How do I scan a documnet form my scanner to my computer?
3 Suggested Answers
SOURCE: Scanner Delivery server fails on my Gestetner dsc232
First, it doesn't work on Vista, if you have upgraded you OS??
So, have all of the destinations disappeared off the display?, and "updating destination list has failed' message displays" (or something similar).
If this is the case........ have you tried going into the "Scanrouter V2 admin utility", and under the "server" button select "set I/O device", then select "remove". If you are asked to "retain settings" select "no". Then click "add", then "Browse", it should find the machine, select "ok" then name it whatever you want -it's for identification only
This helps when (for some reason) the machine has become disasscociated with the Ip address for lack of a better description -particularily if the software is not installed on a machine with a statc IP.
OTHERWISE
Do the destinations still appear but the scans do not reach their destination even though they appear to be sent?
This happens when the Windows login password has been changed, because Scanrouter is linked to the admin password.
The way to tell is if you click to open the "Scanrouter V2 admin Utility", and get a message pertaining to a "wrong password" or similar. - Enter the NEW windows login password
OR
Has windows Firewall been enabled? TCP port #3670 needs to be opened
Please let me know if any of these solutions help, and Please rate me :)
Posted on Mar 24, 2009
puertobori
  • 7733 Answers
SOURCE: the scanner scans but does not produce the scanned
Try using the HP Scan Diagnostic Utility in Windows - HP Customer Care (United States - English)
If you need more help post back!
Thumbs and testimonial are welcome!
Posted on Mar 06, 2011
Canon dr-2010c device cannot be locked
I hope there is enough hard disk space is available in the drive/volume you are attempting to send the data. Scan in TIF compressed mode, uncompressed made uses large space.
Check if there is virus on your system. Uninstall and reinstall the drivers. Run scandisk to optimise disk performance.
S. Mohan
Apr 03, 2012 | Canon DR Office Equipment & Supplies
I own canoscan Lide-25. I want to scan forms and fill in the blanks of the form from my computer then print for my use. How to do this? Am I to buy any splecial software other than OCR already provided.
I wouldn't use OCR, too difficult. I would save your scanned document as a jpeg and edit in Photoshop. From Photoshop thay can be printed or saved as a pdf file.
Mar 31, 2010 | Canon CanoScan LiDE 25 Flatbed Scanner
Cannot edit my scanned images any more
There is a software in the HP CD which is called an OCR software. This is Optical Character recognition. Only with the help of the software you will be able to edit the scanned documents. This software ded not gets installed with the drivers so pleas check this in the CD. Also you can try fine reader software for editing your documnets. You will be able to find it on google
Jul 08, 2009 | HP PSC 1410 All-In-One InkJet Printer
Lexmark x1240 All-In-One Printer Control Panel
Hi
This is the description of printer control panel
green button-START COLoUR COPY BUTTON.....place a documnet on scanner glass...press this button..u would get colur copies of the document
Black button-START BLACK COPY BUTTON.....place a documnet on scanner glass...press this button..u would get black copies of the document
white button on the left hand side-paper feed button..to load paper into the paper feed tray
white button the right...not sure:)....i guess it should be the scan button....
all the best
Apr 02, 2009 | Lexmark X1240 All-In-One InkJet Printer
Dr-2580C nolonger pulls one page at a time.
How old is the rubber roller, in terms of number of scans? It it had crossed 250,000 better change it. It wears out and no amount of cleaning can help. Ensure that the paper is not sticky. Stapled documnets are held together where the pis was, ensure they are free.
S. Mohan, Chennai, India
Mar 19, 2009 | Canon DR-2580C Path-Through Scanner
Need to scan a form to be filled out to computer
If you scan a form onto a computer, it won't behave as a form by default. This is because the computer is just storing a picture of the form, and doesn't see it as a form.
To make a scanned form into an electronic version, you will need some software that lets you define the regions of the form that can be filled in by the user. the full version of Adobe Acrobat lets you do this, as do the less expensive programs CutePDF Professional or PDfill.
Basically, you scan your document into a pdf format and use the aforementioned software to define which regions on the form should have typable text, checkboxes, etc., then you re-save it as a fillable pdf.
This works well, I do this with all my rental applications, etc.
There is a little bit of learning required to do this, but if you spend some time with the program and its helpfile you'll be creating forms with the best of them!
Apr 22, 2008 | Office Equipment & Supplies
HP PSC 1110 all-in-one does not scan with windows vistas. I do not want to use ms paint is there any other soluion
I had this problem. If you like my solution please consider making a small contribution (e.g. 1$) to a charity of your choice.
For use on Windows Vista
Launch "Windows Photo Gallery", click on file and select "Import from camera or scanner". If your scanner is connected and powered up, your device(e.g Hp psc 1110) should be displayed in the "Scanners and Camera" section. Double click on your scanner in this window. A dialog box should be displayed. It will allow you to set scan characteristics and preview your scan. happy scanning !!
As far as i know "HP Director" has been replaced on Vista with the method described above.
Mar 26, 2008 | Office Equipment & Supplies
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
