Question about Health & Beauty
Microsoft Windows XP Media Center
When I turn on my laptop it prompts me for a password, that I did not set up. I have no idea how to solve this problem.
  • 625 Answers
When you start you machine press whichever key you need to get into your cmos setup. once you get there look through the list for password enable or disable. I think pressing the spacebar will change the enable/disable state, then save and exit.
Posted on Sep 27, 2007
I have windows 7 home premium. my windows media center was working normally until one day, it prompts "windows media center has stopped working"
u can check ur event viewer and see what the error code is and look it up online r u can just reinstall media center that should solve the issue but before u do anything please make a back of ur system. now go to the control panel and select program and features now select turn windows features on or off now click on the plus sign besides media features and select windows media center and uncheck the box and reboot and that should unistall media center now just redo all the steps but this time check media center for it to be install and reboot...hope this fix the error...
Jul 07, 2011 | Microsoft Computers & Internet
Tip
How to solve NTLDR is missing issue in windows XP
Using Windows recovery console.
The Windows 2000 and Windows XP CDs supplied by Microsoft has a tool called the Recovery Console which can be used to repair errors that prevent Windows XP from starting using the command line. OEM versions of Windows XP, including computers that were supplied with Windows XP preinstalled, may not have this utility.
This problem may occur if the basic input/output system (BIOS) on your computer is outdated, or if one or more of the following Windows boot files are missing or damaged:
Ntldr
Ntdetect.com
Boot.ini
Check your drives for floppy,USB storage devices,CDs and any other bootable media.Because sometmes these things makes problems.Then go to BIOS and do the BIOS settings to boot from the source where the OS is installed.
1: Insert the Windows XP bootable CD into the computer.
2: When prompted to press any key to boot from the CD, press any key.
3: Once in the Windows XP setup menu press the "R" key to repair Windows.
4: Log into your Windows installation by pressing the "1" key(most of the cases it will be "1" only) and pressing enter.
5: You will then be prompted for your administrator password, enter that password.
6: From the command prompt, copy NTLDR and NTDETECT.COM from the i386 folder of the CD to the root folder of the hard drive. In the example commands given below, C: is the hard drive and D: is the CD-ROM drive. You will need to change the drive letters if appropriate:
COPY D:I386NTLDR C:
COPY D:I386NTDETECT.COM C:
Once both of these files have been successfully copied, remove the CD from the computer and reboot.
on Mar 03, 2010 | Microsoft Windows XP Professional
Whats a good tool to check system files on windows xp?
get your OS disc (windows) ready
Start>run>cmd> hit enter
"sfc /scannow" on prompt then enter, wait for the system file checker to finish
if prompted for the disk just put it in and hit ok.
Mar 26, 2011 | Microsoft Windows XP Media Center Edition...
How do i connect my 360 to the computer
I had this same problem and found this great video on youtube.
go here:
http://www.youtube.com/watch?v=BaKgCYkSCjc
over 175,000 views
if you click the drop down on the info you'll see the step by step instructions.
STEP 1
If you were previously using your Xbox 360 with a Windows XP Media Center Based PC, you will need to remove existing connection. Otherwise skip to step 2.
At the Windows XP Media Center PC
Click Start, point to All Programs, point to Accessories, point to Media Center, and then click Media Center Extender Manager.
Select your Xbox 360 and click Properties.
Click Remove.
Click Yes to confirm removal.
At the Xbox 360
On the Xbox 360, go to My Xbox and then System Settings, then select Computers.
Select Windows Media Center, and then press the A button.
Select Disconnect.
Press the B button until you return back to the System Settings.
STEP 2 Gather Setup Key from Xbox 360
Press the Media Center Start button on the remote or go to My Xbox, then select Windows Media Center.
Advance through the on-screen instructions to obtain the 8 digit Media Center Setup Key. Write this key down.
STEP 3 Add Extender
At the Windows Vista-based Media Center PC, launch Windows Media Center. Select Start, Windows Media Center.
Select Tasks, Add Extender.
When prompted, provide the 8 digit setup key you received at the Xbox 360.
Complete the Extender setup.
STEP 4 Print the Media Center Quick Reference Guide
Dec 04, 2010 | Microsoft Xbox 360 Console
My 9 year old computer is lock how do i unlock it if i forget his pass word
If you have another account on your laptop that has administrator rights, log in into that account and change the password for your account (click on switch account to log in). If you have an administrator account (even if you don't try putting in Administrator and leave password field blank) try using that account to reset the password, otherwise try one of the following:
- see this for XP http://support.microsoft.com/kb/321305
- or this for Vista/Win7 http://windows.microsoft.com/en-us/windows-vista/What-to-do-if-you-forget-your-Windows-password
- or if anything else didn't work you can use thrid party software from Hiren's Boot CD http://www.hirensbootcd.org/download/Hirens.BootCD.12.0.zip
Dec 01, 2010 | Acer Aspire One PC Notebook
I cannot play a sound because i don't have a sound
Click on the links below if your computer has that particular operating system on it.
Microsoft Windows 2000 s.gif » Microsoft Windows XP s.gif » Microsoft Windows XP Home Edition s.gif » Microsoft Windows XP Media Center s.gif » Microsoft Windows XP Professional s.gif » Microsoft Windows XP Tablet PC Edition
Jun 06, 2010 | HP Compaq nc6000 Notebook
Error 105 (net::ERR_NAME_NOT_RESOLVED): The server could not be found.
open command prompt start >run type in cmd
type the follwing command in cmd
ipconfig /flushdns
press enter
this will solve the problem please rate....
Apr 10, 2010 | Microsoft Windows XP Media Center Edition...
How to connect your windows media center from your laptop to ypur x box 360
Set up an adhoc network(pc-to-pc) on your laptop and connect the 360 to it. the laptop should recognize the media extender then follow the on screen prompts
Oct 28, 2009 | Microsoft Wireless Network Adapter Xbox...
Media center receiver service error
The only usefull solution i have found is running mcerepair from this site
http://blogs.msdn.com/peterrosser/archive/2005/10/21/483723.aspx
Its from the microsoft developer network so while not being official it is from someone at microsoft
alternativly you could run "sfc /scannow" from commandline or the start > run dialog, this will return all windows system files to their original versions, it might solve your issue
hope you find this helpfull
Dec 11, 2008 | Microsoft Windows XP Media Center Edition...
Health & Beauty Logo
123 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Jeff Tilburn
Jeff Tilburn
Are you a Health and Beauty Expert? Answer questions, earn points and help others
