Question about Sony STR-DE310
Str-de310 goes to protect mode with nothing hooked up to it except the power
    Problem Solver:
  • 14 Answers
Speaker positive and negative terminals are short circuited, carefully inspect the back speaker terminal if a small single strand of a wire causing this.
-SS
Posted on Nov 15, 2013
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: stuck in protect mode
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Posted on May 29, 2009
  • 167 Answers
SOURCE: Sony STR-D715 Protect Mode
This is a common problem...
It is in fact a bad power-amp module.
I have repaired quite a few of these receivers by replacing it.
The module is inexpensive. I Googled the Part number and found several sources for it.
Posted on Oct 10, 2009
  • 118 Answers
SOURCE: my sony STR-DE695 flashes protect with nothing
if it is in protection mode with no speakers connected, then youve got an internal problem which will need repaired
Posted on Feb 23, 2010
Flashing protected screen
You have two speaker wires touching. Check each speaker and the back panel jacks. Even a single strand of wire will short things out and lock the protection mode.
Sep 18, 2011 | Sony STR-DE310
My sony STR-DE695 flashes protect with nothing hooked up except the power supply. Is it a grounding problem, or something else?
Feb 23, 2010 | Sony STR-DE695 Receiver
Sony Receiver STR-DE310 flashing "PROTECT'
Replacing ouput transistors and probably a couple of resistors is best left up to a repair shop. The entire main board needs to be removed to access the solder side of the board, many screws and several connectors.
Jan 21, 2010 | Sony STR-DE310
My Sony STR-de310 is flashing "Protect", and none of the other buttons work. What does this mean>
there is a short circuit somewhere in the amp. turn it off and find/fix it before turning it back on again.
http://pdf.crse.com/manuals/3859380111.pdf
Jan 09, 2010 | Sony STR-DE310
When iturn on my Sony STR-DE325 it goes into protect mode
Try disconnecting all of your speakers, and then turn on you unit. If you have a defective speaker, or a short in your wires, your unit will go into protect mode. If your unit seems ok with the speakers disconnected, then turn unit off, hook up one of the speaker leads and try it. This way you can isolate the problem.......
Good Luck,
Eric
Jul 09, 2009 | Sony STR-DE325 Receiver
My Sony STR - DE310 flashes PROTECT
remote volume control is broke.
Dec 22, 2008 | Sony STR-DE310
Str-de310
hey painkiller.. :)
Have you tried disconnecting it from the mains power for 20 mins or so then fire it up again. This will allow it to reset. Often fixes this sort of problem. If not, get back to me here and we can try some other things.
gotta love black sabboth :)
regards
robotek
Nov 04, 2008 | Sony STR-DE310
Sony STR-DE310
Our Sony STR-DE310 displays the message "Protected" and will not operate. We have not used it for awhile, but it worked finte the last time.
Jan 27, 2008 | Sony STR-DE310
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Plugging an mp3 into a Sony STR-DE310 receiver
Yes U can.... just put the rca cable in the cd or tape/md receiver
Nov 10, 2007 | Sony STR-DE310
Sony STR-DE310 Logo
150 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
