Question about Hunter 90021 Century Table Fan
Open clean My fan is squealing and blades seems only run on high. I'd like to take it apart and see what's going on inside, but not sure how to do that. I have oiled it, but to know avail...can anyone help please.
    Genius:
  • Hunter Master
  • 1,617 Answers
Send it back to Hunter!!! Should be under warranty.
Posted on Oct 18, 2013
2 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: hunter ceiling fan
Motors work with magnets. These may be permanent, or more commonly elecromagnets. These are the rotor, and the field magnets. Another type of motor just uses a field magnet and iduces flux in the rotor.
Either way, it sounds like one of the main coil windings has either burnt out or mechanically broken.
If you want to remove it and test the coils with a meter (check resistance of each) this should show the fault.
If a coils burn't out. it's scrap .
Posted on Jun 11, 2008
High pitch squealing when i turn on fan
bearing gone or rotor blade scraping against outer cover
Dec 12, 2013 | Lasko 3520 20-Inch Cyclone Fan
Fan is making squeeling noise when running.
After reading dozens of similar problems on here about the Vornado fans squealing (and rattling) it seems they are in need of some 3-in-1 oil for the bearings and any moving parts in and around the motor area.
Also good to keep the fan clean by wiping down and removing front grill and the fan blade...A high pressure duster or spray air canister for the motor body etc. should get out any dust inside the unit.
good luck!
Oct 19, 2010 | Vornado 785 Stand (Pedestal) Fan
My mom's Kenmore HE3 Elite electric dryer vibrates rapidly while operating. She was cleaning out the lint catcher area with a toothbrush and dropped it inside, then decided to run it after several failed...
yes u have to now replace the blower fan housing u may be able to take apart and remove broken piece byt may not run properly or circulate heat and air as it suppose to
Mar 22, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do I get my cool operator fan apart to clean the darned thing
hi! there,
well! no brand and model,anyway the guard fan has a quick clip lockaround the fan blade,be sure to unplug your electric fan before doing this, unlock clip lock then the fan has a quick handy lock knob at the center of the fan observed loosening knob there is direction arrow in loosening this if i'm wrong going counter clockwise,or take the direction indicated marked on top of knob.
pull out the blade and have it clean if this is a plastic or aluminum clean it with water and spounge/cleanser,avoid to distorsion on fan blade if happen this will wiggle when run again be carefull and on the second guard fan still connected to your electric fan,there is plastic lock nut release and pull out the 2nd fan guard,try to clean this with water and cleanser,the motor assembly with control and stand just wipe it out ,don't try to get wet specially the motor,let all dried up before reassemble.reverse the process to eassembly
Apr 04, 2009 | Dryers
Rinnai mdl. 1001 LP does not light.
If your unit starts and runs for any length of time before quitting you may have a problem with the circulating fan blades. They need to be spotlessly clean. The filter is easy to get to, however the blades are not. Taking the circulating fan apart is a pain. A long brush that can get into the blades would work. You can blow them out with air but that gets everywhere. If the whole inside of the unit is linted over, all that stuff has to go. Be sure the lovers in the front of the stove are all open.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 21, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Noisey fan stops when door opens
Fan is supposed to stop when the door is opened . Noise from the fan could be a bearing problem if it is a high pitched squeal. If this is the condition you have , replacing the evaporator fan should correct the problem. If the fan is sounding like a buz-saw the fan blade could be pushed in to far on its shaft, or it could be hitting an ice build-up in the blade turning area.
May 26, 2008 | Refrigerators
Can here motor running but blades do not turn
go and take it apart and clean it afterwards. dont forget to put oil. you might want to check the carbon inside the motor, they may need replacement.
Mar 18, 2008 | Lakewood HV 18-c Floor / Box Fan
Remove blower blade from motor
A guy who has been repairing these for twenty+ years told me sometimes the blower fan is just too tight to remove. If so, you have to use a screwdriver or punch from the motor side and literally break the plastic fan apart. I thought that was going to be my problem, but..... With wrench tightly fastened to the nut at the back of the motor and resting against the post of the rubber wheel, I put a sturdy wrench on the shaft at the front of the motor and whacked it in a clockwise direction with a hammer. It snapped and came loose! Hooray. Try that before you demolish the blower fan.
Jan 15, 2008 | Dryers
Have had 2 9600xt's that had the fan motor start squealing
Try cleaning the fan with a can of compressed air ,make sure there are no wires close to your cooling fan blades. If this doesnt resolve the problem replace the fan .
Nov 24, 2007 | ASUS RADEON 9600XT, (128 MB) AGP Graphic...
Hunter 90021 Century Table Fan Logo
143 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
