Question about Haynes BMW 3 & 5 Series Repair Manual covering 318i 1984 and 1985, 325/325e/325es 1984 thru 1988, 325i/325is/325iC 1987 thru 1991, 525i 1989 and 1990, 528e 1982 thru 1988, 533i 1983 and 1984, and 535K/535is 1985 thru 1992 for gasoline engines and two wheel
Bypass starter solenoid
Car wont start after a cable ****,p was changed. new battery but starter doesn't even try. Ju7st a click is all i get!
    Scholar:
  • 57 Answers
You're in the appliance section for a car problem...however, I had that same issue after my car sat for 10 days. I made sure the jumper cables were good and then let my battery charge on my buddy's car for about 20 minutes. When I tried it then, it worked fine. But then again, I'm better at appliances than I am cars
Posted on Oct 19, 2013
2003 ford explorer wont start hear a click under the hood, i tried to jump it and it wont start. do u think it needs a starter?
Go under the car and have a helper hold the key in the start position while you probe the wire to the solenoid for 12 volts, also do a voltage test on the positive battery cable and inspect it at the battery for acid intrusion near the positive battery post clamp, if acid has gotten into the cable the outer insulation will appear swollen and the cable must be replaced, this is a common cause of no starts on Explorers.
Jun 11, 2013 | 2003 Ford Explorer Sport
My 93 dakota wont turn over at all new battery all wires checked not even a click could it be safety nuteral switch can i by pass it?
If you used a battery cable to the big post
on the starter that the battery cable goes to & it does
nothing,then the starter is bad
You can put battery voltage to the solenoid
Neither test requires the key be on,you going direct
Dec 22, 2012 | 1993 Dodge Dakota
Why doesn't my honda accord start. i didn't have any problems with it starting prior to changing the battery and now the starter wont turn over even with a jump start. everything works with ne
you most likely have a lose or bad connection. clean and tighten clamps on battery. push them down and wiggle them while lose then tighten.
Sep 24, 2012 | 1995 Honda Accord
Ok brand new starter and all the lights and horn work but the car will not even turn over. it does nothing can you help??
I had this issue with my car. its really common in GM cars.. I found this site that sells a way to bypass it. It will save u a ton of money and the site has great customer service if u have any problems .. check it out I hope it helps ya Do It Yourself GM Security bypass
Sep 02, 2012 | 1999 Buick LeSabre
It wont start, just makes a clicking noise. put new battery cables on, new starter, new cylinoid. tried to jump start it, wont jump start either
Clicking noise usually means a bad connection at the battery terminal. It can also be a bad connection at the starter or solenoid.
Re-clean and tighten battery cables,and if that doesn't do it,re-tighten starter connections.Don't overtighten as copper-bronze studs can break easily.If your Ranger is standard shift (4 or 5-speed), don't get under the car or in front of it without the battery cables disconnectede or the shifter in neutral,as any current you inadvertently send thru the starter can engage it and run you over or knock the vehicle off jackstands or blocks. don-ohio
Oct 13, 2011 | 1992 Ford Ranger
1992 acura,my car wont start,not even cranck . head lights,and dashboard work, but dont cranck.
What happenes when you try to jump start the vehicle? If it starts - then it is most likely the battery or alternator. If it doesn't start then the solenoid or the starter or the engine. To get it down to the starter or engine - disconnect the serpentine belt and turn the crankshaft with a wrench. If it turns - then it is your starter/solenoid.
Jul 19, 2011 | 1992 Acura Legend
MY ford tempo is not starting i changed the distribuator cap and router and alternator and got new batterie now the solinoide off of the starter on driver side fender is ticking when trying to turn car...
ether a bad solenoid or a bad starter. Assuming you cleaned all the cable connections.
Put in park and and try bypassing the solnoid with a jumper cable. Battery positiv post to starter.
Be careful
Mar 25, 2011 | 1990 Ford Tempo
Click when trying to start
Sounds like battery and battery cables full of resistance and battery may need replacement or charging.
May 21, 2010 | 1995 Nissan Pathfinder
Turn key and nothing happens, replaced the starter, now it is only clicking from the new starter. I have a new battery instaled that will show 12 volts on my dash when connected to another battery jumping...
if you replaced the starter with a remand unit it could still be a bad starter(personal experience),but if your battery show 12v only when being jumped your battery is having issues,take the battery and have it checked if it was replaced before the starter it could have problems due to the starter drawing to much at once and not recovering,and also have the alternator checked out this will kill a brand new battery very quickly even with nothing on.
Jan 03, 2010 | 1998 Cadillac Seville
Car wont start
Does the battery have enough capacity to turn over the engine though? Even flat car batteries will still power the radio. The best way would be to jump start the car uing a set of jumper leads. If it starts you know it is the battery that needs replacing.
If it still wont turn over then it is most likely the solenoid in your starter motor. You can often tap the starter motor with a hammer and free the solenoid as a temporary fix. The starter motor is loacted at the back of the engine on the bell housing if rear wheel drive, or around the tranmission if a front wheel drive.
Jul 25, 2009 | 1998 Ford Contour
Haynes BMW 3 & 5 Series Repair Manual covering 318i 1984 and 1985, 325/325e/325es 1984 thru 1988, 325i/325is/325iC 1987 thru 1991, 525i 1989 and 1990, 528e 1982 thru 1988, 533i 1983 and 1984, and 535K/535is 1985 thru 1992 for gasoline engines and two wheel  Logo
96 people viewed this question
Top Haynes Heating & Cooling Experts
Mike
SimplyNo
Lawrence Oravetz
Are you a Haynes Heating and Cooling Expert? Answer questions, earn points and help others
