a cycle fills with water and then the lights on door start to flash,leving all the water in the bottom?
Jan 10, 2010 | Dishwashers
I have a indesit idl 40 dishwasher but heater not working changed heater + thermostat still not working
if you have changed the heater then you will find that either the connection from the heater to the control module behind the control panel is poor and may have damaged connections soldered to the module
Feb 24, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit D61D Sticks In Its Cycle
The repair can be done yourself you need to first purchas a can of liquid wrench with extention. and first shut off power or disconnect power. there is a acess panal that you need to remove to get at gears to grease once it is greased you will need to turn the dial a couple of times (powerless) and replace the panel and plug or turn on power (when you are turning the knob besure to return to the start cycle ) if you need more info please email me kcord44@yahoo.com thank you and good luck
May 29, 2008 | Indesit 24 in. D61 Free-standing...
Aug 14, 2007 | Indesit 24 in. DI67 Free-standing...
Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Aug 05, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit D61D
the solenoid has gone you will need to replace the soap unit. meaning panel off of door and removing unit.
Jan 13, 2007 | Indesit 24 in. D61 Free-standing...
Indesit idl 705 Dishwasher
Having read another users fault (LUNNY) that has same fault. They got engr out and it was a blocked pump. Where is the pupmp located on this model as I have the same fault and want to resolve it asap.
Aug 24, 2006 | Indesit 24 in. IDL700 Built-In Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
