Question about NEC VT700 Projector
Reset lamp light without remote - NEC VT700 Projector
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
Reset lamp counter without OSD
press the "help" button for 30 seconds
Feb 14, 2014 | Office Equipment & Supplies
Can I reset the lamp timer without the original remote
No, original remote is needed for this--a universal will not cut it.
If Panasonic the remotes are usually reasonably priced and have all the features you really need.
Mar 26, 2012 | Panasonic PT-50DL54 50" Rear Projection...
How do i remove the black box on my screen
don't have the original remote control, I used the time warner control, I just reprogramed to control my tv without the cable box, I put the volume all the way up in the tv, then down to zero, and at the same time I hold the 0 key in the remote control, after that the screen said lamp has been reset to zero, I repeated this step because a lamp red light stayed on, after this only the power green light only stays, when installing the new lamp make sure is all the way in, you can use the white out to mark exactly where you have to push or put in the new lamp, it may not been all the way in, hope this help someone !!
Jan 18, 2012 | Panasonic PT-50LC13 50" Rear Projection...
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    How to reset lamp timer without remote
    you cant, when you remove and replace the lamp cover the tv will come on and ask if you changed the lamp. you need to press enter on the remote (not the tv) to reset the counter. go buy a universal remote and program it to your tv then use that. make sure the remote you buy has an enter button. most should, but you never know.
    Jul 06, 2010 | Mitsubishi WD-52525 52" Rear Projection...
    Reset Sony VPL-CX6 WITHOUT REMOTE ?
    if you can't through the menu, you do need the remote.
    Nov 02, 2008 | Office Equipment & Supplies
    Lamp Hour Meter
    This proceedure should work for your model to reset the lamp meter.
    Lamp Time Reset Procedure:
    Be sure to reset the Lamp time to "0" after replacing the new
    Lamp.
    1. Plug in the AC Cord, and turn on the power by pressing the
    POWER button.
    2. Press and hold the VOLUME DOWN button on the unit and
    the SPLIT key on the remote together for over 5 seconds
    in power on condition.
    When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
    Mar 29, 2008 | Panasonic PT-50LC13 50" Rear Projection...
    Best but repleace bulb but red light still on
    So far I have entered the service menu (both menus together) then selected Lamp Replace (option 14) and then pres ok to reset. Version and Lamp (option 11) now reads Lamp life (Khr) = 8 and Lamp use (Hr) = 0.
    Jan 19, 2008 | LG RU-44SZ51D 44" Rear Projection...
    NEC VT700 Projector Logo
    Top NEC Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
