Question about Hotpoint RGB528 Gas Kitchen Range
Hotpoint rgb518pcd new install, getting yellow flames
    Top Expert:
  • Hotpoint Master
  • 9,472 Answers
Natural gas, they tell us, is clean burning. Well, it makes good ad copy, but it's not 100 percent true. There are trace impurities in gas, and when they burn they become ash. And over a long long period of time this ash can build up and clog tiny gas orifices, like pilot orifices. The symptoms may be that the pilot will not stay lit, or blows out too easily.
There is also a little "cup" around the pilot light in a surface burner to regulate air for proper combustion of the pilot flame. These can get covered with ash or clogged up with spillage from the burner (see below.) Make sure you clean the pilot area thoroughly.
You can usually clean them out with an old toothbrush and some compressed air, but pilot orifices are generally so inexpensive that it's cheaper and safer to replace them. If you choose to clean them out, use a soft-bristle brush like a toothbrush, and not a wire brush. A wire brush might damage the orifice. Be careful not to push the ash into the orifice and impact it.
The surface burner jets are a different animal. The problem is, that pot that boils over can leave some pretty crusty stuff on the burners. The challenge is to get that crusty stuff off without enlarging the gas holes. Sometimes the crusty stuff is not crusty but gummy, and this can be even more fun to get off the burner.
There's no magic way to do this. Depending on what's clogging the gas holes, you may be able burn it off, or at least char it so it can be scraped or knocked off. Use a propane torch or one of the other stove burners if you can get it into the correct position.
You may also be able to use alcohol or some other non-petroleum solvent to knock it loose. If you do, make sure the solvent is completely gone before you put the burner back into service. (Petroleum-based solvents might leave a residue)
Try poking it out with a straight pin if possible. You can use a welding tip cleaner, or a small twist drill, to poke into the holes but only if it fits in the hole with plenty of clearance. Do not use a drill motor with a twist drill; just push it in and out by hand. Use it as if it was a file. Use a twist drill or tip cleaner that is MUCH smaller than the diameter of the hole. Do not use anything with a remote chance of enlarging the hole. Remember, the objective is to take off the crusty stuff without taking off any of the metal. Sometimes a gas stove burner is just too badly clogged, or the holes are too small, and the burner must be replaced.
Posted on Oct 20, 2013
I have yellow in the flame and it seems high unit is brand new
Yellow in the flame means there is not enough oxygen being added to it. There is an adjustment to lower the flame, which is a separate issue. Call the company that made it, or the company that fitted it. The flame adjustment should be done by a qualified gas fitter or installer.
Nov 19, 2015 | Heating & Cooling
Flame has become very yellow and lazy. I installed a new regulator, but didn't help.
try cleaning the burners sounds like they are blocked ,yellow and lazy is lack of air to burn
Dec 10, 2012 | Brinkmann Charmglow Stainless Steel LP...
Just put in a new Caldera LPGas cooktop the flame is yellow and putting soot on pots how can I adjust air to correct this?
you stove may have jets for natural gas rather than bottled gas the calorific value of natural gas is different to propane and the jets are larger because of this. if using bottled gas then you will get yellow flame and soot because there is too much gas to burn properly check your installation manual for procedure to change the jets for each gas
Dec 19, 2010 | Stainless Caldera SSK-305 Steel Gas...
Yellow flame from all carryover tubes. This grill is brand new
if the unit is running on natural gas, this is not unusual. if running off propane tank something is wrong with the regulator
Jul 05, 2009 | Char-Broil CharBroil Master Flame Gas...
My Dyna GLo kerosene heater has excessive smoke and yellow flame
I'm wondering the same
Should a duraheat, etc., cylindrical convetion heater's flame be bright yellow, blue , or what? With the old wick the flame was blue, with the catalytic converter glowing red hot. Now with the new wick, I can't even see the CC, because the flame burns a bright yellow. Also I have to really fine tune it now. A wee bit too high, I get smoke and soot. A wee bit too low, same...smoke and possibly flame out.
Feb 24, 2009 | Heating & Cooling
Flame way too high and yellow-Frigidaire Model #FGF328GM
call an approved frigidaire gas technician as it is possible that the jets in use are not for the propane gas
they are probably natural gas jets which have a larger jet size
the air shrouds around the jets have to also be adjusted to get the blue flame
you may be able to have it checked out under warranty as it is new
if you touch it your self , the warranty will be void
Mar 11, 2017 | Kitchen Ranges
Toyo 56
Hi ejohn,
There is no valuable, practical adjustment for the flame on a Toyo Stove. A yellow flame can be caused by several things. How old is the stove? When was the last tune-up? A dirty sooty carboned up stove will have a yellow flame. A breach in the flue pipe will cause a yellow flame. An incorrect installation of the flue and exhaust hoses/metal exhaust elbow will cause a yellow flame. In the last scenario, the intake will be hooked to the exhaust and the exhaust will be hooked to the intake ports of the flue pipe. A malfunctioning fuel pump can also cause a yellow flame. The wrong fuel can cause a yellow flame, too. Most likely, your stove is dirty and needs a tuneup. It should have a bright blue flame if it is clean, and operating correctly. You can download a manual at REE, Anchorage through a Google search. If you want a more detailed diagoses, write back and give me more detail and I can help you further. Toyotech
Jan 30, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Yellow flame
lp burners dirty.clean out the orfice and burner and this should solve your problem.
Dec 11, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Hotpoint RGB528 Gas Kitchen Range Logo
53 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
