Question about Sony SA-WMSP1 Subwoofer Speaker
My Sony WA-WMSP1 sub woofer sounds good but has a bad habit of shutting down and off completely for awhile then will play again for a minute then go silent...on and off , on and off. How can I fix this?
4 Suggested Answers
early1234
  • 871 Answers
SOURCE: sony sa-wx90 subwoofer
thats called electrical recoil, the energy that is stored bursts out thru your subs therefore you hear your subwoofer bang.
i suggest you clean your wirings.
hope this helps.
Posted on Jan 14, 2008
dunnbiker
  • 8546 Answers
SOURCE: replacing sub speaker
I wouldn't try reinventing it by replacing the driver. Drivers and their enclosures are designed to work together. And this being a self-amplified subwoofer, there is one more piece that's electrically optimized to the rest. Don't mess with it.
Why don't you just set your receiver's individual relative speaker volume levels so the sub isn't weak by comparison to your other speakers? Weakness, as you call it, is relative.
Is your receiver properly channeling Low Frequencies to the sub? Experiment with the cutoff, too.
This problem doesn't require meatball surgery.
Posted on May 19, 2009
SOURCE: my sony SA-wx700 sub woofer does not have a sound
Check out this link to a thread. I bought a Sony SAWX-700. The light came on when plugged in. The guy said he didn't have a way to test it, but assured be the light was on and that it worked. I got home and it didn't. Did a search and found these posts. I followed them, ordred the parts and fixed it for like $10.00.Hope this helps! I also did a Youtube search on how to solder and desolder and wasn't that hard. http://www.avsforum.com/avs-vb/showthread.php?t=944798
Posted on Nov 20, 2011
No sub woofer output or very little
Your sub amplifier is detecting an overdrive condition and reducing volume to prevent the output stage from burning up. When reduced volume doesn't work, output is cut completely for 10 minutes until things have cooled down.
Mar 27, 2017 | JVC KD-R740BT
The subwoofer starts to make a loud thumping sound
Remove the signal source and power it on to see if the problem occurs without any input signal. The problem could be in the receiver and not the sub
Dec 08, 2013 | Cerwin Vega Avs-sub8 150 Watt Amplified...
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
The required fuse is 1.6 A / 125V an is blown, I wen to radio shack and bought a 1.6A/250V and it has blown 2 already, what can I do or check to fix it? This is a Sony Sub-woofer model sa-wmsp1.
If power transformer T1 got shorted or its output voltage got shorted for some reason, fuse will blow in Sony SA-WMSP1 active subwoofer.
Check power transformer, D401 bridge rectifiers and IC301 power amplifier out chip. Any of them is bad.
Let me know if you have additional question.
Thanks.
Jan 08, 2010 | JBL PSW-D110 Speaker
Sony xplod XM ZR602
What ohm is your sub running at. Sounds like your runnig your amp to low an impedance causing it to thermally shut down, when it cools a bit it turns back on. Either that or you have wires crossed somewhere. Check your wiring and make sure the load of the speaker does not fall below the rcommended ohm of the amp. Usually 4ohms mono and 2ohms stereo
Sep 07, 2009 | Eclipse EA3422 Car Audio Amplifier
Sub woofer is blowing up and down even when head unit is off
This is an internal power supply failure - most likely a failed capacitor or bad ground trace..
Your amplifier requires repair.
To verify this - remove the RCA cables and if the "heartbeat" is still present - take the amplifier to a local repair shop that specializes in car audio and tell them your symptoms.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | Sony XS-L121P5 Car Subwoofer
Sub-woofer shutting off
woofer circuit problem! it could have been overdriven causing overload to the component on the circuit. check woofer circuit for damage components, most likely power ICs and capacitors bulging
May 20, 2009 | Audio Players & Recorders
Radio plays for short time and shuts off ive tride every thing
The problem is most likely the amplifier circuit. It is probably over-heating and the speaker relay is turning off. it is not likely that it can be diagnosed properly on an online forum, since it takes some troubleshooting to be certain of it. Does this system have the amplifier built into the sub-woofer? If I had the model number I could probably give you much better advice, not all home theater systems have the exact same problems. Each different model of every brand have there own unique problems specific to that model number. There are some universal problems, but this is not one of those easy to figure out universal type of problems. I work at an authorized Samsung service center and have experience with repairing these type of systems, so if I were to get the model number I could offer you a better solution. But it is likely that it will need to be serviced to determain the exact problem. A couple of the Samsung home theater systems that have the amplifier in the sub-woofer must have the entire sub-woofer replaced because they do not offer the parts and service data needed to do a component level repair.
One way to determain if the sub-woofer has the amplifier built into it is if all the speaker wires for the sattelite speakers all connect to the sub-woofer.
Sometimes a bad speaker can cause the amp to get hot and shut down, you can check these very easy yourself.
First, while the system is turned off, disconnect one speaker. Any speaker is OK to start with. After one speaker is disconnected, turn on the system and play it at medium volume. If the system stays playing and doesn't turn off the speakers as it did before, the speaker that is disconnected is probably bad. Take it to a service center and get it checked to be certain. Most service centers will do this for free as a courtesy to their customers, it only takes a minute to check.
If the system turns off as it did with all speakers connected, you then need to reconnect that speaker and disconnect one of the other speakers and go thru the proccess again. Make sure to do all of the speaker connecting and disconnecting while the system is turned off.
If you end up disconnecting all the speakers one at a time and the system still shuts off, it could be that the sub-woofer speaker is bad or the amplifier is bad.
If you can give me the model number of your system, it would help.
Dave
Sep 13, 2008 | Samsung Audio Players & Recorders
Panasonic Sub Woofer
I Have the sub woofer SB wa 340, but I need the remote control if posible bussines send me the information 7862873227
Jun 23, 2008 | Panasonic SC-HT690 System
Subwoofer stops working after awhile, but only one
it sounds like u blew them or the voice coils could be messed up here is one way to check take the woofer out of the box and look at the coils it should be ornge and then smell it if it smells like fire it might be going bad thats the reson it is frezzing like that let me no what happens and please rate me
Apr 07, 2008 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sony SA-WMSP1 Subwoofer Speaker Logo
87 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
