Question about Sony DRU 510A DVD±RW Burner
Sony DL DVD Burner, Opens by itself and sometimes will not stat closed at all. No rhyme or reason to it, sometimes it works fine, sometimes it opens... Any Fix?
Magullaaa
Posted on Apr 27, 2009
SOURCE:
What cd burner can replace a Sony CRX310S-DB
Any Internal DVD/CD burner that uses what is called a SATA interface will replace this one. You can find replacements for this at a very reasonable price on my favorite computer parts site www.tigerdirect.com It is very easy to replace the drive. Here is a link to one such replacement. This one is on eBay.
http://www.ebay.com/itm/PC-Internal-Desktop-Computer-SATA-CD-DVD-R-RW-ROM-DL-Burner-Drive-Writer-Player-/270818140994?pt=PCC_Drives_Storage_Internal&hash=item3f0e04e342
Oct 13, 2011 | Sony Computers & Internet
Sony AD-7260S does not write or read Dual Layer DVDs
i think your drive Lens is weak that reason your disk is not read or write
Sep 08, 2011 | Sony Optiarc AD-7260S - DVDRW (R DL) /...
My trunk on my 2004 Chevy Malibu will not stay shut. There is no rhyme or reason why it opens when it does. Sometimes, it opens when I open any of the 4 car doors. Sometimes it opens when the car is in...
there is whats called a trunk lock mechanism that is simmaler to what is in you doos to keep them shut there is a plastic tab that keeps the trunk closed the tap has brokern find you local chevy dealer and pick up the trunk latch should not be any more than $30 usd and labor to put it in will run about $50 usd
Sep 07, 2011 | 2004 Chevrolet Malibu
The TS-H652L drawer opens and will not close. Need a driver perhaps??
Drivers should not impact the drive not closing. This issue is a hardware issue. Good thing is you can order a new dvd+dl burner sata or ide off of newegg.com for under $35
Aug 28, 2011 | HP Pavilion a1540n PC Desktop
My computer doesn't register the ne.ASUS DRW 24B1ST - Disk drive - DVD±RW (±R DL) / DVD-RAM - 24x24x12x - Serial ATA - internal - 5.25" - black I had a ATA before and have now got a sata. The...
goto device manager,,...Open the "Run" dialog box by pressing and holding the Windows key, then press the R key ("Run"). Type devmgmt.msc.when it opens,right click the topmost icon,,choose "scan for hardware changes"..
sometimes,windows not show your dvd drive,unless you put a disk in.
Sep 15, 2017 | ASUS DRW 24B1ST Disk drive DVD RW ( R...
My multi dvd writer door opens every time I insert a disk it opens by itself
Check for loose contact, dry solder at the power connector end, try cleaning the lens, most of the times the rubber belt that is used to drive the tray gets loosened due to time factor and usage
Jul 29, 2010 | Lite On LiteOn LH-20A1P - Disk drive -...
When i want to burn a cd my burner opens and closes by itself and
It can happen sometimes. You can try holding the tray while it is open, insert a blank CD-R and close it. Now you can use it for burning.
Sep 22, 2009 | Philips PCRW (PCRW404) CD-RW Burner
Cd drawer opens and closes by itself
the sensor that tells it when door closes under door theres a guide that flips a slide switch as it goes in is failing. bad hardware!
Nov 11, 2008 | Philips PCRW (PCRW404) CD-RW Burner
Sony AW-Q170A-B2 DVD RW Dual burner - drivers needed?
MAN TRY ANY OTHER DVD SOFTWARES
FIRST OF ALL YOU GO AND SEARCH FOR K LITE MEGA CODEC  DOWNLOAD AND INSTALL
WHAT IS U R OS
Jan 01, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
Unable to burn DL discs
Whats ur DVD specs, it has to be DVD-DL capable, not just and DVD can burn both DL
Dec 09, 2007 | Sony DW-G120A DVD RW Dual Layer Burner
Open Questions:
Sony DRU 510A DVD±RW Burner Logo
87 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
