Have Sony stereo model hcd-vx333 no power, when plug in I heard the relay click, after. 1 or 2 seconds its click again still have no power. Anybody have an idea? Please help me.
SOURCE: We have a sony stereo
Always be that legend for the audio amplifier IC damaged you need to replace him
Posted on Aug 12, 2008
  • 108 Answers
SOURCE: sony tv wont turn on, standby light just flashes
check for an open resistor on the power supply, it is actually a fusible resistor, (white) if open, then check the converter, some sets have two separate and some have it as one. it will be on a heat sink on the power supply. if shorted then check for a shorted horizontal output transistor and repair cold solder joints on the horizintal drive transformer which is the real cause of this problem
Posted on Jan 08, 2009
ravichetty
  • 158 Answers
SOURCE: Sony hifi system model hcd-lx9av requests!protect push power
CHECK UR AUDIO IC/STK
Posted on Feb 10, 2009
hbsurfdawg
  • 95 Answers
SOURCE: Won't turn on - relay clicks, power supply squeals, relay clicks, etc,
The television has a protection circuit. Sound like you know something about electronics so that is cool.
I suspect the HOT or High Voltage Transformer. If you want to operate on it, they typically will short externally from moisture or plastic high voltage breakdown. The TV starts, shorts as it cannot come to full high voltage, then shuts down. If your brave, you can unsolder the HOT which is the part that is on the main board or that comes from the top of the picture tube wire into a dark or spaceship type object.look underneath, sometimes they short underneath and you can scrap the carbon and get it to at least start up and work. Do not leave this as a fix as it can be a fire hazard.
The HOT is the most common. They are around 20-60 bucks. 34" TV. I am assuming this one without looking it up it is NOT a flat screen, as most do not squeal like that nor do they have to de-gausse like the old ones. I just looked it up and yes it is not a flat screen. Old school, so that is more thank likely the problem.
Posted on Mar 02, 2009
  • 188 Answers
SOURCE: no picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Posted on Jul 21, 2009
Sony hcd wz8d
Power attnae hooked up on amp for sure
Feb 25, 2014 | Electronics - Others
Sony system hcd-zux9 shots off power button flashing
My Sony - Model : HCD-GX 470 . When i turn the power on it is on . Just 30 seconds it turns off itself . I do not know what is going on ? Please show me OR help me to fix it .
Jan 06, 2014 | Sony MHC-GX450 CD Shelf System
I have a Sony HCD-451 home stereo. The sound goes in and out every few seconds and there is a clicking sound when it does. I just moved and when I hooked it up after the move it started behaving this way....
Diagnose first. Surgery last.
A big clue is that it started after a move.
Recheck your speaker connections for loose strands that might be touching each other.
If it still clicks and loses sound, disconnect all the speakers and see how that works out. If it's stable (no clicking) add speakers unr\till the problem reappears. Then isolate which one it is/was.
Jan 05, 2011 | Sony Audio Players & Recorders
I have a Sony receiver/tape deck/cd system, and need a copy of the owners/users manual in order to use the presets and other features to best advantage. The model of the unit is HCD250 or Hcd-G2000. I was...
http://www.givemefile.net/smanuals/hi-fi_hi-end--others/sony/hcd-g2000_26718.html
Above is a service and repair manual for the Hcd-G2000.
Below is your user guide.
www.devicemanuals.com/guide/.../Sony/Sony-Bookshelf-Hi-Fi-System-HCD-F250AV-User-Guide-TXpZek9EST.html
Support links for Sony below.
esupport.sony.com/
HCD250 service repair manual below.
http://www.givemefile.net/smanuals/stereos/sony/file/8297.html
Aug 24, 2010 | Audio Players & Recorders
I need a manual for my SONY stereo. The model no
manual availible at sony website
http://esupport.sony.com/US/perl/model-documents.pl?mdl=HCDHPX9
Oct 03, 2009 | Sony Audio Players & Recorders
No picture on my philips 42PF7321D/37
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Sony stereo model HCD G5500 will turn on but no sound comes from speakers. I tested speakers on other unit and they work. I have the back off. Nothing appears to be melted or disconnected. What else can I...
Check fuse in plug check onboard fuses if all good look for black or blue or ornge little rectangular boxes(relays) should click if not then protection problem and needs to be serviced
Dec 30, 2008 | Sony TA-N9000ES 5-Channel Amplifier
37 people viewed this question
 Grubhead
Grubhead
