Question about Samsung RF4287HARS French Door Refrigerator
We had a short power loss the other night and now the LED display panel has flashing I E, called Samsung they want to set up a service call. Is this serious and how can I get rid of this?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
TURN POWER OFF AND UNPLUG UR OVEN..WAIT FOR A WHILE AND PLUG IT BACK IN AND SEE WHATS HAPPEND...MOST OF THE TIME ITS JUST A AUTOMATIC RESETTING INSIDE THE OVEN...
HOPE THIS WILL SOLVE THE PROBLEM..IF THE OVEN IS STILL UNDER WARRENTY..THEN GET SAMSUNG SERVICE AND GET IT FIXED...
Posted on Oct 18, 2013
Samsung un39fh5000 shutdown no led start has info on screen usung a flashlight replaced both main and power supply bds chked led strips no burning visiable ohms reads high no short im stumped
T'Con board fault. With most modern models of Samsung LCD sets, this board is a built in part of the display panel. If it is a separate part (in case of your set); replace it. Check it out.
If it is a built in part with the display panel, there is no repair other than replacing the display panel.
Aug 26, 2016 | Samsung Televison & Video
Samsung ln40b630 led back light flash on and off
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Nov 19, 2015 | Samsung Televison & Video
My TV will not turn on. It has a flashing red light on the small display
Is the power button just flashing, is this what you mean by 'smal display'? Try troubleshooting with the instruction manual. Check the aerial/antenna is properly connected and functioning etc. If no joy just return it to the retailer for service of your warranty.
Jun 12, 2015 | Televison & Video
Display panel flashing 93 E
Warranty?? Call immediately Samsung Customer service if under warranty. according to: http://www.appliancerepairlesson.com/tag/samsung-refrigerator-error-codes/ e84 was a new error code in 2013 and covered under warranty.
Mar 13, 2015 | Samsung Refrigerators
BLINKING GREEN LIGHT AND WILL NOT POWER UP
You can check the Error code by doing the following.
On the Front panel hold down the Device and Menu Button for 5 seconds. The LED light will then start flashing the first set of flashing lights is for the "1"5 part of the code it will then pause for about a half second and start the ones place 1"5". The code will repeat 5 times before going off.
The Error Codes: 12 - Normal Operation; 21 - X-Ray Protect; 22 - Short Protect; 23 - Loss of Horizontal Deflection; 24 - Loss of Vertical Deflection.
The problem may also be in the power supply when you first plug the device in check how many times the Led blinks if it blinks for just over a minute the power supply is working fine. If the Led blinks repeatedly and does not stop the DM is not running.
This is a link to the service manual for you TV,
http://www.service-manual.eu/model.php?id=2710
Mar 02, 2011 | Mitsubishi WS-65909 65" Rear Projection...
I have a Samsung LE40C530 lcd tv. I bought it on the 2nd June 2010. I was watching it last night when, all of a sudden, it turned itself off. Now there is no power on LED and no seemingly no power. There...
It is probably a bad power supply board and yes I have had to replace this board on new machines before. You need to call 1-800-samsung and set up a warranty service call.
Jul 01, 2010 | Televison & Video
My tv willnot turn on
When it shuts off. Try doing what's called a self-diagnostic test.
As soon as the television shuts try these steps.
Pressing on the front panel's ?INPUT? and ?MENU? buttons at the same time, and holding for 5 seconds,
activates the Self Diagnostic Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Please do Note: The front panel buttons must be used, NOT those on the Remote Control.
? The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
? The flashing then pauses for approximately 1/2 second.
? The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
? The Error Code is repeated a total of 5 times.
Example: If the Error Code is ?24?, the LED will flash two times, pause, and then flash four
times.
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
Self Diagnosic Code Description
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source).
Jun 09, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Philips 30PW8420/37 TV Won't Turn On
The led code indicates vert failure for one. ( 3 blinks )
The 2 blinks indicates excess beam current of which could be your picture tube or re-adjusting the G2 voltage on the HV transformer which is very critical on philips sets.
Apr 10, 2008 | Philips 30PW8420 TV
Power went off last night and our phone stopped working
I had power outage last night now corder at&t 1855 led's keep flashing keeps telling me about power outage before every new message. How do I get rid of the flashing?
Apr 14, 2007 | Uniden CLX485 Cordless Phone
Samsung RF4287HARS French Door Refrigerator Logo
108 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
