Question about Dryers
How to remove back
Can you send a picture on the back and inside of my stove I did get one with my stove and I need a light bulb
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 92 Answers
Most diffusers are twist to remove, then lamp is also twist (Edison screw) - this is done from inside cavity, user accessable.
PS: righty tighty, lefty loosey.
Posted on Oct 18, 2013
The flame effect quit working in my Brittany Electric Stove Heater, Model #BESBY-1500. How can I replace or repair the flame effect?
Typically the flame effect is accomplished when a motor turns a rod with polished metal strips on it. The strips then reflect the light onto the back of the glass. The the rod rotates, the reflection moves giving the effect of the flames moving. If the lights work on your unit then the motor has most likely stopped. It would need to be replaced. A quick internet search turned up nothing for that company so you may need to go back to the store where you purchased the unit to get the part. Once you have the part, you will need to disassemble the unit. Some units are simple (like removing the fake logs) and some units are more involved (like removing access panels from the back or bottom).
Mar 10, 2014 | Vendor Development Group Inc Borgen...
Motor running but no flicker effect shaft drive
If you check your owners manual it should tell you how to change bulbs etc. Are you not seeing light, or light comes on but no flicker? If you can reply with model number on your unit, perhaps we can guide you to diagnosis and repair easier.
Sep 21, 2011 | Dimplex Compact Electric Flame Stove...
Light and flame effect not coming on dimplex springborne electric stove.
The light bulbs that provide the flame effect, may have burned out. You can access the bulbs by remove a rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I hope this helps you and thanks for choosing FixYa.
Jul 25, 2011 | Dimplex Compact Electric Flame Stove...
How do I replace the light bulb in a Dimplex Springborne electric stove?
You can access the bulbs by removing the rectangular access panel on the back of the stove, just above the bottom edge of the stove. Be sure to turn the unit OFF and unplug it before attempting the bulb replacement. The bulb type is 60 watt, small base, clear chandelier bulb.
I can't to find the area to replace the bulb. Everything works except for the light To eacy to leave on without the light. Where is the bulb located and what should I purchase to replace it. model #...
On the back of the heater stove, you will see a rectangular panel in the center, near the bottom of the stove. If you remove that (by removing the screws that hold it in place), you will have access to the small base, 60 watt. chandelier bulbs that you will need to replace. Be sure to turn the stove OFF and unplug it, before attempting to replace the bulbs.
Hope this helped you and Happy Easter!
Apr 24, 2011 | Dimplex Compact Electric Flame Stove...
I have newhome es 550 cooker and the light inside the oven is not working.Can i get a replacement, if so can you tell me what i need and how do i go about changing the bulb.
Go to a Home Depot, or Lowe's and get a high temp bulb. Remove the screws that hold the cover on, and change the bulb like any other bulb
Mar 31, 2010 | Stoves Newhome ECH600MXa Electric Kitchen...
Where does new bulb for picture go inside the TV?
The bulb is in the front of the TV. Remove the front lower cover by pulling oneside at a time. There will be a lable next to the cover for the light housing.
Feb 09, 2010 | Mitsubishi WD-62525 62" Rear Projection...
DLP HDTV shut off, sound but no picture
replace light bulb,
if you are hearing a click like the stove is because the lamp balast is trying to power on the lamp,
if you need part number and vendor please send me the model number
Apr 18, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Oven not working
I had the same problem. At the back of the stove is a plastic cover with thermal overload written on it.
Switch off your power.Remove the cover, pull out the two luggs and connect the two luggs straight to each other. Make sure the oven knobbs are in the off position. turn on the power. If your oven clock etc. comes on the thermal overload is faulty and needs to be replaced. It is fixed to the stove by a screw from the inside of the oven, so open the door and remove screw to remove thermal overload at the back of oven. Take sample to electrical shop and replace. DO NOT USE OVEN WITHOUT THERMAL OVERLOAD.
Dec 27, 2008 | Ovens
Kenmore Range/Oven Smooth top Model 95022107 RM3120383
Friend,
ngfam1 at your service!
Below I will give you a 800 # that if the part is in stock they usually send parts in one business day!
The lens should tun and come off. How old is the stove and the model # ?
Usually if the lights flash this is a code that the manufacture recommends service to be used!
Bulb sockets will mostly all be a little burned color because it's in an oven!
lets see what you send me??
If you end up needing service, here is a good company nation wide that can make appointments 24/7!
A&E Factory service
1-800-905-9505
We have been in the appliance business for 65 years!
ngfam1
Bless you
Please give me a good rating before you sign off !
Aug 30, 2008 | Kenmore 95022 / 95024 / 95029 Electric...
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
