Question about Dell 5100MP Multimedia Projector
Dmd dell 5100mp - Dell 5100MP Multimedia Projector
My 5100mp has audio in and out ports how do i make use of these
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip,color wheel, motherboard, powersupply ... with high quality and competitive price.
Jerry China Lampdeng Limited
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
http://www.lampdeng.com
Feb 28, 2014 | Dell 5100MP Multimedia Projector
Dell 5100mp projector fan is quiet when doing presentations on table top, but makes noise when ceiling mounted for home theatre. Noise get better after 20-30 minutes, but is just as noisy next time i...
turn it on when sitting on a table right side up. If possible, take the cover off and support carefully nearby the unit. Then slowly rotate the unit upside down and notice when the noise starts to get worse. Have a look at the fan area and see if there is anything that's causing the fan to make a worse noise. perhaps the bearings are getting worn out or something's not as titgh and vibration is being amplified by the fan unit.
Jun 07, 2011 | Dell 5100MP Multimedia Projector
My dell 5100mp is not getting signal from my IBM laptop
Hello.
Check your VGA cable (from laptop to projector) to be certain it is secure. Wiggle it to see if anything changes. Could be faulty.
Check the Function keys on the top row of your laptop. Note which key has "CRT/LCD" or an icon of a display. Hold down your Fn key and press that key. Try again and again and hopefully you will get a display from your projector.
Hope this helps.
Apr 08, 2010 | Dell 5100MP Multimedia Projector
Bulb Error
http://www.retrevo.com/support/Dell-5100MP-Projectors-manual/id/575bh227/t/2/
manual above. Also check, the Thermal Fuse, some have a little "Reset" button, to restore them check that. Also work through the troubleshooting section.
Mar 27, 2010 | Dell 5100MP Multimedia Projector
How do I open the case of the Dell 5100MP projector?
Remove the 5 recessed screws on the bottom and the two screwlocks on the m1 connector.
Feb 15, 2010 | Dell 5100MP Multimedia Projector
Dell 5100MP displays bands of color at the top and bottom of the screen. Light appears to show through the upper portion of the lens.
you have a collapsed light tunnel. it'll need to be replaced. but since dell doesn't sell the parts, you'll have to send it to them for repair.
Feb 03, 2010 | Dell 5100MP Multimedia Projector
Image is pink when you connect any laptop to the dell 5100mp projector
make sure the input is correct. chances are you have it on component. change it to computer (rgb).
Jan 20, 2010 | Dell 3200MP Multimedia Projector
Dell 5100mp dlp projector - white vertical lines evenly spaced
clock and phase are off. go into menu and reset the settings to factory default.
Sep 02, 2009 | Dell 2400MP DLP Projector
Dell 5100MP Multimedia Projector Logo
18 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
