Question about AO Smith Pool & Spa
Capacitor numbers rubbed off my original capacitor . The pentair pump s/n is 717747520, 1 1/2 hp,8.0/16.0 amps,230/115 volts.3420 RPM. Thank you Ken
  • 3,103 Answers
Go top the pentaire website and see if they can assist..
Posted on Jan 11, 2014
5 Suggested Answers
  • 114 Answers
SOURCE: I have new pentair 1 hp pump that was intalled by
to open the basket the pump needs to be off. all drains and the skimmer needs to be shut. otherwise all the water from the pool will leak out... now when you have done all of that. there should be a ring around the lid you take a hold of that and twist. it can be alittle stiff at first.. When you get that ring off the lid will pop off. now water will come out of it becuase it's just what's in the pump and in the line. once the water is out you can take the basket out and clean it. Now very important. when you put the lid and the locking ring back on open the skimmer and the drains to get water back into the pump. If the pump is not filling up go ahead and automatically put water in there until it's full. once the pump is full you can turn back on the pump and everything should work fine. if you have any other questions please let me know.
Posted on Aug 19, 2009
MOTORWIZJ
  • 1368 Answers
SOURCE: I have a pentair 1.5 hp 177475 pump i would like t...
ITS ON THE LABEL ON THE MOTOR HOW TO .. ITS BY MOVING THE BROWN AND WHITE WIRES
Posted on May 29, 2010
  • 760 Answers
SOURCE: MY PENTAIR 1HP PUMP WILL
If it does hum, but not start it couuld be the capicator. Check to be sure the motor turns free. If it does and won't start , and it has a capacitor (hump on motor or in back cover) try replacing. (Be sure motor is turned off)
Posted on Aug 12, 2010
heatman101
  • 43501 Answers
SOURCE: What are the specifications for
Take the cover off of the capacitor...it is the bump on the top of the motor...then look on the capacitor and find the numbers that end with mfd. that is the size or rating of the capacitor...also then look for the voltage of the capacitior...you need to match that also...there are so many different motors used, even for the same pump that it is hard to say for sure what you may need there with out looking at it.
You can do that and then you know you are getting the correct cap for your motor...
My guess is that you are looking for something in the range of a 20mfd 370volt cap. but please check it out for sure they vary alot!!
heatman101
Posted on Aug 28, 2010
Need advice on capacitor purchase for pentair spa pump
There are so many models of what may appear like the same motor, but the internals may vary????
If you can take off the cover & look at the capacitor itself, that is your best bet. You need to at least be at the equivalent of the same range of MFD!!!! Example 72 - 93 MFD!
You can go slightly higher, but not by much!
If you can't read what you currently have, then contact Pentair directly. They may be able to assist you with the right information.
Here is a link for your assistance...
Contact Pool Expert PENTAIR
Apr 27, 2015 | Pentair 1.0 Hp Whisperflo Pump
Rheem condenser fan motor
"the guy" added another start capacitor because the motor installed is actually better than spec. Your unit calls for 1/5 HP, 1050 RPM motor. The installed device is 25 rpm faster, and 1/4 HP.
The Rheem/Weather King/Corsaire/RUUD part number is 51-23055-11 (replaces many other Rheem/Corsaire/Weather King/RUUD Part #s including 51-21855-01)! It takes a 3 uf Capacitor rated at 370 volts. This Motor mouts with screws in the SIDE, instead of mounting studs coming out the back!!
Normal price for a generic motor w/ cap will be $125 or so, OEM part will be closer to 200. This is without the fan blade. Make sure you get the correct side mount studs.
This vintage unit is rated at only 10 SEER and is less energy efficient than a modern window air conditioner. Its days are numbered, and you are paying at least double every time it runs. Before you sink much money into this unit, please consider replacing it before it has a heart attack. Replacing it during the off season is cheaper anyway.
Please mark my answer down as helpful.
Jan 05, 2015 | Heating & Cooling
Wiring pentair 3 hp 230v pump
see side of motor should only be 220 volt 1st hot to L1 2nd hot to L2 green to case or ground
May 01, 2014 | Pentair Challenger Energy Efficient , 3...
Wiring schematic for MTB217 cooper b line
I would suggest taking a closer look at the motor name plate. I am not familiar with a 120/240 three phase service. When I checked the web it shows: Voltage 115/230 (that is single phase), Max Amps 115 Volts = 19.2 Max Amps 230 Volts = 9.6 , Single Speed, Square Flange, RPM = 3450, Threaded Shaft, Frame = 48Y Used on the following models: Sta-Rite Max-E-Glas, Max-E-Glas II, Dura-Glas, Dura-Glas II, Dyna-Glas, Dyna-Max Pentair Whisperflow, Pinnacle and Anthony AR2 Series. You should also show what voltage you are connected to.
Mar 14, 2014 | A.O. Smith SQ1102 Pool Pump Motor
I bought a fan motor for my hp 2100, when i went to swap it i found the new fan had 1 less hot wire than the old 1. when i installed it, it does not work. could i have bought a 110 motor when i need a 220?
old motor has data needed for replacement. hp, sf ,rotation ,rpm, volts and amps.plus capacitor size required. the extra wire can be for a capacitor conection usaly brown in color and if you look at the label it will tell you how to eliminate the need for this wire.
Aug 21, 2013 | Hayward Heat - Pro 2100 Heat Pump Pool...
Pentair challenger hums but does not spin
check wiring see side of motor 120 volt vs 240 volt if 120 volt have to move some wires
Oct 02, 2012 | Pentair 2 hp Challenger Pump
Capacitor type
take capacitor to electric supply store to match up
Apr 20, 2012 | Century New Magnetek Pool Spa Pump Motor...
A.O smith pool pump tripping breaker
It you either have an impeller problem or capacitor problem on the motor. I would take the capacitor off and take it to a electronic or lexical shop to have them check it. It's only about 15 to 20 dollar pics if it's just your capacitor.
A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS YOU.
Apr 08, 2012 | AO Smith 1 hp 3450rpm 56Y Frame 115230...
Pentair superflo electrical wiring
if 220 volts 2 blues 1 to L1 one to L2 green to ground or case
Feb 08, 2012 | Pentair Super Flo 1 Hp Pool Pump 340038
How to connect the Dayton Capacitor Start Motor to 230 volts ?
In the **********, the screws will be market L1 & L2. There will also be a jumper that needs to be connected between the 2 terminals for 230V.
Aug 28, 2009 | Dayton Permanent Split Capacitor Motor Fan
Pool & Spa Logo
53 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Larry Maranto
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
