Question about Zanussi ZI918 / 12K Bottom Freezer Refrigerator
I have a zanussi built in fridge zud 9154a the fridge constantly ran as soon as I switched the thermostat dial on to just 1 even though the fridge was freezing.i have replaced the thermostat but it still doesn't stop running although it doesn't come and straight away now.
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: My Zanussi Fridge Freezer ZI921/8FF
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
The cold control needs replacing. Thats the knob with the numbers that turn the Ref OFF and ON.
What I do is call my local Appliance Parts Store with my model no. They are extremely helpful .
Get freezer and ref thermometer. Ref is probably too cold.
Freezer should be 0 to 10 degrees. Ref 33 to 35
If you need more help, Go here:
http://www.applianceaid.com/procedures.html
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Posted on Sep 06, 2011
Why does my Zanussi td4212w tumble dryer work but no heat?
check continueiy in the ellement and the thermostat
check the thermo with out 1 wire on........cheers
Jul 18, 2014 | Zanussi Dryers
Adjusting the settings on a fridge thermostat
You've indicated that you have changed the thermostat but the model number you have given is electronically controlled via an NTC. If the the unit is built in there is a possibility that one of the following is causing the problem
a. the seal is no longer catching properly because the decor door needs adjusting.
b. the internal lamp is not switching off when door closes and is creating heat that the fridge is trying to compensate for
or
c. the fridge fan is not operating and not circulating the air to the sensor. (You can check the fan and light by pressing the switch at the top of the fridge compartment frame, the fan should run and the lamp go off when the button is pressed).
Try these first and repost if this does not help.
Feb 04, 2013 | Neff K9724X4GB
How do I replace the thermostat switch on a Zanussi ZCE 7701CH? I have removed the screws for the side panels at the rear but cannot access the screws for the side panels at the front. The Product No...
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 18, 2011 | Zanussi ZCE7551X Electric Kitchen Range
My integral fridge has a small built in freezer at the top. The freezer door handle broke and the door would not shut properly. An engineer came out but brought the wrong part. He returned three weeks...
It is possible that in defrosting the built up ice on the freezer that you accidentally punctured a coil and that allowed the gas to escape. If you check the area you defrosted you may find a small nick. As the tech said, it should have nothing to do with the prior repair unless he was poking around in that area with something sharp. As for the long running that would not cause it to lose gas.
Jan 21, 2011 | Zanussi Z57 / 3 Bottom Freezer...
Idesit BAAN134 PSUK fridge keeps freezing food . The fridge part of my tower f/f keeps freezing food even though I have turned the dial down to the minimum the temperature regularly drops to below...
If it is an electronic thermostat it could be that the engineer has changed the board but not the sensor which reads the temp. If it is a mechanical thermostat it may be hes fitted the wrong type.It could also be that the system is short of refrigerant and the actual refrigerant charge is not getting all the way to the thermoststs sensor to switch it off, the back wall of the fridge should be frosted at least 3/4 of the way down and not just forming in a small part of the fridge.
Jan 05, 2010 | Refrigerators
What is the coldest setting on an old zanussi fridge freezer 1 or 6
hi there......the coldest setting on your fridge is 6
the normal accepted working temperature of a domestic fridge is usually between 0 and 8 degrees........the numerals on your thermostat are not temerature settings ...but a guide to coldness setting....the actual temerature must be checked with a reliable thermometer...usually best done in the morning after the fridge has ran throiugh the night without the door being opened.....
regards Sir Galahad
Aug 12, 2009 | Refrigerators
Faulty Freezer & Fridge
You have a defrost or temperature control issue or both. I will be back soon with photos and solutions. Thanks, Sea Breeze
Jul 13, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
THE FRIDGE FREEZER CONSTANTLY MAKES A GROANING SOUND AND NOW EVEN THOUGH ITS FROST FREE THERE IS FROST STARTING TO APPEAR ON THE BACK WALL OF THE FRIDGE
You could have one of two problems- 1) The defrost timer has failed OR 2) the defrost heater has failed.
Switch off fridge, open back panel check continuity of defrost heater. If it checks out OK you need to replace the defrost timer.
Jul 24, 2008 | Refrigerators
Zanussi ZI918 / 12K Bottom Freezer Refrigerator Logo
47 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
