Question about Dryers
Kenmore Diagram no agitation, no drain, no spin and timer doesn't advance.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
What appliance is this? I suppose washer that wont start. Or does it fill and does nothing else?
Check power supply. Check Lid switch if this is a top loader machine (lid on top)
More info would be helpful.
Posted on Oct 19, 2013
4 Suggested Answers
watugot
  • 290 Answers
SOURCE: kenmore agitates doenst spin
There are 3 things that may be wrong.
The timer is keeping the transmission in neutral drain.
The clutch is slipping.
The basket drive block that supports the basket has failed.
Aimiel is correct that you will need to see what is happening during the spin to diagnose the problem. Please post the complete model number from the top under the lid and I will try to walk you through checking it.
Thanks/Mike
Posted on Dec 23, 2007
  • 198 Answers
SOURCE: agitator grinds and won't spin
You have a broken motor coupler, you can see how it is replaced on samurai appliance guru
Posted on Jan 18, 2009
  • 784 Answers
SOURCE: agitator humms and won't move
It hums since the motor is still working. However the mechanism for the agitation is not working due to the helix part worn out. Need to replace it. If the service man is coming, have him to check the spinning mechanism also, since the same labor for the 2 mechanism. if the agitation mechanism worn out then the spinning mechanism is going to wear out soon. Now keep in mind that the clutch and the brake for the spinning mechanism are hardly worn out, only the part pushing up to release the brake is worn out. Keep this in mind to prevent overcharged.
Posted on Jan 09, 2010
How to move around brandt wm 550
see this causes and fix it. God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Sep 22, 2012 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
Aug 01, 2012 | Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
    Jan 21, 2010 | Kenmore Washing Machines
    End of wash cycle, no draining or spinning, but can move to rinse cycle and it agitates again, no spinning after rinse either
    This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
    First, see the Sears parts site for your washer:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number and you'll see a list of major sub-components with diagrams and parts.
    The drain and spin functions are started when the timer advances to the spin mode.
    The motor is reversible. When agitating, the motor spins one way, when going to the drain / spin mode it reverses.
    Since the machine agitates, the problem points to the timer.
    Sep 04, 2009 | Kenmore Washing Machines
    My machine loads and agitates, but will not drain, rinse or spin
    If this is a top load machine check the lid switch.
    If you manually advance the timer to spin, open then close the lid, and get no spin, it is a bad lid switch.
    If it does spin, report back for the next step.
    Apr 21, 2009 | Kenmore Washing Machines
    As washer was on final spin cycle it sounded like a belt came....
    Apr 01, 2009 | Kenmore Washing Machines
    Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
    Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
    May 23, 2008 | Kenmore Washing Machines
    Dryers Logo
    Top Dryers Experts
