Apa penyebab lampu indikator kedip pada indoor ac split daikin inverter
SOURCE: I have daikin split ac and it stops suddenly and blink
trying to get the panel to work. Its blinking and won't accept commands.
tried new batteries..still does'nt respond
Posted on Aug 29, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
  • 9 Answers
SOURCE: Hi I have 1.5 ton samsung split AC. the problem is...
the water comes from the coil, start there make sure there is no obstruction coming out to your condensate line and make sure its properly pitched.
Posted on May 22, 2010
  • 81 Answers
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
heatman101
  • 43501 Answers
SOURCE: Daikin Inverter Split system turns
There are quite a few things that can cause the symptom you are describing there...
The most common would be for you to have a refrigerant leak in the system that is causing the outdoor unit not to run, but the indoor unit still will run...
Often there will be a diagnostic LED on the outdoor unit that will help with troubleshooting...
Of course also a good thing to try is to remove all power to the unit indoor and outdoor...and then reapply the power and see what happens...this may correct the fault...
here is a tip that also will give you some things to check....
Feel free to comment back with any more questions...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Feb 05, 2011
Bagaimana cara mengatasi code P07 pada canon MG2170
Saya mengalami masalah di printer yang sekarang sedang saya gunakan yaitu pixma canon mg2170. Setiap kali saya nyalakan tombol power, di lampu LED nya terdapat numberic "P", "0", "7" begitu seterusnya berganti-gantian dan lampunya kedap kedip. Solusinya bagaimana?
Aug 26, 2013 | Canon Office Equipment & Supplies
Lampu indikator toner menyala
gan mohon bantuan pencerahannya, di kantor saya memiliki printer LQ 2190 saat ini memiliki kendala lampu indikator merah nyala semua dan printer tidak bisa nge print, itu di sebabkan kenapa ya gan, dan bagaimana cara memperbaikinya
mohon bantuan pencerahannya ya gan
Feb 07, 2012 | Brother HL Office Equipment & Supplies
Lampu warning,lampu handbrake menyala,apa masalah
Ada dua kemungkinan yang terjadi,pertama masalah di switch handbrake,kedua check kondisi minyak rem.Pada masalah yang pertama adalah check switch,kabel dan koneksinya,apakah semua berada dalam kondisi yang baik.Anda dapat menggunakan multitester untuk mengecheck nya.Pada masalah yang kedua adalah,periksa level minyak rem,karena apabila minyak rem berada pada level tertentu (Min) akan membuat lampu handbrake menyala sebagai tanda peringatan (Warning).Mudah2an penjelasan ini dapat membantu teman2,terima kasih.
Aug 20, 2011 | 2007 Toyota Camry
Kaluu lampu epson L200 teru menyala dua duanya..?bagai mana cara memperbaikinya..
mas kalau printer epson l200 lampu kertas, tinta n powernya 33 kedap kedip itu knpa y mas,,?
mohon solusinya,,,
Aug 01, 2011 | Epson STYLUS R230 InkJet Photo Printer
There is an indicator light on the dashboard that i don't realize what its for.
pertama cek sekring sudah putus pa belum, cek lampu indikator putus apa tidak
Jun 16, 2011 | Volkswagen Passat Cars & Trucks
Aku punya printer samsung ml1640 pas power dinyalain keluar indikator lampu merah-orange, kemudian printer mati total
saya punya printer samsung ml-1640, sata powerdinyalakan lampu merah dan kining nyala semua (hank) itu kenapa ya?.... mohon bantuan dan pencerahannya Thnks
Jun 13, 2011 | Samsung ML 1750 Laser Printer
Error pada mesin cuci lg 6.5 g kode dE disebaban oleh apa?
m.cuci lg toplouding error DE. pada dasarnya pintu atas dilengkapi swich tapi kenapa model ini kok gak.terus gimana cara ngatasi door swich ini. mohon pencerahan
Jan 17, 2011 | LG Washing Machines
Sisa toner di sekitar cleaning blade mesin canon ir 5000 mengeras apa penyebab dan solusinya
bagaimana cara mengatasi kode error 804 pada canon ir5000, lampu scanner kedip-kedip pada saat mesin start.
Nov 21, 2010 | Canon imageRUNNER 5000 Copier
May 28, 2010 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
159 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
