Question about Nokia N79 Cellular Phone
Master reset code
After turning off the phone and Turn it again,Inside the screen Nothing is shown
  • Mahmoud
    Mahmoud Oct 20, 2013
    lcd Backlighting is on But it can not be seen in any written or sound
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 129 Answers
Change lcd display
Posted on Oct 19, 2013
Testimonial: "lcd Backlighting is on But it can not be seen in any written or sound"
5 Suggested Answers
  • 4102 Answers
SOURCE: switch on button not responding
Hi your problem will be with a stuck key this not allowing other buttons to work the only way to solve this problem is to remove the outer casing and clean the pads behind the buttons it might have evn got damp and coroded as this causes the problems your describing.
The big problem is taking the phone apart as its not east to do and it also needs to be undone in certain order else you can warp the board destroying the phone completely and when putting back to gether it has to be done in certain order and the screws have to be tighten up to certain tension else the board will also warp.
If you are unsure of what you are doing then dont do it as you can destroy the phone beyond repair ok
You can try searching online for instructions on how to remove the cases but these are hard to come buy but would be of help to you.
Of unsure take it to phone shop as it wont cost to much to get repaired and it would save you destroying the phone beyond repair
Its not just the screws that need undoing their are also clips running along edge of the case and as its a slide phone their is a spring between the two halves that need removing before the ases can come off but this spring can destroy the ribbon betweent the two halves so be warned ok
Posted on Mar 31, 2008
otacon
  • 1944 Answers
SOURCE: 6288 switch on button not working
You should try to reflash your phone's firmware.
http://www.nokia.co.uk/link?cid=PLAIN_TEXT_52635
Posted on Mar 29, 2008
SOURCE: n73 master reset code
I forgot my security code
Posted on Jul 14, 2009
VinayT
  • 1884 Answers
SOURCE: When I turn my phone on it ask for a security code
There is no master security code. If it is asking means you changed to original which was 12345. Now without the new code it will not let you move until you re-install the firmware.
Posted on Aug 03, 2009
I want to know the shortcut keys to bypass my nokia phone security code.I put security code on my nokia phone. and about two weeks, i forgot it. and when ever i turn my phone on, it ask me for security...
If you forgot the security code you have to reset you mobile......... Its the only way to use your mobile again. After resetting you can enter a new security code again.
You can visit http://www.theunlockspot.com/nokia-dct-master-code-service/rs10wp10/ for the master reset code service and get the reset code........
Jan 16, 2012 | Cell Phones
Forgot security code
what is your mobile mobile model? try the default codes like 12345 or 00000. if they didn't work our you can go with resetting your phone. You can reset your security code through master reset codes. You can get the master reset codes fromProunlocking.com
Dec 29, 2011 | Cell Phones
How can i unlock my cellphone i forgot my pass word
what is Your Phone brand and Model? You can reset the Phone using the master reset code,You can get the master reset code at here Unlock-free.com and reset it....If your Phone Nokia or Alcatel means get the master reset code and reset from PASSWORD LOCK...
Jul 26, 2011 | Lands Phones
Its not getting started.just showing SAMSUNG SCH-S379 Logo n its blinking once again the same LOGO is shown as SAMSUNG SCH-S379. Need urgent solution of it . il b thank ful if u help me out thank u. My id...
Do a Samsung b3310 Master Reset:
CAUTION: A "master reset" changes the phone settings back to default. This process will erase all contacts, downloaded settings, and downloaded applications (ringtones, wallpapers, graphics, etc). This process cannot be undone.
Enter *2767*3855# from the standby screen. (You may need to remove the SIM before it will allow you to type the code in). Or flash your phone
Dec 24, 2010 | Cell Phones
Security code problem
Unlock service provider: Insert sim, turn phone on and press vol up(arrow keys) for 3 seconds, should say pin code. Press C,then press * message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Jan 29, 2009 | Nokia 1100
Forgot Security Code
To unlock a Samsung turn the phone off take the sim card and type the following code *#pw+15853649247w# .
Java status code: #*53696# (Samsung X600) If you want to unlock your phone put a sim from another company then type *#9998*3323# it will reset your phone. Push exit and then push 7, it will reset again. Put your other sim in and it will say sim lock, type in 00000000 then it should be unlocked. Type in *0141# then the green call batton and it's unlocked to all networks. This code may not work on the older phones and some of the newer phones. If it doesn't work you will have to reset your phone without a sim in it by typing *#2767*2878# or *#9998*3855# (not tested)
Jan 28, 2009 | Nokia 1110 Cellular Phone
Motorola q9c smartphone is frozen on windows mobile screen. this happed when i updgraded and had a new phone activated. is there any way to unfreeze the phone. have tried teh soft reset with battery with...
master reset the phone by hold the center key and the power, then follow onscreen instructions, let it sit on the windows mobile screen, before you master reset try turning the phone off, and taking out the memory card, then turn back on, if same thing happens....do the master reset
Dec 29, 2008 | Motorola Mobility Q9m Smartphone
I can't view all the calls!
hi there did you try to reset the phone? if not go to menu, settings, master reset, reset settings, then it will ask a code, default code 0000 unless you have'nt change it. but if you choose master clear it will erase everything contact, musics, etc.
peace!
Feb 17, 2008 | Sony Ericsson W850i Cellular Phone
What is the master reset for a v6 razr???
go to main menu then settings. click initial set up scroll it there you will see master reset. click master reset you will see enter security code type 000000 then enter it will reset itself wait it will shut down by itself and activate again
Jun 24, 2007 | Motorola Mobility MOTORAZR maxx V6...
Nokia N79 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
