Question about Technics SA-DA8 Receiver
Technics sa da8, no sound
My Technics SA DA8 does not have any sound. For a long time, I could solve this issue by turning it off, letting it rest for a couple of hours, and then turning it back on. As long as it stayed on, it was fine. But, if I turned it off and then turned it on within 5 minutes or so, I wouldn't have any sound. The "rest" period had to be longer than 5 minutes. Any ideas on this one?
Tip
Keeping your SA-DA8 cool
When I first bought this I noticed that it runs very hot even on low volume levels. I took it in for repair and told the tech that the fan didn't come on even when hot. He said "works as designed - the fan is output-power-driven, not temperature driven."
Wishing to prolong the life of ma SA-DA8, I used an old computer power supply and muffin fan. Plugged the PS into the controlled AC output of the amp, and the fan into the PS. Jumpered the "power-on" pins of the PS. Laid the fan on top of the amp, padded with some foam tape, and it now stays a lot cooler (and the fan is very quiet, though not silent.)
on Nov 05, 2011 | Technics SA-DA8 Receiver
Sound just stopped all of a sudden .....unplugged it for 30 secs still did not work....fan was on but it felt a little hot on top
Power amp output IC have an overheat. Cool it down and restart at
low volume. Send your e-mail if this did solve your problem.
Sep 25, 2009 | Technics SA-DA8 Receiver
Max. wattage for speakers w/ Technics Receiver SA-GX100?
I too have a Technics SA-GX100 and it's rated at 2 x 40W @ 8 Ohms. I have the Technics SB-2840 floor model speakers hooked to it, which are rated at 200W Music Input - 8 ohms. It sounds very nice just to be a 40W receiver.
Apr 06, 2009 | Technics SA-AX720 Receiver
Overload technics SA-GX390
It sounds like you have a wiring issue. Try looking for a bad wire or crossed wires between the positive and negitive jacks on the back of the unit.
Nov 06, 2008 | Audio Players & Recorders
SA8 5.1 receiver overload comes on with no sound
Try checking your fuse if it overloaded then it probably blew it
Oct 22, 2008 | Technics SA-DA8 Receiver
Sa-da8 overload and off
Be sure that the EQ settings aren't accidentally putting you over the top as far as demand is concerned. Bass-heavy material? Same conditions apply...accordianman
Jan 21, 2008 | Technics SA-DA8 Receiver
Sa-Da8 Overload and power off
you mite be pushing too much power, try unhooking a few speakers or check the wattage cuz that mite be your problem
Jan 12, 2008 | Technics SA-DA8 Receiver
I hooked two Receivers up in series a Technics SA-DX930 and a different kind I'm not sure wut kind. They worked great for a while, but when they got turned up a little louder they both quit puting out...
you blew your power amp board, you cannot hook them in series due to impediance matching and improper input levels, cheaper to replace reciever than the board
Apr 30, 2007 | Technics SA-DX930 Receiver
Technics SA-DA8 Receiver Logo
64 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
