Question about GE GSS20IEP Side by Side Refrigerator
I heard a loud fan/blower noise in the night and found water dripping from melted ice. The noise seemed to be coming from the back of the ice maker. I dumped the ice and turned the circuit breaker off and back on. The noise is back to normal and the freezer is making ice cubes. The fridge side is still only back down to 47, but I have been opening the doors to check every 30 minutes so it may just be taking a while to cool back down. I have noticed over the last year or so that that same fan makes a vibrating noise every once in awhile. Should I replace the evap fan motor?
    Genius:
  • GE Master
  • 1,859 Answers
-Don't have to.
-Any nut to hold the fan...? If so the nut might be loose. Or the fan blade bend.
Mai
Posted on Oct 18, 2013
  • 1314 Answers
SOURCE: ice-maker problem
ok do you have a meter a volt meter ill tell you a better way to do it go to the back of the refrigerator and un plug the water valves then open the freezer door turn on the water if you hear the water running replace the valves if you don't replace the ice maker module the range for pressure is 30-120psi the valve just might be sticking from being dry for so long
Posted on Feb 01, 2008
SOURCE: Freezer fan noise
What you need is a new updated computer main board. Thay are fairly cheap and easy to install. My GE Side By Side did the same thing and the new motherboard worked like a charm. I think that this is the one you need but you can email the seller with your model number and he will tell you which one to get WR55X10552 GE Refrigerator Mother Board fits WR55X10335s.gif GOOD LUCK
Posted on Mar 04, 2008
tborn6
  • 700 Answers
SOURCE: water coming from ice maker freezing down back wall of freezer
check for levelness of the ice maker also make sure that the fill tube is inserted all the way into the unit
Posted on Apr 25, 2009
jumptrout51
  • 3361 Answers
Remove the freezer panel to access the fan motor. Look for any obstruction around the fan or blade. Ice, misplaced wire etc.
Check the fan blade. Sometimes they slip down the shaft too far.
If you find none of these issues, replace the fan motor.
Posted on May 25, 2009
  • 6 Answers
SOURCE: blower fan in the freezer is making a vibrating
only if the fan noise is driving you crazy. the noise is probaly the motor starting to go out. you can replace it. it might save you money in the long run to replace it, if it goes out you could run into bad food in your fridge.
Posted on Sep 23, 2009
I get a loud grinding noise from my ice maker. What can make that noise?
Thank you for your information you provided, could the noise be described as a clicking or ticking noise? The reason I ask is I have heard for this to be a motor driven harvest and the heating within the ice maker is not engaging to release the ice, so the unit continues to push the ice out causing the gear to jump a tooth. If this is the case the only fix is replacing the ice maker to fix the issue. Other possible cause of grinding is the water in not entering the ice maker (hollow ice cubes) so the water is accumulating around the fan motor and freezing up. As the fan turns on the grinding is the fan motor cutting away at the ice. Gain access to the fan motor and check for ice around the fan, if its there remove that ice. The cause is that the water is not getting into the ice maker and causing this issue. Good Luck, I hope this helps.
Aug 30, 2014 | Frigidaire FRS6HR45KS (26 cu ft) Side by...
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
Whirlpool refrigerator model ed5phexnloo loud noise & ice build up.
If this unit has a ice maker, when it fills the tray, water spills out around the fill tube. The water drips down and builds up around the fan over time. Need a drain line extension to slide over water line, should take care of issue.
Aug 18, 2012 | Whirlpool Refrigerators
Loud humming noise coming from freezer
I believe what is happening, is your Evap fan has some build-up of ice on it. The reason it stops when you open the door, is the Evap fan cuts off. The Evap fan starts back up when the door is closed. What you'll need to do, is open the freezer door, and remove the back panel of the freezer. This takes some 1/4 inch screws and a couple Phillips I believe. Once you get the panel off you'll be able to see if there is any ice build-up on the Evap fan. If need, be take a hair-dryer on medium or low, and melt the ice off of it. This should solve your problem.
Mar 28, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Fan makes noise on LG lsc26905tt. defrosted and
Sounds like ice is building up near the fan blades. Try defrosting it longer to melt out all the ice and see if that helps.
Nov 09, 2009 | LG LSC26905TT Side by Side Refrigerator
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
Ice maker quit working
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Sep 07, 2009 | Refrigerators
Ice maker seems to be dripping water onto ice in ice container
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Watch it when it fills with water. The fill tube could also be stopped up with ice. The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Jul 12, 2009 | Kenmore Freezers
Whirlpool Side By Side Refrigerator
1. How do I get repairs done under warranty?
* If your refrigerator is under warranty, you must use an Authorized Service Company.
An Authorized Service Company can be found by using our Service Locator. Enter your zip code on the Service Locator to get a listing of available service companies in your area.
Back
2. How do I order parts?
* Parts can be ordered through an Authorized Frigidaire Parts Distributor.
An Authorized Parts Distributor can be found by using our Parts Distributor Locator. Enter your zip code on the Parts Distributor Locator to get a listing of distributors in your area.
* You can call our toll-free number to order parts (credit card orders only.)
Please call 800-599-7569 M-F 9:30am - 5:30pm.
Back
3. Noises / Sounds.
* Dripping sound.
* Running water.
* Vibrating or rattling noises.
The following can be sources of these noises:
1. Dish vibrating on shelf - move dish slightly.
2. Floor is uneven or cannot adequately support refrigerator. Use shims or extra support.
3. Items on top of refrigerator are rocking. Place a pad under the item or remove.
4. Refrigerator is not level. Adjust leveling legs or rollers as needed. Add shims in the back if floor is not level from front to back.
5. Refrigerator is touching wall or cabinets. See your owner's manual for space requirements.
* Snapping or clicking sound.
If your refrigerator is equipped with an ice maker the water valve will snap on when the ice maker is calling for water. This is normal. In some cases you may not have the water connected to your ice maker and the sound will be greater. In these cases, pull the wire signal arm (bail arm) on the ice maker in the up position to turn your ice maker off until the water supply line is installed.
Back
4. Taste and odors.
* Ice or food has a bad taste or odor.
Ice and uncovered foods can pick up odors or taste from strong smelling foods in the refrigerator or freezer. Cover foods tightly and discard old ice.
* Ice tastes like plastic.
Plastic water lines will give off a taste when first used. It takes one or two containers of ice for plastic to stop leeching. Discard initial container of ice after installation.
Back
5. Ice maker - not making any ice.
* Freezer may not be cold enough.
Temperature must be 5 F. or colder to work properly.
* Water supply valve may be blocked or restricted.
Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
* Water supply valve may not be open.
Find and open the supply valve.
* Wire signal arm on ice maker is in the up position.
This position shuts off the ice maker. Pull wire arm (bail arm) down to start ice making.
Back
Sep 05, 2008 | Whirlpool ED5FHEXMQ Side by Side...
GE side by side water dispencer area Leaking
* You can also schedule service by calling our toll free number:
800-374-4432 M-F 9:00am - 5:30pm.
Back
Back
3. Noises / Sounds.
* Dripping sound.
* Running water.
Back
4. Taste and odors.
Back
Back
Sep 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS20IEP Side by Side Refrigerator Logo
71 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
