Question about Braun BP-5900 ExactFit Blood Pressure Monitor
What is error 88 - Braun BP-5900 ExactFit Blood Pressure Monitor
  • Fedai Barcan
    Fedai Barcan Oct 26, 2013
    Braun Bp 5900 is not masure blood pressure.
    There is a errror no:88
    What is this error
8 e code
Most like it is a defrost sensor error in the FF section. On the back of your refrigerator there should be a schematic of what happens when there is an error...normal when performing the self test and all is ok is a reading of 88 88 Different parts of the 8 will blink depicting the error. For 88 88...if the last 8 is blinking the sections on the right side of the eight it looks like an E...but it is not.,..it is blinking an R1 b, or R1 c error. Looking at the chart R1 b is Sensor System in FF Compartment Errors, and R1c is Defrost Sensor Error in FF Compartment Errors.
I hope this clears things up as I see a lot of people say there panel is flashing 88 8Y, or 88 8E when actually it is just different parts of the 8 blinking.
Feb 20, 2014 | Samsung Refrigerators
Error code 88 88
The 88 88 code indicates a modem communication error in the refrigerator. This error is not applicable in the U.S. It should be ignored. The control will conduct a self diagnostic check when it is powered up. When this code is encountered it will just need to be cleared and the refrigerator will resume normal operation. To clear the code, press and hold the POWER FREEZE and POWER COOL buttons simultaneously. NOTE: Be sure to press these two buttons at EXACTLY the same time -- no sound will be heard when the buttons are both pressed properly). HOLD the buttons down for about 8 to 12 deliberate seconds until the control beeps and goes blank. Leave the control in this diagnostic test mode and allow it to exit after it times out in that mode. This will take several minutes. When the test mode clears the fault code 88 88 and returns to normal operation, you should be able to set the controls on the unit and it will work normally.
Frank V.
Jul 22, 2012 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
Error 88 typedrive not connected
Tapeware error 88 refers to a tape drive not being found. Make sure you have disabled removable storage in services. What tapes are you using?
you can find your tapeware error codes by going, Start/Programs/Tapeware/Tapeware Documentation/printable documents/Tapeware error code reference
May 22, 2010 | HP StorageWorks DAT 72 Tape Drive
My Singer 7436 keeps getting an error code 88
I have been having the same thing happen. I just discovered the bobbin winder was in the wind position. I moved it and I am in business again! Hope it works for you!
Apr 11, 2009 | Singer 7436 - INGENUITY
Having sharp Photo copy, Model-AR121. It is not working. Pls. provide me service center.
Sharp AR-121 code
CC Original not detected E1 00 Lost communication with the Sorter 10 Lost communication with the Sorter 11 ASIC error 12 Image Processing Unit error 13 ROM error 14 NVRAM error 15 Page memory fault 16 SIMM not present or installed incorectly 17 Page rotation error in RAM 80 Electronic sort board error 81 82 84 88 E7 03 Lens position error 04 White level calibration error 05 Black level calibration error 12 CCD calibration error F1 06 Shift sort motor overloaded F5 02 Exposure lamp blown F6 00 Fax board problems 10 80 81 82 84 88 F9 00 Printer board problems 10 80 81 82 84 88 H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded 10 Separation motor overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error U2 04 EPROM error 11 Main counter error 12 EPROM error U3 29 Mirror position error U9 00 Op panel problem 81 82 84 88 U95 Firmware error
Apr 08, 2009 | Sharp Office Equipment & Supplies
I have maytag neptune 5500- shows error code 88
When the 88 displays, put a heating pad over the display - it will be ready in just a few minutes. Sounds crazy, but it works every time.
Jan 10, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Braun BP-5900 ExactFit Blood Pressure Monitor Logo
62 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
