Question about Zebra Office Equipment & Supplies
We tried to replace the print heads on 2 of our Zebra Z6M/ZM600 printers. It shows error 'Invalid Product' on the display. It is genuine Zebra part no G79058M from our regular supplier. How can we resolve this error?
    Top Expert:
  • Zebra Master
  • 41,738 Answers
I suggest that you consult your supplier as to why this is happening
Posted on Oct 18, 2013
4 Suggested Answers
  • 9 Answers
SOURCE: zebra s4m error condtion paper out
Sounds like you will need to perform the calibration procedure.
when you access the menu system go to advanced menu, the password is 9999, use the keys to navigate to manual calibration and follow the instructions. when it states load backing this is refering to backing paper, so remove the labels from the backing and place in label path. hope this helps
Posted on Jan 27, 2009
bartech9
  • 155 Answers
SOURCE: printing error condition
First clean the sensor tag and sensor head open and tape. Then perform a calibration label pressing the PAUSE and FEED buttons and turn on the printer, release the keys until it starts to move the label. Wait until you are finished and ready to print.
Posted on Mar 16, 2009
SOURCE: Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Posted on Nov 16, 2009
How do i fix the error in Zebra ZM600 printer and error is ERROR CONDITION INVALID HEAD
You may have problem with your Printhead cable or Logic, I'd start by re-seating the cable on both ends. If that does not work I'd replace the PH as it will wear out eventually anyway if it is not the problem you can keep it as a spare. The ZM600 will take both a 203 and 300 dpi Printhead make sure you get the same one you installed currently.
203 dpi
MRP provides IT Parts Product Supplies and Services
300 dpi
Jul 11, 2015 | Zebra ZM600 Printer
Zebra Z6m Error Paper Out
sensor not working or dirty in the feed path id suggest
Dec 27, 2017 | Zebra Z6M Plus Thermal Label Printer
How to printer test page from the display panel zebra zm600
With most Zebra printers, a test page is printed by pressing and holding the PAUSE key while turning on the power. Keep pressing the PAUSE key until the printer completes the POST (power on self-test), then you can let go. A test pattern will begin printing. You can stop the pattern by pressing PAUSE. Turning the printer off & on again is the fastest way to end the test. This is a good page to print because it prints a large black box and it's easy to see if there are any printhead elements not functioning. It's best to use the largest, widest label you have for this test.
Hope that helps !
Aug 29, 2011 | Zebra ZM600 Printer
I have a brand new Zebra ZM600 with new ribbon and new label. However, it is only printing half of a ticket, and what it does print is very faded.
If the problem is on the right side , try adjusting the head pressure adjustment knob on the top right side. You can adjust with a flat blade screw driver.
Feb 28, 2011 | Zebra ZM600 Printer
I have one z6m and the error is: Printhead open.but the printhead is closed. Please help me. Thank you.
push down the print head assembli and you will see what the probles is then ajust it.
Jul 07, 2010 | Zebra Z6M Plus Thermal Label Printer
Same Problem with Z6M
Your Logic bd needs to be replaced or repaired.
Rory
Midrange Repair and Parts
Sep 02, 2009 | Zebra Z4M Printer
Z4m zebra printer problem
Might foul the ribbon sensor, clean the sensor and try to print again.
Mar 02, 2009 | Zebra Z6M Plus Thermal Label Printer
Printing error condition
Feb 27, 2009 | Zebra Z6M Plus Thermal Label Printer
Z6M printing issue
try adjusting the presure of the printhead
here is the site for the manual
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
good luck
Dec 12, 2007 | Zebra Z Series Z6M Thermal Label Printer
Open Questions:
128 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
